I had set plans for all my multi-emitters. This thread has me looking at them in a totally new light. I've decided to scratch those plans and think about what I really want those lights to do.
[/quote]
Im glad to hear that and I look forward forward to hear what you come up with and how you like them. :)
Lets compare the two SRK with mixed emitters vs a few other NW emitters.
-On the top, representing the green-ish tint. De-domed XM-L2. Supposedly U2 1A. But I got this from KD. Im guessing it was T6 1C, if not a B.
-XM-L2 3B from FT
-XM-L2 4C from FT
-XM-L2 3A from intl-outdoor
-Info on the lights with mixed emitters in OP.
Looking away from that my 3A and 3B looks extremely similar to each other. I think its quite obvious that the emitter mixing worked its charm! Even when being 30cm from a white wall, there is not much signs of the various colors in the lights with mixed emitters. The XM-L light used to have a fairly green-ish hue. A bit like the de-domed XM-L2. Look at in now! :)
Too much greenish/yellowish tint. No problem neutralize the hue by adding an emitter with more red tones. :)
So, what do you guys and gals think? I know, photos are not the best way of comparing various tints, but I think this shows the differences in the various colors fairly good.
Very nice comparative beam shot photo. Was all that taken in one shot?
The tint improvement is impressive and consistant with my mixes as far as how the whole beam's tint is changed. When I aim a SRK type light at a wall, I get 3 faint clovers on the outside of the beam. Those are generally to tint of the nearest emitter. I don't see those in your photo. It may be the way the lights are oriented. I think I see some thing that may be clovers on both sides of the 3A beam. Since the light are aimed away, the other clovers would be way to dispersed and faint to see in the photo. Is that what is happening here?
Yes, all lights on at the same time and taken in one shot. All pointed at a proper white cinema screen.
The angle and and especially the slight overlapping with the other beams is minimizing the "clover" effect on the SRK/M6. Outer edge of the spill does not look that round and nice when pointed straight on a wall.
btw, the tint of a specific emitter is seen on the opposite of where it is placed in the reflector. In real life use im not able to spot it..
You're right. I misspoke. The lowest point for light to spill out is either the short walls in the center of the reflector or the distant walls on the far side of the reflector (No sure which one ends up actually cutting off the outside of the clover spill). So clover spill is on the opposite side of the emitter placement.
Interesting, and nice work for the picture! I can see the difference in color around the edge of the mixed emitters, but if you are outside/moving and not shining on a white wall I dont think you’d be able to tell much. Is the greenish dedomed XML2 that green in real life? I have a mixed multi-emitter with dedomed T6 and its more “neutral” definitely not green…do dedomed XML2s come out “green” typically? I’d heard dedomed color isnt really different depending on which color emitter you start with to dedome (CW, NW, WW), but this seems to say otherwise unless XML2s go “green” or the color is “off” in the picture…
I’ve actually found I like to vary color tones now, I get tired of CW and its too reflective bright in some circumstances, but after using a NW on the yellowish side I really liked that tint, and then started using a warm white and really loved using that for a while, ran out of power in my warm white and found I like CW again more…its interesting, I seem to get “bored” of one color tint, but I’m really liking warm white’s reduction in night vision recovery time.
I’ve been experimenting with this on my bike, of all things, with two S5 Convoys. One has a 1B and the other has a 5C1 emitter. As I change relative settings I can mix the colors together in different intensities. Kinda cool, or warm, or anywhere in between.
De-domed CW emitters that leans towards the green/yellow side of CW emitters, like 1B and 1C will get much more of a green/yellow tint after de-doming than the ones with more red tint. I have not noticed any difference between XM-L and XM-L2. It depends on the tint you start with.
Yes, the outcome after de-doming will depend on what you start with. Normally you can subtract about 1300-2200 Kelvin, and add more green/yellow, atleast when de-doming CW/NW. If you are de-doming WW you will end up with very WW. So yes, there is a large difference between all the various emitters. Generally, you would like to add red tones, like I have done with my two lights in this thread. That fixes the tint and makes it more white.
In real life, the eyes adapts to colors, to some extent. So if you walk around in the nature with a de-domed CW XM-L, it will not look that bad, because it renders trees and everything fairly green. And green nature doesn't look that bad. :p
If you're eyes are adapted to nice NW light with a dose of red in it, then the de-domed CW XM-L (especially 1C and 1D) will easily look as green as above. Then it looks like :Sp
I have seen worse green than the above too. When looking at the picture, most colors are more visible. But it nicely portrays the green-ish tint compared to the others, which have more white light.
