i gave up buying from them
i like. big light with big head and with a side switch.
this is on my radar for now.
First impressions:
- 1.0A at tailcap (other modes 0.5A, 0.15A, strobe, sos)
- Next mode memory
- Fast, almost unnoticeable PWM
- 540lm (OTF, after 30s)
- 34kcd (= 370m) throw
- Aluminum reflector, dimensions 53x46mm (OD 58mm, lens 58x1.9mm)
- 22mm press fit driver (was not properly seated, causing flickering & higher modes not working - pressing it properly in helped)
=> Looks like a decent mod host.
Here are some photos of the most interesting part of the light:
Thanks for the information the
The pill looks like having very limited room for driver, might not be able to fit the IOS driver inside.
Do you mind taking pictures of the reflector base?
Thanks _the_! Yeah, what is the depth in the driver area? How's the overall quality?
-Garry
-Garry
+1 Wondering about the same, and thanks for sharing first impressions.
BTW, who is going to see how far that stock driver can be pushed?? J)
Thanks for posting those pics - the pill looks rather nice. Hope mine gets here soon.
Overall quality matches the TR-J12. Not great, but totally ok for normal usage.
I'll try to take the requested measurements & photos later today (still busy at work).
About 12.5mm x 21mm + 1.5mm x 22mm => 14mm total
Some bonus pics of the reflector:
the lck led 5a 3 mode driver will fit in there……just an fyi, it can probably be resistor modded for more output if you wish too, the toroid is ’kin huge compared to the 3a version.
edit, dunno about the lectronic switch though lol
What "lectronic switch"? Does that driver use an "lectronic switch"?
-Garry
No electronic switch…tail clicky.
double dumbass only got as far as poks photo when scrolling back lol.
so yeah, that 5a driver would be great, dedomed xp-g2 on copper or xm-l2 u2 dedomed on copper and its gotta hit at least 200kcd
the lck led 5a 3 mode driver will fit in there…just an fyi, it can probably be resistor modded for more output if you wish too, the toroid is 'kin huge compared to the 3a version.
I have not been able to make it do more than 5,2A best. My testing have been limited though. I went back to stock, 5A. Unless someones makes it do 5,5A+ then Ill consider 5A the limit..
LCK-LED (/intl-outdoor/lightmalls) driver is the default "backup driver" for small pills... Ideally, Id like to use a driver that can do higher current in this light..
good to know, it is just a modded ld-29 at the end of the day, it must have limits. I’d not seen any testing reported though, guess you were keeping it under your hat.
so what 6a drivers do we have available?
Well, I don't write about everything I do. And its not that many weeks since I did it.. Most people does not have much interest for minor details. I have tried to share various small stuff in my flashlight collection thread. But little response/interest/questions.
High current drivers for single XM-L thread.
Btw, I have done beamshots of various throwers and lights, some at 5amps..
Edit: I skipped the word "don't.... First sentence now fixed "I don't write about everything I do" :p
fyi.. The LCK-LED and the IOS driver are the same driver, just different resistor values. That driver is easily resistor mod-able. Also, the FT $8 (FT-2-3-lithium-5-mode-3a-led) one is also the same driver, just a different inductor - I resistor mod'ed that one.
Racer86 - good info. I work with EE's, one guy who has worked on LED designs before. Basically the circuit design and components is based on the max amps spec to a degree, so you could have been seeing a brick wall there for this design with the 5.2A limit. Of course your test may depend on the voltages in and out, ie 2-3 cells, 1-3 LED's, etc. Using the TI website tool to design your circuit, if he puts in 6A as output, the parts get rather huge, too big for driver sizes we need - it was interesting, but of course that auto circuit generation is based on everything being within spec I'm sure, while we tend to go over a bit beyond the limits .
Thanks the for the pictures. Good to know that the base of the reflector has step.
The driver in this light looks to be the same as in the uniquefire UF-X6S, and its several siblings.
Here is a close up:
I never tried to mod it. It gave it away in a giveaway.. These days I always see what can be done with stock drivers before changing them.
So, we have two (sense?) resistors. R200 and R270. Im guessing they are in parallel. Adding more resistors will probably equal higher current. :) ^^
(if not poof, sorry Garry, I did warn you on the 3-18V driver 0:) )
We also have 2 of those brown thingies (aka capacitators). Putting a low value resistor on top of one of those normally fixes next mode memory. (330K or lower will probably do) Anyone know which one??
I also see a resistor/bridge marked "0". Could it possibly be like some various others drivers and transform the light into a 3 mode if its not there/bridged?
