It certainly is a part of the LED. I think the actual name for what we normally call an "LED" is an LED package.
The actual Light Emitting Diode part of the package is the die, so technically, lionheart wouldn't be wrong in asking what is the green thing that the LED is sitting on, cuz that would be another way of asking what is the green thing the die is sitting on.
But generally, I think we refer to the entire package as the "LED" and not just the die.
No problem, you’ll learn. Just keep in mind this can be a very technical hobby, like cars or guns, or like physics and chemistry, and terminology can sound similar for different components, so the correct terms are important.
When the LED are off you can see darker color when the tint goes to warmer tint (mistaken doxa,infact it is cooler).
Cool white are lemon yellow, warm white is orange because there is more phosphor on the die.
Wow, I’m learning in this thread…didn’t even know the SC52 came in a XM-L2 emitter, I thought only the brand new SC600II’s did. I guess it’d make sense for them to update their emitters across the board.
The SC52nw is xml2t6. The SC600II was xmlu3, as were the S6330 lights. The SC52 cw/regular, which came out a long while back, was also xmlu3.
All of the newer lights coming out from them now seem to be xml2, which makes sense.
Right now I'm anxiously awaiting my SC600II NW, with the xml2. Cellguy has the XMLu3 versions for sale pretty cheap. I know intellectually it's only a small bump, but I also enjoy warmer tints more.
I tried a pic with XML2 4C, 3B, 3A, & 1C, cropped out everything but the dies, and I couldn't tell them apart. If anybody wants the full size version to play with in photoshop, right click/save as--> http://75.65.123.78/Dsc06275.jpg
I think you’re right rojos, the metal trace seems to be directly under the die on the XM-L2 version, whereas it’s buried on the XM-L.
Does anyone know of the most efficient way to slice the silicone dome off while leaving a very thin layer over the phospor? Would a very sharp blade like a scalpel be best? Heated? A heated wire? Heated as in glowing red? I’d like to shave the dome off an MT-G2, but I want a clean slice one time…don’t want to hack at it.