I prefer to start with 1A or 1D before de-doming. But even then, its far from great.. Which is why i "fixed" the tint by adding a more red emitter.
Im a bit like you when it comes to tint. I need change... Which is why I have a lot to choose from...
BTW, the two lights in this thread are in a large beamshot comparison with other lights here.
I kinda started like that. Most times I bring two lights with me for comparison, sometimes 3 or 4. I often try a bit of mixing. If I only bring two lights, and use a bit both of them a bit, I usually prefer the combination of them.. :p
The dedomed T6s I have went yellowish, maybe a bit of brown. Have you dedomed a warm white, like say T4-7C and if so what did you get?
And no green in nature is not bad, but when you are hiking in the green forest at night, adding green to the green is probably going to be an overabundance of green…which is why I didnt really like the idea previously. Its probably kind of neat to have in a city like setting.
[/quote]
Yes I have dedomed XM-L T4 7C. Result was warmer than XM-L2 8B4. It would probably be a "9" tint.. :p Certainly no green or yellow tint in that range. It was just very warm. :p
If you walk around with an 7 or "8 tinted" light for some time, then turn on a "5 tinted" light. It will easily look more like white NW without any hint of warmth at all. If you put on a "3" tint it can even look look like CW. Eyes adapt... If you are used to various CW tints, then a "5" will look warm in comparison. But it will not look warm compared to a proper warm, and it its not warm by definition. When I say definition, im thinking about Cree datasheets.
No, it shows the differences fairly well Actually, I’m wrong! It shows the differences…
EXTREMELY
ELOQUENTLY
BRILL… no, no puns here.
It makes my eyeballs chuckle like a ferret with a grocery bag.
I for one would LOVE to have been able to look at, say, take your idea to the proverbial nth degree and put one of approximately each Chromaticity Bin at exactly X cm from a “Reference White” wall & shoot it with ABC camera settings, then put it out as a grid. How easy would it be to “point and shoot” instead of having to imagine the coordinates of some Cx / Cy grid? “Do I want a 3C or a 3B and how exactly am I supposed to know?” More importantly “Can I stand the weird color rings of this or that bin?” Cree should really hire you to do this…
Its probably because I wasn't clear when saying adding red. My fault.. Im talking about adding more pink/rosy/red tint.. Not warm emitters.
See this picture.
Left side= cool
Middle= neutral
right side= warm
Now, lets stay in the middle, inside the NW range. A 3S will be yellow, probably even greenish. Its in the NW range, above the black line.
A 4R will be more rosy in the tint (its got more red in it). Its still in the NW range, but below the black line. Where more of the pink/rosy tones are. (I have a tendency to just say red)
Mix a 3S and a 4R and you end up with with pretty nice and white NW light..
In terms of temperature. Mix a CW and a WW and you get NW.
In terms of color. Mix an emitter with yellow or greenish tint with an emitter emitter with more rosy tint (I normally say red,sorry) and you get more white light. That black line in the middle represent the whitest light you get in the CW, NW, and WW range.
Makes sense?
If you don't think the colors of the picture above matches the real life that well, well, don't take it too seriously.
This picture shows things in a different and more colorful way.
See that little black line in the middle "black body locus". It stretches from blue to orange. CW-WW. Like the black line I put in the picture above. If you have too much green/yellow, which is on top of the black line. Add some pink/red which is on the bottom. Then you "neutralize".
Its quite simple. If you have to much of a color. Add the opposite.
Oh I was just thinking that possibly the 8D4 dedomed would get you more into the orangy red, but maybe 4R is better for “red”. I am not familiar with how they actually look.
Ill try to make a more visual example. Rough example of the theory. Which also works quite good in real life.
BLUE: Represents a typical CW emitter.
Then, it got dedomed, became warmer (not warm, just NW looking in terms of temperature). But it also got a more yellowgreen looking tint.. Say, somewhere in the greenish circle.
You want to get rid of that tint, but maybe stick to roughly the same temperature range (Kelvin). You take a more rosy looking emitter and combine it with a more greenyellow looking emitter.
BOOM. Combined they end up in the white circle. Fairly white NW light appears.. Green/yellow-ish tint gone..
