Mine arrived just right now. Sadly I have just loaded all devices to 100%…
But it seems to work, soldering is okay, the shunt is soldered in a bit angled but I see there no problem.
Neat little device.
Neat little device.
Werner, what do you wanted to say with “Sadly I have just loaded all devices to 100%…”??
I think he is saying he cannot test any chargers just now.
Among other things, I plan to use it to test / check the output on some small solar panels.
I'm interested to see just how big an efficiency drop I get with changing alignment and levels of light.
I think, all his batteries are charged up to 4,2V and he hasn't any other at the moment. Now he has to use a flashlight to get a battery, which must be charged again. The sun will be down here in Germany in maybe an hour :)
It’s handy to measure current draw from USB power sources without having to make something from spare parts and DMM.
[quote=Chloe]
Well these things can vary but I got mine from Ebay seller estore2009.
[/quote=Chloe]
I ordered one from there too - arrived this morning, which is pretty quick considering non-tracked China(?) Post. Neat little tool - thanks for the link Chloe.
Been waiting 33 days for mine, contacted the seller yesterday, he said wait a bit longer , I’ll be claiming when it gets to 40 days.
Things seem to be getting to me quicker by China Post lately. How is yours? Does it look like the same revision or more like HKJ’s example?
I haven’t taken it out of the plastic casing, but it looks similar to your picture. It says “CHARGER Doctor” and “3.5V- 7.0V, 0A-3A” on front. Reads 5.06v from my laptop. Only took 11 days to get here - pretty good.
[quote=Woody]
Well these things can vary but I got mine from Ebay seller “estore2009”:http://stores.ebay.com/estore2099.
[/quote=Chloe]
I just ordered. How long did it takes your tester to arrive from this seller?
Mine was ordered 29th August; sent next day, arrived in UK 10th September.
Thanks Woody. Two weeks sounds good to me. Hopefully I'm as lucky.
UPDATE: An hour and ten minutes have passed and it's now marked as shipped.
Mine arrived a couple of days ago.
Unfortunately I didn't realise the display only shows 2 decimal places. Not a problem for most users I imagine, but not quite what I need to check the output from my small solar panels in less than full sun!
Does anyone know of one of these that resolves down to 1mA?
Mind you it has been very interesting comparing actual output of various plug packs and battery boxes against their labelled ratings. Seems there is a whole system of "Chinese mA" I wasn't aware of previously!
You could use this and check more easily with your multimeter. I'd put type A connectors on both ends though.
https://www.tindie.com/products/FriedCircuits/usb-tester/
Thanks leaftye
A little more DIY than the current one but could be workable if I can't find a self-contained all-in-one unit.
Bookmarked!
But you will probably loose more voltage on this one. The "Doctor" has a 0.05ohm resistor to measure the current across, with wiring to the DMM and the resistance in the DMM, you can very easily get above that.
The voltage drop is not really interesting, as long as you are only measuring a few milliampere, but if you use the same setup to measure 500mA or more it will affect the result.
I ordered mine off eBay on 8/15, and got it yesterday. Seller was onzway2010, and cost $2.83 shipped. I have a bunch of multimeters, but this is cheap small and easy.
The main reason I got mine was to check the cheap USB chargers that say they put out higher current. We all know how accurate the specifications are for cheap Chinese products. I have a few to test, one of them is this one:
http://dx.com/p/215107
So far I tested my OEM Galaxy S4 AC charger, I got 1.3 amps. I also tested the S4 on my computer’s USB port, and it’s at 0.32 amps.
I also tested my mouse that has some lights on it. With all of them off it uses 0.04A, and with all of them on, 0.11A.
I do wish it had 3 significant digits, but 10ma resolution will be good enough for the price I paid. I also wish it had a button to switch between V and A. Most of the time I only want amps.
I ordered mine to test out solar chargers. I'll be reviewing one soon, and it'd be nice to have an easy way to determine the output.
As long as you test in bright sunshine you will probably be OK.
The past couple of days here (since I got my parcel) as luck would have it has been mostly overcast.
I thought solar panels were supposed to generate close to their rated voltage even in poor conditions, but giving very low currents. Now I'm not so sure if this is correct.
These meters only read from 3V upwards and when testing on some of my small panels with 5V USB output, I couldn't seem to get any display at all. Perhaps it depends on the load I apply.
Also, quick heads-up - the display is very, very dim when trying to view it outdoors. You might need to use an extension cable and put the meter in box of some kind or shroud it in your palm in order to be able to read it.
