I always wondered about these shower head multi-emitter beasts please post your findings and enjoyyour stay
looking forward to your review on this 15 emitter.
I hope you have ordered some good batteries too. And you will definitely need big leads for your multimeter to measure current…
Bumpy Dumpy
Hey THANK YOU for all for the warm welcomes, I really appreciate it! What a cool bunch of guys.
Well SURPRISE the FedEx truck arrived today with my box from LightMalls 2 days early!
The protected 26650’s are charging right now in the 2 new Intellicharger i4’s.
My total order was:
- UltraFire 15T6 16000-Lumen 15xCree XM-L T6 5-Mode Memory LED Flashlight Torch(4x26650/4x18650
- TrustFire X100 7xT6 7*Cree XM-L T6 High Brightness 8000LM 5 Modes LED Flashlight(4x26650)
- TrustFire TR-J18 7xT6 7*Cree XM-L T6 8500LM 5 Modes Led Flashlight(2x18650/3x18650/2x26650/3*26650)
- Focus Adjustment 1xCree XM-L U2 5Modes 1300LM Flashlight Torch(1x26650/3xAAA Rechargeable Battery
- SK68-1 3W 1-Mode Small LED Torch (1*AA)
I’ll read up on how to post pictures & get as detailed a review as I can (for a new guy) posted as soon as I can!
Zeke
Nice! I bet that box is going to make you happy for a long while! Beamshots of x100 vs 15xT6 ASAP please!
I bet the “North Texas” will be a no-fly zone untill after you have finished your tests. :bigsmile: And if you want to just keep some of them and discard the others, there will be people considering those treasures. :heart_eyes:
Hey Zeke! Any first impressions? Tail cap measurements? You do have or have access to a DMM I hope?
We're all waiting to hear about that monster.
Oh, ah... Welcome to the forum too...
This seems cool, but not too useful for reasons some of you already pointed out.
Another reason is that the human eyes perception of light is logarithmic analog. It is not linear, in other words. So you double the lumens, diminish batts life, but get only a slight brightness increase in perception.
To date, I think the 7 LED flashlight is the most useful, striking a good balance of perceived lumen and battery life.
More results in diminishing return.
_
_
Even if you are right (did not check), you are comparing the light at the same distance and area. If you get more throw and wider flood with the extra light then it is good for something. If you do not need see that farther, use the med or low mode to get more battery time. My 2 cents.
There’s definition some uses for it, but not much.
Plenty of reference about the eye perception of brightness. Here’s one
The reason I got into that research was because I mod a 7x and a 9x. Data showed more lights, more current consumed. But my eye said, “yeah, kind of.”
But, it is fun!
Well, what I notice between my J18 and 12xT6 on hikes is a perception that the “entire forest” around me is lit up, wider flood + brighter. Yeah, it cant keep it up too long, but its significant. 15xT6 should be even more significant! Sometimes I do like going with just a J18 though, because of the longer runtime and more level output over time. I’m tending towards running the lights on lower settings, but interestingly enough, the 12Tx6 is still preferrable, just by the fact of the bigger flood zone. I switch all the time between J18/12xT6 and on short hikes I alternate in SRK/Kung/C8 along with the big ones, all my lights are fun, depends on the mood, distance, other people with me and location
The J18 is insane though with the IOS driver, and KK cells - 5,500 lumens I measured... DayLighter has it now, but I got a J18 and the IOS driver, waiting...
Which driver is that Tom E? I have a J18 on the way.
I had mod a J18 with a new 7x board from Kaidomain, 3 MNKE 26650 ($15 each). It is definitely brighter than a stock 9xT6 ak47. Since the ak47 yields probably near 3,400lm, I’d say 5,500lm is about right for the mod’d J18.
I bought 10 of 9xT6 to distribute among people I know. I did mod one of them with a 9x board from Kai. Ran tested it with a 7.5amp 12v Power supply and with the MNKE 26650. It runs very hot quickly, but yield brightness just a tad brighter, if any, to the mod J18. So considering its larger size, power drain, cost, yielded perceived brightness, the J18 is the more worthwhile flashlight to modify.
Also, 2 of 10 ak47 did not work. I traced it to the center LED of the 9x set, on both. That’s a bit of strange coincidence, I thought. And the interesting part was that in this 9xT6, the LED star was labeled “XML U2” ! On the J18 7xT6, they were labeled just “XML”. So if the U2 is marketed as 17% brighter than T6, your eyes can barely tell.
Anyway, the stock 12x or stock 15x on just the same 3 batts 26650 would just drain it faster but shouldn’t noticeably brighter than a modified (and smaller to carry) J18.
We spent a weekend at the beach in FL, the J18 is so impressive as did the ak47. They’d sweep the low tide beach from easily 100yrds away, revealed fishermen in the dark. That was illegal for them to run net on shallow water so they did it at night. While impressed with the flashlights, They requested me not to attract cops attention to the area. LOL
You’d be happy with any of these lights, I believe. I just pointed out trade-offs of efficiency, price, size and resulted light perception.
BarrelMount - real good info there... With TF 26650's, I measured 5,000 lumens at 30 secs, and that is plenty enough, and yes, it heats up pretty quick.
photon1K - it's the only 7 emitter driver IOS sells: http://intl-outdoor.com/boost-7led-3-modes-23-cells-input-circuit-board-p-545.html
We think it's the same exact one KD sells, about the same price. Mode switching is slow and you weill get a buzz/humm on med and lo modes.
Thanks for the info Tom!
The later versions of the AK-47 is only about 32 watts with the low power driver they ship it with now. The IOS driver installed in the J18 should be about 52-55 watts, so that’s a big power boost and makes a big difference in output.
The J18 is insane though with the IOS driver, and KK cells - 5,500 lumens I measured… DayLighter has it now, but I got a J18 and the IOS driver, waiting…
it died on me after i used it for about 15 mins… i think the driver is fried
1. Did you use the heat transfer gum paste between the board?
2. I think it has an auto shutdown feature when it gets too hot. If that was active, it would be impossible to fry if use within power supply spec.
3. High batts drain. Charge your batts again. It could be protection circuit inside a batt shutdown.
Fwiw.
