The hosts handle the same amount of heat and stabilize at around the same temp/light level. The M6 driver compartment heats a lot fast than the SRK (maybe because the black body radiates heat back into it better).
Am I right that the upper limit to this mod is, in effect, direct drive? After all I believe that the cells are in parallel as are the 3 emitters. This is good as there is less danger in wildly over driving the emitter.
The TR-3T6 resistor mod had 2 or 3 cells in series. If I had this light, I wouldn’t hesitate to do this mod.
[quote=dchomak]
Am I right that the upper limit to this mod is, in effect, direct drive? After all I believe that the cells are in parallel as are the 3 emitters. This is good as there is less danger in wildly over driving the emitter. The TR-3T6 resistor mod had 2 or 3 cells in series. If I had this light, I wouldn't hesitate to do this mod.
[/quote]
Most likely yes. We can not know how far the resistor mod will work until someone tries it though. Might be limits. But as can be seen, medium and low becomes higher too. About 3,6A to each emitter is already at the stupid amount of heat for this light IMO. It will be very useful in the winter though. Not only does it function as a light, but it will be a great hand warmer too! :)
4 cells in parallel will be able to kill 3 XM-L mounted on aluminium in DD, so DD is not a good idea on stock emitters. Put in XM-L2s mounted on copper and you should be able to output the amount of current you desire, if the driver will do that. But there is really not much point in going beyond the 3,5-3,6A range IMO. Not only due to vf of XM-L2s and the less great medium and low, but mainly due to heat.
I’m loving this thread. I’ve been seeing resistor modding in the forums a lot lately, but most of the chatter was between modders with electronics backgrounds. This thread is truly helping me understand what is going on. The before and after pictures by RaceR86 gave me immediate focus of the what and how, and each additional post has helped me with the why. Now I’m looking at all my lights a little differently. I can’t wait to get started.
_the_ that is sweet, and your calculations seemed good too.
Based on the resistor values, and amps, we seemed to get very similar results, so that is always nice to see. :)
Are you one of the people who have ordered AR coated lens from CNQ? Would be nice to see your lumen comparison on your modded light with AR lens vs stock.
(I know many others have those lenses coming, and some will probably share, but the more numbers we get, the better)
Edit: did you measure current with 3 x 0.1 ohm resistors?
I have a feeling you will order at least one pretty soon. Im still waiting, I want to see some numbers before I pull the trigger.
If you find the time, this day or another, please check emitter current with 3 x 0.1 resistors. Considering that you only saw a 94 lumen gain going from 2x 0.1 to 3x 0.1. Im wondering if you are not seeing much of that calculated output (3,8A) due to vf and such of the copper mounted XM-L2s.
Some may be familiar with my other SRKs (SRK/UV-S5), both modded. A little comparison here.
I tested both of those vs my current Supfire M6 (not supbeam as wrote on one picture). Mouse-overs below.
Camera settings:
1,6s, f5, iso400, 17mm (aps-c), WB was 5000K on first comparison, and 5200K on the second.
What other members have noted, or showed before. The M6 have less flood, and a more defined hotspot with slightly more throw. Otherwise, not a huge difference compared to my other modded king. In real life, there is no doubt M6 appears brighter due to the more harsh light. Output difference is not that much though. Due to tint,CRI and such, id take the SRK easily. Much nicer in real life. But its impressive to see the output of the M6 with stock emitters (and modded driver circuit).
When it comes to throw, I compared it to my SRK with de-domed emitters and a much lower current. The treeline in the distance are 120 meters away. The de-domed SRK wins fairly easily, not a surprise really. Due to not having that much bright spill, I would say its a better thrower in real life than in the picture. Lots of bright spill and flood kinda limits the ability to see things in a distance. The M6 outputs a lot more light though(!), and still have decent throw despite running close to 3,6A to XM-Ls on aluminium. And when XM-Ls are on aluminium, gain above 3A is not that much.
There is a formula that one can use to calculate current if the voltage drop across the resistors is known. It can be obtained by putting the DMM leads on each side of one of the resisters. The formula is:
Vdo/[1/{(1/R1)(1/R3)…+(1/Rn)}]
Please excuse me if I’m using the wrong types of brackets above. Just trying to make the formula easier to follow. I don’t know if Vdo (voltage drop out) is the correct term either. I don’t have any formal electronics training.
