Group Buy: TERMINATED by Niwalker
When I dedome a MTG2 the tint gets warmer.
I'm guessing the LED doesn't end up looking like this when you do it?
not at all :slight_smile:
Here’s the post/thread…
Good :D
Oh I remember it well. It was one of my crowning "Oh crap, what did I do!" moments :o
This is all generalities. "where needed", so on this Niwalker model is it needed? What's being directly copper bonded? Are you re-using the stock emitter by removing it and reflowing it back on or are you reflowing on a replacement emitter? What exactly is the new thermal adhesive? If not AS5, something newer? On this Niwalker, are you replacing the springs? Do you do all these steps conditional from piece to piece, or by model, or both?
I don't mean to be a PIA (but I am I know), but that's what I'm confused about. Please, dont take this the wrong way - I know what your end product is, and they come out fantastic, well worth the troubles, and you keep a high level of quality while turning out some huge numbers.
I’m sure it’s a trade secret. :smiley:
But I’m with you, more info the better. :wink:
While I don't know exactly what he does, I can say with certainly... it works.
I ended up with two TK75's and sent the worse of the two off to Vinh to mod.
After getting it back, I ended up having to send the other one too. The modded light beat out the stock one by a very clear easy to see margin, it wasn't even close.
If I had to say, I'd guess it was a ~30% improvement over the stock light, which is no slouch to begin with.
To keep it short and simple. It’s a trade secret. I offer full customer satisfaction guaranteed. If you do not feel the mod was worth the money I will gladly offer a refund, and if you want I can also restore the modded light back to factory specs. I will cover all shipping charges. Thanks all!
I’ve just read both of selfbuilts reviews on this one, the pre shipping and final shipped versions. While he does not measure the reflector, he does clearly state that the diameter of the bezel is 80mm. The diameter of the S2200 is 81mm. He estimates the reflector as “the deepest I’ve ever seen” and compares a couple of lights, but not the direct competition.
It has been said that under a high load, the Vf on the MT-G2 climbs quite high. With a Vf of nearing 7V when the output is pushed, 2 cells sag appreciably in the first few minutes of operation. Quite possibly even below the Vf of the demanding emitter. This makes the 2P2S battery configuration a questionable venture. The Vostro will be highly capable of extreme output, dropping fairly quickly after the first few minutes of use. This means that very high quality cells will be a must with this light. Samsung INR18650 20R cells would do well here. Hopefully they can be had, with the shipping situation going on overseas at the moment. Flame type cells would probably be best avoided. Panasonic NCR18650PD cells will also be a good choice but I’ve measured AW 2600mA cells taking a hit with this emitter and not delivering the amperage we’re all looking for.
Yes, I’ve built a K3 head to take 2 cells at over 6A using a Q-Lite driver. I also ran it at over 8A in direct drive. This was done on a very large copper heatsink. The Samsung cells were the top performers, surprisingly enough Efest V1 IMR18650 cells were the next best delivery with their V2 version following fairly closely. The protected AW’s were last in the cells I tested.
So what I’m saying is, if you’re going to bump performance of the Vostro using the MT-G2 I strongly recommend using the best cell you can find, and that is arguably the 20R.
Essentially, the Vostro is running 2 cells with a nominal 8.4V to supply the greedy emitter. The S2200 is running 3 cells in series, easily handling the hunger of this emitter. Two different approaches, both handled by the right battery. Either is an excellent choice, and I’m sure Vinh will push this one to the maximum of it’s capabilities.
Have fun, and remember….Pics or it didn’t happen!
That's an MTG2 LED in your profile picture isn't it?
I ordered 40 of the Samsung INR18650 20R earlier today. I tossed in a few other odds and ends as it seems mixed orders “might” have a better chance at going though. We will see. I order 2 batches of NCR18650 late last week and they are not moving so far…
My experience with Vinh has been superb as well. During his mod my M2S he encountered a problem offered to reimburse my cost of the light or build me custom driver at no additional charge.
I think the questions are a good thing and not meant to say anything about the quality of Vinh’s work. Modding is a learning experience with each new light and the more data that is shared and scrutinized by the community only furthers the hobby.
in my avatar the MT-G2 is in direct drive at over 3000 lumens. Picture taken through a #11 Gold Filter Plate intended for a welders mask. That’s why it appears green. Pretty much looks like the sun does, when seen through this filter. Shot with Canon 5D MkII and 100mm Macro f/2.8L Hybrid IS on a tripod with Really Right Stuff slide focus rail.
Vinh you want me to contact my work and have them switch my direct deposit to yoir account? Might make things easier in the future :wink:
Cellguy, just to make sure im clear; if you get 10 buyers in two days, the GB will still run until 9/30 no matter what (unless there isnt enough buyers at the end). Just want to make sure I can plan this out right and get the $ in time.
PP will probably accuse him of money laundering soon enough.
10 is the minimum threshold, not the max. There is no order limit/cap at this time. I cannot offer the sale price without at least 10 sales to make the incoming shipping reasonable enough.
Yhpm and thanks for GB.
LOL :slight_smile:
I can write more about the mod details of these lights once I get going on them. For now my descriptions are the best I can offer.
