I would think the biggest concern in a mine would be sparks. With all that coal dust and perhaps flammable vapors. Lead-acid batteries just don’t sound that safe to me. I would think that what you would want is an integrated light and battery, perhaps hermetically sealed so that there would be no sparks. Charging would be done above ground.
Well our use is in stone mines, not coal and technically for stone mines we didn't need "certified" lamps but bought them just in case we did end up in a coal mine. Oh, and it's amazing how bright 30 lumens is underground in complete darkness!
(Sorry if I've taken this thread too far off-topic.)
This should be real easy for some, and a history lesson for others.
It used to be that getting a part like this was very hard to do and expensive. Sure you could go to Radio Shack and buy a consumer version of this part, but even then they were incredibly expensive and no where near the quality or value of these. Almost every electronics project needed them. I was always deprived of this particular type of part………until I found out how to get them - cheap. When I finally got a hold of some, I bought a whole case 24 for $5.00. I just checked eBay, they sell for upwards of $30 each today. It is little wonder that the day I got them I actually went to sleep that night with one of them under my pillow! I absolutely Cherished these. The color, size and shape and most importantly, what they could do.
Here are 2 of them next to a C8 for size. Before the company that manufactured this particular part was sold in 1978, they also manufactured DuraCell batteries!
The questions are:
What is it?
What was it called?
Where was this particular item to be used?
Bonus: Why was I able to get so many of them so cheaply? Hint: 1971
Creepy and beautiful at the same time.
For some reason, old tech stuff like that always attracted me.
@dchomak
They look like capacitors, also known as condensers to me.
With some nice screwing terminals. Maybe they were used as start/rum capacitors for some kind of motor (or generator)?
If I was in an underground cave I would rather have 30 lumens of warm high CRI light. I can understand the resistance to upgrading if you have gear that is well known (and well known flaws) vs. new stuff that needs testing and familiarising, and training others on use (health and safety).
The suspense is killing me. Someone guess this correctly now darn it.
I would guess some type of capacitor, but the sleeping with it under your pillow the first night thing is throwing me off. I can't imaging wanting to have a capacitor anywhere near my rock filled head. I wasn't playing with electronics much back then. So I have no appreciation for the shortage of this type of part.
I remember my much older sister telling me that until one goes deep down into the earth, they have NEVER seen darkness. Only then can you experience the total absence of light.
It looks like a chassis mount capacitor, the kind used in output stage of power amps. Maybe you could get them cheaply because of transistor amps becoming more popular?
Computers, interesting idea.
But What happened in 1971?
Maybe a company switched from linear regulated PSUs to SMPS, rendering their stock of big caps useless?
Could be at that time.
Oh the suspense.
Rated at 40 VDC they certainly are not for vacuum tube power supplies. Filter caps for B+ power supplies would be 470 volts or so.
I remember that in 1971 the HP hard disk drives that I worked on had big capacitors like that for emergency head retract in the event of power failure.
Back in the day, often times Amplifier manufacturers would would use huge non-polarized capacitors to protect the speakers from any DC current. Theoretically that would impact low end response. In my opinion the better designs wouldn’t need them. 2 of these in series in reverse polarity could mimic a non polarized capacitor. When that was done though, shunt resistors of the proper value had to be used. It was a kludge. My personal use was for filter capacitors in power supplies.
Aluminum electrolytic capacitors with excellent initial electrical performance, voltage combinations, high current filtering, energy storage, and good ripple capability. High performance, high capacitance and high CV rated. The were/are used for spot welding, DC/DC converters of +500W power, DC/AC AC/AC +500W converters, motor starters, flashtube ignitors, audio crossovers, frequency converters, DC links, DC buffering, UPS buffering ….
