I have thought of two or 4 XMLs which I would power with a separate acdc wall wart transformator another driver inside the lightâŠthat would make it absolute safe and bright worklight, perhaps on a tripodâŠ
But I have lost my spare XMLs I have collected through the time, so Have to order someâŠ.
I use one at my solder workstation, and two for lighting my light box for studio shots. The Warm White emitters (once white balanced) seem to have great CRI. Once they warm up they produce a nice consistent light output.
I finished my 7th floodlight ârelic-resistorâ mod today, and they will all get a good long burn-in tonight. After some testing, 2 x XMLâs @ 3A each (24 watts) would definitely be too much for these housings to effectively dissipate heat if left on for more than 10 minutes. Im still very pleased and impressed with the mod results. I think I paid about $7 for each of these. :bigsmile:
Relic, its interesting that these LEDâs still deliver fairly good performance, especially considering their vintage. Do you have a link for the warm-white emitters? I may have to give those a try.
I got them off eBay for about $3 each. Iâll dig up the link. They are the 10W square emitters that the housing was designed for.
Thats a great price @$3 each. I have a dilemma: whether to wire for AC and spread the lights around my yard, or to convert to DC serial for XML (powered by 24-27V DC transformer) and keep the housings all fairly close together (within 40 feet of each other). If I could get the warm white emitters, Id probably go that route. Thanks! It looks like ebay has loads of them listed.
Good news! They are even cheaper than I paid. They were five for $11 way back when I bought. Now they are under $2 for one. Nice!
http://www.ebay.com/itm/1x-10Watt-10W-High-Power-Bright-LED-Bulb-beads-10W-Warm-White-Lamp-Light-3000K-/130900864879
Good seller. Hopefully they have not changed for the worse. Good luck with them.
I have one warm white emmitter bought from fasttech, was fairly cheap too.
https://www.fasttech.com/products/1103511. 3.54$
Could you please explain why two XMLs are to much?
Just because it gets hot? A halogen bulb will get really hot an d that was standard for decades n such housingsâŠ
All 7 floodlights survived the night, but they do get quite toasty after an hour of continuous use (even while out in the cool night air). I actually like the effect of the cool white tint when my back yard is well illuminated. If they start burning out, Iâll consider a change but will keep what I have for now.
@Werner - The housing already gets very warm when the LED is continuously driven at 10 watts. Heat is an emitters worst enemy, especially when kept on for sustained periods of time. I have less than 20 hours of use on a brand new XML that has dimmed by at least 2/3rds because my lamp conversion needs additional heat sinking to properly cool the emitter.
What do you guys think of the 20w or even 30w versions of these found on Amazon and Ebay? Do you think those can handle the heat? Or is 10w a max for these types of enclosures? (Of course there are also 50w and 100w versions too.) I was thinking of replacing one of those typical high pressure sodium HID lights (at least I think that's what it is) with two 20w (or even 30w if I found a good price) LED floodlights. Thoughts?
-Garry
I think the larger ones can handle the heat, if they have good thermal connection to the emitter. The housings are quite a bit larger and provide enough surface area to dissipate the heat. They are quite a bit larger than this one. I built a 60W one using a halogen housing, but ended up using a fan to keep it cool. No longer weather sealed. I also built two other 10W ones in a similar way and they handle the heat just fine.
I find the larger ones to be a little pricey, so Iâve stayed away from them. I have seen a few models in Home Depot, and they are even more expensive, so i guess maybe the one online arenât relatively that expensive.
Thanks for the feedback relic! Hard to tell from the photos that they are much larger. Here is an example 20w one I was looking at (US seller) - $27.49ea. $34.90 for a 30w "day light" one. Be nice if they already have attached ground wires and good quality control on them.
-Garry
Anyway, That 20W is quite a bit larger at 7âW x 5.5âH x 4.3âD
The 10W one I have is 4.5âW x 3.5âH x 3âD
Edit: Depending on shipping, thatâs not a bad price either ($27, doesnât ship to Canada)
I have the fasttech 10W 12V led driven with 700mA on a finger heatsink like this
As a desk lamp and it gets hot maybe 60°C but thatâs nothing bad it works and makes nice floodie lightâŠ.
And if I consider that I have really small Tubular flashlight with 8W LEDs⊠I think that it should work with such big housingsâŠ
But I think you are right that heat isnât good especially if you use this light continuously for lightning. I would use this as a working light and for playing around or so and the huge 12V emitters arenât really efficientâŠ
Maybe I will check the light out later, havenât put my hands on it for about half a year.
How is your mounting piece on your lights, mine wasnât really build up well if I remember correctlyâŠ
Edit: I have just searched my light and I think the 3T6 driver should fit in the driver compartment, that would give me a nice voltage range and even modes. And nice regulated current. Maybe I use two XMLs parallel driven with 4.5AâŠ
So I just ordered a pair xml2 T5 3C.
If you are referring to the 10W worklights, the emitter is directly mounted on the main light housing. It could not be better. One improvement would have been anodizing the housing instead of paint. Still, at 10W, it is fine. I think it could be pushed to 15W with a bit better driver.
Yep, I guess 15W should be OK and thatâs what the stock 3T6 driver does from 4-13VâŠI have just looked up and xml2T5 does 630 lumen @2A so I guess at4.5A it should be a nice floodlight with 1200lm or so.
Nice hint with the paint, I am going to grind it awayâŠ
I will try to solder 2 XMLs on one star like I have seen it here somewhere, maybe I can grind some of the protective layer awayâŠnot sure but I will try.
I have some noctigons/sinkpads lying around anyway.
The screws for the mounting piece(not sure how this is named) doesnât fit the threads or maybe the threads are paintedâŠanyone else had this?
You can mount two XM-Ls on one star, but grinding away the space around it will do no good. There is just aluminum under the dielectric layer.
Two XM-Ls at 4.5A will give more output than one, for sure. At 4.5A into one XM-L, youâd be better off with a direct bonded copper star.
I wonder if there would be any differences in heat output:
- 1 x XML driven at 3A
or
- 2 x XML sharing the same star, driven at 3A⊠so 1.5A each emitter.
Ive noticed that most LEDâs seem to run fairly cool until you drive them slightly harder.
There's no aluminum underneath to worry about with a sinkpad/noctigon
That ^^ worked fine, direct drive I think it was around 5.8 amps and made plenty of heat (and a LOT of light). Getting a usable beam pattern with a round flashlight reflector is near impossible but would work great in a floodlight.
What Comfy did should work fine. Now that I think about it, on a regular star it would have heat issues.
Thanks but I probably didnt explain that correctly.
Which would give off more BTUâs? One XML driven at 3A or two XML at 1.5A each. Im guessing the first option, but I havent been able to confirm this.
