Since I have a big anniversary coming up, was knocking around the idea of buying a small reasonably priced piece of ‘jewelry’ for the wife… and if she didn’t like it, I would get to keep it.
Triple or Quad?
Well, at least I would have great light to find the way to my new home - out in the doghouse!
hi are these still available please?.
Nichia?.
im looking for the drop in and quality 18650 body to stick it in.
could it be built for me then sent?.
looking for a bright nichia 219 / home garden use really.
Solarforce L2m, L2t are what I have used with vinz’s drop ins - any solarfoce 18650 p60 host will fit from what i understand since all their parts are interchangeable
Though I’m not at all opposed to buying for purely aesthetic reasons (and these creations are gorgeous!), is there any pragmatic benefit to these drop-ins over others? It seems that 4 LED’s utilizing a relatively small reflector and only 3.7v isn’t the most efficient lighting.
thanks, what other drop in can be better than these. they look really good, wow!.
i did see some nichia p60 drop in’s at illumination supply in the US, but what is the difference ?.
those dropins you linked are quite a bit different than the vinz drop ins
malkoff dropins are usually used with cr123 batteries since they are usually based on 3, 6, or 9 volts and will run a battery until there is nothing left in it, so if you use a lithium ion it will run the battery down till the protection circuit is tripped.
the malkoff dropin you linked is 60 lumens in output - much much less than the vinz one - but the advantage to this low output coupled with its efficient buck/boost circuit would result in very long efficient run times. Ideal for an emergency light (since cr123s have a shelf life of 10 years)
edit: having owned about 12 p60s including several triples and a quad, nothing is better than vinz’s dropins
I get mine from http://www.solarforceflashlight-sales.com/ its overseas but they ship fast (i get all my orders from them in 1-2 weeks and you get a registered tracking number)
hey kind thanks , thank you, so once VINZ’s i bought, does it just slot in and ready to go , or do i need to modify anything such as taping etc for a tight hold?.
also the sforce will have a glass lens , so would this be removed or could it stay, as the drop in would already have one.
thanks.
