Got my Shocker - a comparison... plus a question
My BTU is hitting aroung 130,000 on the lux meter…
Makes me winder if your meter is under-reading? I have a feeling that if the DD’d and dedomed XP-G2 is on copper (Sinkpad/Noctigon) it would be reading north of 100k based on what I’ve read from Tom E’s results.
The lux reading is the main reason I was posting. I’d seen that folks were saying 100K+ lux.
I was taking my readings at 11 feet (3.352) from the meter, then:
lux @ 1m = (distance squared) * (my lux reading)
I got that “formula” from another older thread I had.
Is that right?
BTW, I got the Shocker with the “BTU Driver”, and not the “DRY driver”. I also ordered a DRY driver with the same order, but it’s not being used currently.
I was just out with my shorty STL-V6, and the BTU Shocker, hitting a treeline that’s ~100 meters away from our front porch, and both the STL-V6 and the Shocker hit the treeline, about the same brightness. The Shocker beam at that distance is quite a bit larger, but, while the Shocker beam may be a bit brighter than the STL-V6’s, the brightnesses looks kind of similar.
For 3 IMR's, the Shocker should be in the 130 kcd range for sure - 77 kcd is definitely low. Did you hunt around for a while to find the absolute highest reading? Think some of the meters capture the highest measurement automatically. Also, 3.3 meters is a little on the short side but I get pretty good results at 4.3 meters, but takes a lot of hunting around that hotspot.
I'm thinking you are seeing the difference you are measuring (close), but both measurements are lower than expected.
Well, I figured out one problem… stupidity :)…
I didn’t realize that with the BTU driver, there are FOUR modes. I think the earlier measurements were on the “high” mode, rather than “turbo”.
I just did a couple more, on “turbo”, and got 8740 - 9000 @ 3.352 meters, which comes up to 101123 on the high end.
But that still seems low?
I’ll have to find another spot where I can get 4.3 meters range.
And yes, I had the meter in Max mode, and moved the beam around to try to capture the maximum, which was the number(s) I reported.
I would not measure the BTU at one meter. Back off to three or four meters and calculate it back to one meter. Higher powered lights need to be measured from further away to be more accurate.
http://www.ledrise.com/shop_content.php?coID=18
Edit: Now I see your latest post. Duh. :smiley:
relic,
That’s what I did… measured at 3.352 meters (11 feet), then calculated back to 1 meter.
Edit: Our posts crossed each other :)…
Try measuring from 8 meters or further. I measure mine from 13 meters just to make sure everything is accurate, multiple emitter or single emitter.
Hi,
I haven’t been able to get an 8 meter area yet, but I did find an area of about 6.4 meters (21 feet), and here’s what I got:
Short STL-V6 DD - w/UCP/p, cleaned/improved thermal compound 2 x Efest 18350, partly charged 1629 66891
BTU Shocker BTU Driver 3 x Efest 18650, partly charged 2378 97647
The last numbers in each row are the @1m calculations.
So, these seem to be almost the same as previous?
Edit: Also tested my HD2010 w/EAST-092 driver, with this same setup:
HD2010 EAST-092/Stock Driver 1 x KK 26650, fully charged 1113 45703
i.e., ~45.7K lux @ 1m.
Just got in a black HD2010 from TMART, here's what I got:
On a fresh TrustFire 5000 26650, approximately 4.0 amps (readings vary): lumens: 952 at start, 887 at 30 secs, throw: 58 kcd
So, could be your HD2010 readings are low as well, because a KK with the HD2010 should be doing 5-6 amps maybe.
I have a TF 26650 also. With my HD2010, tailcap on high is ~4.22 amps. With the TF battery, I get:
1107 at 21.5’ 47539 at 1m (re-measured/re-adjusted distance).
Edit: The above a luxes. Is that the same as KCD?
Yes - 1 lux at 1 meter is 1 candela, technically, we should always quote candela units. kcd is short for 1,000 candela. when someone says lux, you should always assume they are just reading it off the meter, while candela puts it in perspective to a distance which has a standard definition that can be compared and rated at.
That result is again strange - normally a KK ICR should do better than a TF 5000, but the KK INR's are higher resistance than KK ICR's. I got a couple of each, though regretted buying the INR's -- didn't learn about the difference until after I bought them.
Hi,
I agree, it’s strange, but this is the same meter that I used in that other thread with the same HD2010 (although I was using the Efest IMR with the earlier test). I’ve been using the HD2010 as a kind of “benchmark”, since the lux readings for an HD2010 with EAST-092 seems to be fairly well-known.
The distance is, I think, accurate, as I’ve measured it several times.
The only other difference from the earlier testing is that I’m now testing in a slightly different “environment”, so that I could get the new distance.
Earlier, I had the meter attached to the front of our fridge, but we got a new SS fridge last week, so now it’s mounted on the front of the SS fridge (rather than a white one).
Could the meter battery be low and would that cause lower lux readings? The meter’s still fairly new, and I haven’t really used it much though :(…
Puzzling…
Edit: Tom E, I found the earlier thread/post:
In that, you mentioned:
and it appears that I am getting 40Klux/Kcd at 1m with the HD2010 at ~4.22 amps?
If that’s correct, then it appears that the Shocker lux I measured should be “correct”?
Edit 2: Did you already mod the HD2010 so that you got the 57Kcd?
Hi ohaya, sorry to hear for your possible issues.
Can you do me a little favor and see if there are AR lens on your Shocker? if it has, the glass should have bluish/green tint.
Thanks.
That’s a good question. With the light on, looking at the lens from the “side”, there is a bluish tint, but the lens is kind of really dirty. I haven’t tried to clean it yet.
Hmm wonder if this pic helps? AFAIK on Shocker is less bluish…and you should see it when its powered off.
Or this,
And this,
Thanks for the pics. My lens doesn’t look anything like those. With the light off, the lens looks basically clear… no color/tint.
Hmm. Time to PM RIC :(…
Also, would a non-AR lens make that much difference on the lux?
Hi,
Can I ask the following: Has anyone (other than me) gotten a BTU Shocker (with the BTU driver) that is producing less than the 130Klux that others have mentioned?
AFAIK the lens can hold off around 100-150 lumens max. which is very hard to notice.
BTW Ric will send you the replacement lens for free if you got older model, relax…
IMO you got some problems with the meter - or maybe driver problem….lens cant make big difference.
Another test, this time, without the lens.
The same distance, 21.5 feet, and got 107361 lux.
Jim
Edit: When I removed the bezel ring and lens, I noticed that the diameter of the lens is quite a lot smaller than ID of the bezel ring. Is that “normal” for a Shocker?
