Well put Kollege. Only thing is I did not kauf a DQG 18650 so if I kauf this one, I am still froh. I did not waste geld.
Just let me know when your better bigger battery charger is here so I can buy a couple. Cheers.
The light should be good if it takes protected cells and has memory. One can only hope.
i don’t need it,i want it
Pretty compact. ;)
only miss up front picture
If World War II ended in a tie... :evil:
Each XPG driven at 1.4A.
That's respectable, and is good enough for an EDC. If there was a slimmer 18650 version I'd get it, I need the smaller size!
Looks really interesting!
My wish list for changes, in priority order:
1. Quoting leaftye: "The low mode should be lower.", about 2% should be fine
2. Add lowlow mode of 0.1 .. 0.2% (not a moonlight, but 1-2lm)
3. 3D tint instead of 3B
4. Tailcap design with longitudinal lines breaks the harmony of this light. Please consider similar knurling than in head. Something like this, but thinner:
Here's some rough calculations for "perfect" mode spacing:
Basic data | ||||
Emitter count | 3 | pcs | ||
Drive current / emitter | 1400 | mA | ||
Total current | 4200 | mA | x3 | |
Mode spacing | ||||
High | 100 | % | ||
Med | 30 | % | ||
Low | 2 | % | ||
Lowlow | 0.2 | % | ||
Cell used | 4200 | mAh | King kong or similar | |
Approximate runtimes | ||||
High | 1 | h | ||
Med | 3 | h | ||
Low | 50 | h = | 2 | days |
Lowlow | 500 | h = | 21 | days |
Approximate output | ||||
XP-G at 1400mA | 441 | lm | From CREE charts | |
Total | 1323 | lm | x3 | |
Efficiency (approximated) | 80 | % | Optical & electrical efficiency combined | |
Approximate OTF lumens | ||||
High | 1,058 | lm | ||
Med | 318 | lm | ||
Low | 21 | lm | ||
Lowlow | 2 | lm |
Just keep in mind that most drivers are very inefficient at low currents and you could assume under 50%.
i would love this in warm white… will take neutral though
Thanks for correcting me. The table is just a very rough estimate for starting a discussion..
Yes, lets keep the discussion on this light. I am keen to find out more.
It looks interesting.
I forsee me being roughly $42 less well off in the very near future. I too wish it was 3d tint or one of the hi cri bins but i guess that just means I’ll have something to do.
The qlite mode spacing on star four would suit me, but otherwise, 26650, nw xp-g2, its ticking boxes for me that’s for sure.
I bought the DQG 18650 XM-L2 and ended up selling it. The only cells I could fit in it were Trustfire flame 18650’s and I don’t have enough trust in those cells to keep them that near my twig and 2 berries. It wasn’t a bad light, but it just felt cheap to me. I imagine this will suffer the same fate. CNQG has shown they can make a great light with the BTU Shocker, but sadly, I think my desire for cheaply constructed lights has shrunk as my interest in this hobby has grown.
i want try a triple XP-G2!…where can i buy this flashlight?
I like the look of this, but the 18650 Tiny hasn’t inspired me tbh. I still fail to understand how someone can design and build a flashlight that is too small for it’s intended batteries
A mm wider and 3mm longer would not have affected it’s physical size but would have solved these issues.
With regard to my own experience, I did pre order a Titanium 18650 Tiny.
It looks great, but needed a fair bit of work to it to make it work at all, I had to sand the end of the body tube flat and finish it off, fit O-rings, reassemble the optic and it still didn’t work as it should with High being very difficult to activate, would take about 10 attempts to get it to select this mode.
Rick did offer a new LED/driver module and I also paid for one of his recommended non protected 18650’s. Sadly these bits never turned up.
After a bit of chasing Ric did offer to send me a brand new 18650 Tiny flashlight free of charge. I salute Ric for this and this kind of customer service is the only reason I’d purchase from them again.
The replacement 18650 Tiny was black not a titanium though. It worked much better out of the box, but also seems less bright on high than the first one. And I’m sad to report, despite EDC’ing it, this one now flickers and is a bit of a PITA to use. One handed operation is not really possible and when using high after about 30 secs on time it’ll flicker and often change modes, this means you have to tighten the head even further with two hands to stop this, but this then makes it very tight to then turn off.
Visually the light looks brilliant, but when I compare the overall quality to my EagleTac D25LC2, I’m sad to say the DQG is a looong way behind
Hoping this 26650 one is a superior product as I’ll likely take a punt on it
Counter-point: I ordered, and received two of the original 18650s (one black and one TI/gold, and one NW and one CW). The only thing that I had to do with them was move the O-ring, per the info that RIC provided early-on, and they worked fine, once I figured out where to put the O-ring :).
Even though I didn’t have major problems, I did take advantage of RIC’s post-sale offer for the 18650s and got 2 of them. If you didn’t receive the batteries, you should probably email or PM him (they don’t come with tracking if I recall).
I didn’t enounter any problems with battery sizes, though most of the batteries I have are unprotected batteries, including some 17670s from laptop pulls.
