I have used gas and it works pretty well. I agree. Iâm trying the DS as an experiment. I wonât belabor the point but this stuff was formulated to do exactly what we want a solvent to do for de-doming: quickly and completely remove cured silicone without otherwise damaging the substrate. It even washes off with water when itâs done.
I was going to post results afterwards but folks seem resistant to something new, so anywayâŠ
I don't think anybody here is resistant to anything just because it's new. Personally I'm resistant to things that don't work as well or aren't as convenient. If this DS were available at every corner store in the world and cheaper than gasoline I'd be all over it.
Say someone proposed switching all road vehicles over to square wheels, and had proof that they work just as well as round wheels as long as you cut all the roads with the appropriate washboard pattern so the ride is as smooth as with current-tech tires, and maybe they even give better traction as long as the wheels & road surface stay in phase. Better road-holding, fewer traffic fatalities. That would be something new, right? Would it be silly to point out the shortcomings of square wheels?
Well, I am curious about anything new, useful and not so usefull the like, so I'd be glad if you try out the silicone solvant and post about the results :-) (I'd also like reading that post about experiences with square wheels and zigzagged highways ;-) )
Please, let us know the results!! This is exactly part of what BLF is about - experimentation, R&D to find better solutions. At the time, I thought gas was the best easiest way, that's why I started this thread, but records are made to be broken.
Iâve decided to try dedoming one more time after one unsuccessful attempt. Took the pill out of a Defiant 2AA and hung it upside down in a tiny container of gas (actually, the cap to the gas can). That was 14 hours ago, better go check on itâŠit might have evaporated!
It's been posted LED's have been left for several days in gas with no known side effects, so should be fine. I try to do 2 - 2.5 hours, but frequently let is soak overnight, sometimes to the next evening, so 24 hrs has been no problem with me.
Just checkedâŠmost of the dome came off with some residual leftâŠbut the gas had evaporated who knows how long ago. Put some more gas in there to soak off the leftovers.
And thanks, mfrey, that DS-2025 looks like it was made for dedoming. Let us know what happens!
Well the Defiant 2AA light was a semi-successful dedome. It came off but the light it puts out in VERY blue. However, it still works!
Buoyed by the sweet scent of near-accomplishment (and LOTS of gasoline smell) I decided to dedome my S5 Convoy w/XML U2 1B emitter. After slicing into the dome then soaking in gas for 4 hours the dome fell off with just a touch from my fingernail. Next it went into a bath of rubbing alcohol for a while with some swishing around mixed in there for good measure. Then it hung by a ziptie to dry for an hour or so. Before pushing it back into the pill I put some Fujik-like white stuff behind the boardâŠprobably way too much, it came out around the edge and made a bit of a mess!
Anyway, after reassembly the darned thing WORKed! The beam was much warmer in color and narrower, with a tiny bit of a donut shape to the hotspot. Upon âtestingâ, which involved visually comparing it to another S5 that has the same 2.8A driver and an XML2 U2 1B in it, it doesnât seem to throw any farther and puts out noticeably less lumens.
Any ideas on how to improve it from here? I assume the presence of the donut means the focus is a bit offâŠhow should I attempt to rectify this? It has a SMO reflector in it. Iâm a little disappointed that it didnât do much for the throw, I knew it would lose some lumens and warm the beam tint up a bit. I tried spacing the emitter back a little and it didnât seem to help.
Thanks to Tom E. and everyone else who has posted their results here!
Thanks for the reply Tom. I figured it must be the loss of the phosphor on the one that went blue. I have no idea what kind of emitter is in those 2AA DefiantsâŠ.XB-D maybe?
Yes, the center was a little darker than the rest of the hotspot on the other one. How in the heck do you get the emitter farther in the reflector?
Does the S5 reflector have that lip around the base? If so that will bottom out against the pill and thinner insulators won't actually change the focus any. Trim that lip off and it'll start responding to different thickness spacers.
LOL, I use tin snips. Cuts much easier than you'd think. Needs only very little cleanup with a file afterwards to knock off the sharp edge, the whole thing doesn't have to be filed down perfectly smooth.
I tried to dedome a dead xm-l in gas for about 16h, but it failed. I hanged the star sideways in the glass, i thought the dome will slip off by the gravity. It actually worked, but a lot of silicone remained near the wires. I tried to remove, but i broke the wires.
Is there a way to trick out that situation? Dissolve the silicone, or anything? Because i think if i do the same thing again it will also broke, and it is a bit pricey to waste the xm-ls to me.
Oh boy - I got a ton of XML T6's laying around, all from upgrade mods. I always do it on a dis-connected board though, never wired. I use a toothpick now with a 20x lighted magnifier to clean up the silicone, but I won't try for 100% around the wires. You have to use something soft with a magnifier, even then, I don't take the risk getting too close to the wires. Very important though to have good visibility.
