Hope to ses Convoy L2 in the best future.
+1
Looks awesome also.
I have to say the L4 is a must have light! Impeccable quality and performance. Super stuff!
^^^ +1 Looks awesome also.
We've been looking into these, the problem has been the battery tube tolerance differences and poor sales across the lineup in general.
New batteries listed!
Panasonic NCR 18650PF 2900 mAh High Discharge Flat Top (Made in Japan)
Free battery case when ordering in pairs.
Specifications:
Minimum Capacity: 2750mAh (0.54A discharge at 20°C)
Typical Capacity: 2900mAh (0.54A discharge at 20°C)
Nominal Voltage: 3.6V
Discharge End Voltage: 2.5V
Standard Charging Current: 1.35A
Charging Voltage: 4.20+-0.03V
Standard Charging Time: 4.0 hours
Max. Continuous Discharging Current: 10A
Internal Resistance: less than 35 milli-ohms
Weight: less than 47.0g
are those the new version of the PDs?
Specifications:
Charging Voltage: 4.20+–0.03V
are these the newer version of PDs?
!! are these the newer version of PDs?
Yes, these are the updated PDs.
Congrats…looks like the Kinoko 18650 HKJ tested did really well!
Great news, the information matches expectations from our own testing.
Mmmm.
Mmmm.
Do you have a link?
Do you have a link?
Working on the listings, should be up by tomorrow. Unfortunately the pricing on these won't be great. Our margin from Cutter is abysmal.
ohaya:Do you have a link?
Working on the listings, should be up by tomorrow. Unfortunately the pricing on these won’t be great. Our margin from Cutter is abysmal.
Hopefully the shipping won’t be $14+ :)!!
No, we don't try to profit through shipping. We try to set shipping as accurate as possible based on weight. Shipping for MT-G2s should be very similar to other mounted CREE LEDs.
Bump in case this was missed because it was posted in the middle of the night/morning :)…
MT-G2 at IS (soon, I hope) :)!!
20mm MT-G2 3000K
20mm MT-G2 4000K (Coming soon)
20mm MT-G2 5000K
are these on no dielectric stars?
CalvinIS:20mm MT-G2 3000K
20mm MT-G2 5000Kare these on no dielectric stars?
No, I do not believe these are direct thermal.
20mm MT-G2 3000K
20mm MT-G2 5000K
It would be great if the 4000K one would be the 2-step 80CRI version ( MTGBeZ-00-0000-0B0HM040H )
Any plans to get more 26650 or (dare I dream) 32650s?
