I believe you were unlucky, HD2010 is one of the best budget lights out there.
I own Trustfire A9 which is 26650 and might suit you. Also search for Palilight, they offer some 26650 models. Hope I helped you a bit.
Absolute best bang for the buck IMO assuming you can find someone to do a simple bore out of the switch end of the tube, is the DST.
You don’t have to chop it either of course to gain the best of a few battery configuration worlds to boot plus that big reflector gives you so many options.
Can’t say enough good things about this or a similar setup.
Since that has an integrated pill, a replacement pill would be huge and very expensive. There isn't a thermal path with the X3 is already quite good aside from a little dip in the middle. The main benefit for a new pill would be if it was redesigned to allow the use of protected 18650 & 26650's, or if it had a hole and plug to accommodate the use of a side clickie.
Oops. Wrong thread.
Yes, the X3 is a nice light. I have one. I'd buy an updated version if it accommodated protected cells, and then I'd buy a third one if it had a side clickie that still used the Qlite driver.
the x3 is minor developments away from being perfect.
I would add to the above, make the body tube 34mm id and 70mm internal length, it should then be possible to take 4aa/32650 protected cells and 26650/18650 with appropriate sleeves, side clicky would be easy to implement with a qlite but would add a little overall length, the trade offs for the above would make it just about the most awesome light available in this class.
Chinese Looomens real about 800, hey, I was impressed for the money, nice gift to yourself. I find myself actually using this torch for actual use, it is a good combo light.
I just recently ordered the Raysoon F13, plan to mod it into a useable daily use light. Have a couple of 26700’s I need to put to use, hope they fit (if not, I’ll make em)
