I’ve just compared mine to a $urefire P60 incan; the T4-C7 turned out to be quite close, a wee bit more yellowish (yet, a lot brighter, and the beam being a lot smoother than on the 20 years old “Laser-Products” 6P).
Thanks, i don’t own any LION battery so any non-lion flashlights are welcome, but i emailed Hank Wang and he does not have it in warm white, only NW … :_( but thank you for the suggestion, i would take it if the warm white option was available.
AND thanks guys for the replies, but i don’t care to not have an EDC, i want something that will last me at least 1h30 in high mode. i don’t think only one battery will do the job :quest:
A single 18650 have more power than 3 AA.
Not many choice and almost everything use Li-on battery right now…
The best option from your requirement would be a modded flashlight with 4x18650 for long runtime with 3 X 90+ CRI, 3000k, XM-L2 S6 made by somebody but it would not be cheap and you also have to bought the batteries and charger.
I think you can’t replace the TK70 LED because there is glue everywhere inside.
OK….so you come in asking for a warm white, then 1:30hr runtime on high, then no Li-ion flashlight….then choose a non-warm white, Li-ion that wont last 1hr 30min runtime on high and isnt a good deal. What was the point of this thread?
Well… it look warm to me and yeah i don’t own any lion battery but now I have to buy four, i don’t know the runtime for this but it use four lion battery so i thought the runtime was fine
Well first off, I think you can get the Kung (most people call the 4 emitter version of SRK the Kung) for about $35 with free shipping now. Look for the threads here about the Kung light for info on it, they are highly variable in quality too.
Next consideration, I think my SRK (3 emitters, otherwise same light) runs a little over an hr, approaching 1.5 on high, but this has 4 emitters, so if its driven even decent, not only will it last just around an hour, but you cant hold on to the light after about 15min continuous run without burning your fingers (I have a 4 emitter version, it gets finger burning hot at 12 or so mins and unholdable later).
You also can’t judge the tint by the picture because cameras change the tint etc, and warm white is typically more expensive, so it would be extremely unlikely its warm white if it doesn’t specifically say so, it would be a selling point.
The Kung gets very hot, its not “unstable” that I know of. If you want warm white there are lots of SRKs even, just do a search. They are variable in quality. Buy a black one to help deal with the heating up issue.
Yeah but the golden color is recommended at the FASTTECH website… “This golden version is recommended over the black version for better build quality and output.” maybe i’ll wait for a good warm one in the future…
That notice is quite old. I wouldn't put much stock in it. Bought 3 black ones from FT, over a long period of time, all three were fine. Still have one around somewhere.
he asked our advice and we gave it to him, he has no obligation to follow it
i would pick a different light as well if i were him starting out, but it seems he decided after doing more research he wants that one instead
well… i realize that the market for this kind of flashlight is not developed enough for my needs… I’ll just wait a few months maybe years to find the one that suits me best… but that problem would be solved if i was good at soldering, but it’s not the case.
No, he was misinformed about this light and did not bought it after-all since it was not warm, see upward.
Like someone said HID with 4300k would be a good idea and will give huge amount of light compared to LED (depending of models of-course), the problem is that the quality is random on cheap no-names but you will have a huge batttery with it and a charger so no problem on this side. HID are meant to use for long time session but turning them off every 30 seconds will reduce the bulb lifetime.
again we gave advice, and free advice is ultimately worth what you pay for it, but i think there is a lot of good advice in this thread
frankly for a first light a bit warm i would get this with some sanyo 2600 batteries and a charger https://www.fasttech.com/products/1601/10002364/1212405
with the understanding that you can’t run it on high for the whole battery life unless you want to burn your hands and wreck the battery (i think of it as a manually controlled turbo, or buy one with a lower max current)
