In a way he might be asking if the mounting holes on the light are at the center of gravity. If it's not, then vibrations may eventually cause it to point up or down. At least that's what I wanted to know.
Oh, gotcha. I can’t do that on this light, plus I think it looks like crap. Other light bar manufacturers do that. I think it will be just fine on this light. My big light is like this and it does not move. I can always rough up the back side of the bracket for more bite.
I wouldn’t have thought it a big problem, I’ve never had tilt adjustable lights move unless I happened to land on them and then their angle was the least of my worries
Nice light, I have seen rock crawlers in the past on TV but nobody around here has had one until recently. In the past 3 months I met a man that had one, a new coworker has one, and a recently past coworker’s long time boyfriend builds them full time for a living. These things must be exploding in popularity. And the cost of a good one is super expensive, like 6 figures. With people putting that kind of money in them, $190 is pocket change.
I’m wondering something about the light housing and the bar housing. Why did you choose to make the fins go around the light, both this one and the bar, across the flow of air instead of with the flow of air? Seems if the fins ran longitudinally they would be more efficient at dispersing heat.
Don’t think the bar was lathe made, had to use a mill for those. Which would also do the lengthwise groove for air to flow down instead of over. Just wondering is all.
24 emitters driven at 3A each… very well done! :bigsmile: It looks like you have quite an impressive crawler to play with. Do you have a link to a spec sheet?
WOW! That looks like a tank powered by a turbo LS1. You have amazing fab talents… and perseverance. How does it run? After playing with LSx engines over the past decade, they seem to do a lot of things really well. Is there a good chassis dyno shop in your area that specializes in LSx tune? Im due for a retune after several mods on my vette, but there’s no one in my area up to the task of getting the most out of it.
Buggy runs amazing! Mine runs on Megasquirt 3 running E85. I do all the tuning myself.
The shop I dynod at(Garage 808) can do LSx stuff. He mainly does Honda stuff though. I am sure there are shops in Portland that are good also. Maybe Horsepowerfreaks?
JESUS H CHRIST!! :bigsmile: That thing looks like a 4wd projectile clawing its way up the rock field. Your cooling fans werent even running at the end of the run. If you ever mount a forward camera to give us the drivers perspective, please post it here… that is if your bobbling head doesn’t knock it off of its mount first.
Thanks for the names. Im probably going to make the pilgrimage to Tommy Wongs in Vancouver for the tune.
