In stock form, 6A vs 4A at least (not calculating the losses) is quite the difference. Since nobody is going to buy it for the looks, they will mod it to 100W, that’s double the power and consequently double the current. 2 batteries won’t cut it anyways.
Flo, that is an interesting one. Not super long, but still a huge light. Gotta wonder about the heatsinking internals, will it be better than the AK90? I’m still wondering that about the J20 as well.
I will be getting this light next. I do have an extra hyperboost driver just sitting on my shelf! Im kinda wondering how fast I can get it from kaidomain though.
yup, this j20 and the kd shorty has been on my mind as of late.
so happy and looking foward to what you have to say about the kd shorty hyprmtr….in stock form and beast driver mode
Overall, the TR-J20 is the heaviest and best built of them all. Extremely thick aluminum. I am disappointed with the output considering the thermal dissipation this host must offer.
Let me know if you have any specific questions I can answer.
Nice light LEDMatt, I’m very tempted. I’d love to hear the answers to the questions asked above plus: did you use 32650s for the test or 26650s? Looks like the head diameter is getting closer to the shocker than the x100! How heavy is it? It almost looks like I’d have to be doing curls constantly on my 1-2hr hikes if I took that
The TR-j20 has two banks of six leds are driven at about 18V. So with about 7amps split between two banks you get, after losses, about 3 amps per led. Don’t know if I would want to try for any more, but It’s quite bright, sorry I don’t have beam shots, I’m too busy now, will take some in future. Good Luck, please post your results.
It’s simple, but not THAT simple.
R12 is the missing resistor in a 4 resistor parallel circuit.
When I measured the circuit (without R12) I got about .50 ohms.
When I used the 26650’s I too got about 3.4 amps tail cap current.
So the .47 ohm resistor just about cuts the circuit resistance in half.
(it’s pretty hard to accurately measure less than 1 ohm, your meter’s leads are about .10 ohm.)
See this for formula to calculate the circuits NEW R value:
This allows about twice the current to flow.
When I changed the batteries to 32650’s, I now get about 7.4 amps at the tail cap.
I wouldn’t try for much more current that that. I’m not sure the other components will survive.
I didn’t need a LUX meter to see how much brighter it was now than stock, it turns night into day, on my street.
I did notice that the massive head and cooling fins dissipate heat extremely well, very little heating effect.
It’s not made to put on your keychain, but If you want to build inside the pill, there is plenty of room.
I havn’t done any long runs and runtime testing, I have to travel and will not be back for a week.
If you can do measurements - that would be interesting. Good luck.
Unfornately it is not that simple. You measure the amps at 3*4.2=12.6V withouth the sag. but it is converted to 18V and lower amps. You draw about 92W at the tail. without losses you divide this to 12 leds and get about 7.6W per led.Include some losses at the driver, say 10-15%, you get about 2/3rds of 10W. about 2 A per led.
A conservative mod with a noticeable change. I may go for more after some 32650s come in.
Coincidentally enough, I found a .47 Ohm resister on another junk board in the basement! I do have concerns with PCB heat and what would happen in low cell voltage conditions; however, I saw some other great ideas on the forum about cutting out heatsinks for the fets.
At least now it’s in more of an expected range given the size of this monster. Pleased with the results.
Thanks again for the clear instruction, A number 1. Hopefully I can find a resister value to boost it to 50% brightness / current intake.
