Thanks brted, this looks like an interesting new option for battery aficionados.
Thanks for the review brted.
Hmmm . . . got some pretty awful results with one of the 10440's (129 mAh capacity at 1A). Will check the other one.
129 mAh, ooh that realy isn't good. I assume that part of the advantage of the IMR's is that their capacity should be reduced less by high loads than with a conventional Li-ion?
I've tested ICR 10440s and gotten similar results. I think they just change the printing on the wrapper. :)
I like your method of testing a lot. I think you're getting a fairly accurate estimation of the capacity. Those 14500 look great. Better than the IMRs I got from lighthound (see: AW vs. Lighthound IMR) at 3A. I think I'm going to grab some of the 22650's to test.
I'd love to test the cells you got so that you could verify your measurements. If you have any interest in that, PM me.
The 14500's seem the best of the bunch so far.
On the Turnigy at 1A, the first 18650 tested out at 1330mAh. vs. nominal of 1500. In a flashlight runtime test, I calculated 1265 mAh. This isn't very impressive. But I'm wondering if maybe the Turnigy isn't fully charging the batteries.
I wouldn't advise anyone to order these until I can do a little more testing, including some tests in flashlights of the 10440 and 18650 batteries.
Once I'm done, maybe we can work out a deal where mitro can test the cells too. I realize I don't really need these because I don't have any small high-drain lights and the 18650's I have can take the 2800mA draw of the XM-L I have.
I wonder if those 22650 fit in a L2i body.
Did you manage to test the other IMR 10440? I'm trying to decide whether to buy protected 10440's or these. 130mah on the first one is just too low.
Also, the l2i will fit the 22650's. They're 24mm inside.
I did a test at 1000mA of both of the batteries on the Turnigy and got 188 and 190 whereas the label says 350mA.
Ran the test again, topping them off at 600mA this time to squeeze a little more charge into them and they hadn't lost much charge at all from a couple of weeks ago when I was last messing with them. Discharging at 1000mA one battery now has a capacity of 204mAh and the other a pathetic 46mAh (see below). They sag way, way down under load (down to about 3.7V right away). That's enough for me to say avoid these. In fact, I'd avoid all of the "IMR" batteries from BestInOne just to be safe.
Later: whoops. I may have accidentally tested one battery twice. So the 46mAh reading may have come from the same battery that had just been discharged. I charged the battery I thought was 46mAh and it took just a few mAh, starting out almost immediately at 4.20V. A discharge then gave me 203mAh. So both of these match pretty closely, but well below nominal and I still don't recommend them.
Thanks for the info Brted...I think you're right, best to avoid all of these.
Really? The 10440 and 14500's only seem to be about 2/3 of the capacity of the li-cobalts which doesn't seem too bad.
But doesn’t the cell also have to fit into the tailcap of the L2i? Thats ~22mm.
Good point :D.
Well I got the 18350s and 22650s today so I'm charging in preparation for testing, but I tested the 22650 in the L2i and it DOES fit inside the tailcap until it comes to the threads for the switch retaining ring and then it stops. This results in the cell being a little too long to screw down fully. It does function but the o-ring doesn't engage the body. I think I can find a way to grind down the threads that are holding it up so that it fits properly. (I'm thinking just a sanding drum on the Dremel should do it.)
How would these be compared to Sony, Samsung 18605 LMR s I have?
Here's the 18350s at 3 Amps: (click thumbnail for graph)
I tested both cells 3 times. I'm not real thrilled with the way #2 is lagging behind and just the consistency in general. Still... they perform acceptably. I just wish I had some of the Ultrafire 18350s to compare them to. The #2 cell is getting more capacity with each run, but I wish I knew what I did to get 915mAh out of #1. :) Here they are compared to the AW IMR 18350s:
I took the middle run from each of the generics and here is a single (only) run a pair of the AW IMRs. I like the curve of the AWs a lot better. That would give you higher current reading from the MF UF dropin or the like. The generics look like they're running out of wind at 3A and I bet there would be a big drop in capacity at 5A. But I don't think I'm going to try 5A. They are already getting warm at 3A. I'm doing 1.5A tests now, but I figured that 3A would be most relevant.
I'm going to try them both with the Manafont Ultrafire dropin and get some readings just to compare further.
EDIT: ok... done :)
(MAX from turn-on - tested with my Vichy VC99 with leads from my hobby charger)
AW - 4.325 amps
Generic - 3.506 amps
As long as they hold up, I think they are a good buy. I wish I had a larger sample size, but its safe to say that if your light will hold them, they're going to do better than ANY 16340.
Are you testing the 22650's? I think they're fit a lot of lights that are 3aaa with 18650 option, but most of those aren't terribly great. I have two though.
Yup... I will. I just haven't gotten to it yet.
The 22650 are pretty good. Between 2000 and 2100mAh @ 3A. Here is a graph of an AW IMR 18650, the generic 22650, and a Sanyo 2600 18650 (not IMR):
The only problem it that they don't fit in an L2i like I had hoped. It's possible to make them work, but the machining involved is beyond me. I murdered an L2i tailcap with a Dremel trying to make it work. What we need is solarforce to crank out a 26650 host for 4Ah of goodness. Since the uses for these cells are limited at this point, I'm not going to test them in depth.
This might well work http://www.manafont.com/product_info.php/sipik-ck91-floodtothrow-zooming-cree-q4-convex-lens-led-flashlight-black-3aaa-p-5824
Also small sun c37 for throw.
