If I see something that can’t be associated with a source, I might consider it…but the pics are stamped and p-shopping to remove that would be involved, etc…PITA.
One of my ambulance driver friends used to send me pics of all the motorcycle accidents he responded to (in order to convince me to give up motorcycle riding), and he got in big doo doo for that too
Yeah, its verboten. You really never know who might see it, and if for example if by some happenstance it involved a loved one of yours, etc…its traumatic to see something like that online.
Its like doctors discussing a case in the elevator with an unbeknownst family member of the patient along for the ride…its just not fair to the parties involved…they deserve privacy.
For perspective, the vast majority of my investigations lately involve solving environmental safety and health issues, say nabbing polluters more than bank robbers, etc.
I do a TON of investigations that actually just answer why water leaked into a building and if there’s mold, how to get rid of it, etc. I started a company just to do that on a consulting basis. I now am subcontracted as a consultant on the more traditional investigative work, so I keep busy with a variety of things. A lot of skills are very cross applicable,and I’ve been involved in one way or the other since the ’70’s…
Some things add together many facets, for example, I might measure the sound deadening at shooting ranges, and/or calibrate the range lighting for night shooting practice, so we know what scopes/sights need how many lux to shoot what…so I might be out at 3 am with a bunch of people shooting a few thousand rounds down range while I measure the lux on the targets and adjust the lighting while we chat on the radios to see who can do what with what lux, etc.
Or I might be sneaking remote control monitoring stations up/downwind or stream from suspected polluters and collecting evidence over many months to find patterns of releases to the environment that a single inspection would probably miss (Already missed typically…). One plant used a large truck to screen cameras’ views of a storm drain, and once in a while, the truck would cover the hole, they’d open it, do the illegal dumping, close the hole, and drive off again. If they knew you were onsite, they simply didn’t dump…and the fencing, etc, made it impossible to see what they were doing in there otherwise….
…So I set up monitoring stations up and down stream IN the sewers, to compare the water going into the plant with water coming out, and measure/collect the water quality every few minutes….and every night I’d sneak back and recover the samples, swap in fresh batteries for the sampling pumps, etc, and sneak back out undetected (the manholes were under their security surveillance we discovered, they had Jeep Cherokees with bar lights and spot lights patrolling the areas, to report back to base if “intruders” were around, etc.)
Wow, Teej. None of my UV lights even remotely compare to that. Looks great. Thanks for posting those pictures. That totally answered what I needed to know. Thank you again.
Your work sounds interesting and challenging. With the broad spectrum of projects you work on, it sounds like you need to do research at the same time you're investigating sometimes. I'm sure it has some tedious aspects at times, but it definitely not cookie cutter type work.
The variety is what attracts me to it. Now that I’m “retired” I can do what I want to as long as there’s cash flow.
I don’t find research to be tedious, I like investigating things…and there’s always SOMETHING to be learned in the process, even if its not relevant to the original question.
That’s one direction that took me in search of newer UV lights in the first place…I saw something that my current light could not do, and wondered why…back in the 1980’s, and delved into the wavelengths, etc…and what reflected UV vs fluorescing UV was able to resolve, etc. After that, when LEDs came out, I started to be interested in that format. The electronics for example is not a long suite though, and that’s an area that I can delve into deeper, etc.
I have so much to learn, as relatively speaking, I am only familiar with HOW to use various lights, but relatively speaking know almost nothing about how they WORK electronically.
What model emitters do you use?
LED Engin seems more availble then nicha emitters.
I recall reading on LPF about some really pricey emitters you had a few years ago.
I suppose it depends upon what you are fluorescing though, as some materials simply need shorter than 385 nm UV to fluoresce. IE: They don’t at 385 and do at 365 for example.
The problem is that the emitters are much BETTER at converting the cell’s power into mW if its mW of 365 than 385 nm UV light.
I use UV tracer dyes for certain applications, and dyes that work at 365 nm by design may not work at 385, whereas most of the 385 dyes also work if 365 used used to excite them.
There are rare instances where something can work at 385 and not at 365, but, typically, its the other way around in actual use.
Some minerals will not fluoresce at 385, OR 365 nm for example, its still too long a wavelength…and they require even shorter wavelengths.
The only time 385 will work better than 365 is if 1) 385 is short enough, and 2) It just needs a higher mW exposure to make it fluoresce…and the 385 can use the same power to get a higher intensity exposure, using the easier to emit longer wavelength….than the 365 can.
In practice, the higher energy of the excitation from the 365 will compensate for that, and things will generally fluoresce better. If the targets are MADE for 385 nm, say currency, sure, 385 will work better as for the same powered light, more 385 mW can be applied, etc….IF power was the limiting factor.
And, I may want to interest you in some future projects, as while I might use my UV differently than you do, so our experiences are different, YOU understand the electrical aspects, and, I am seriously lacking in that department. I am more involved in the chemical/biological, than the electrical, end of things.
Not from what I’ve seen… you can get much more 385 nm light out of an LED than 365 nm… the shorter the wavelength, the larger the electron band-gap jump needed to produce it… and as a rule, the less efficient it will be.
The emitters, we agree, are better at longer wavelengths, IE: For the same juice, they can make more 385 than 365 nm.
The point was that some things DON’T fluoresce at 385, and will at 365 nm….so while the LIGHTS can more easily make things that do work at 385 nm light up, the potentially higher mW of 385 nm lights will not make a material that needs 365 nm fluoresce.
If bills for example are MADE to fluoresce at 385-390 nm, then you don’t NEED 365 nm to light them up, and, a stronger 385 nm, which is easier to attain, WILL work great.
For other materials, you can shine all the mW of 385 nm you want at them, and they won’t fluoresce, as they only get excited by shorter wavelengths…some shorter than the 365 nm as well, and so forth.
This was primarily in reply to the statement that 385 nm provides better fluorescence…and the context added was that that applies only if the material is fluoresced by that long a nm range, and that 385 nm will not provide better fluorescence for materials unless its mW limited instead of wavelength limited.
I just got two Solarforce UV P60s — one works fine; the other one, shortly after I put it in the Solarforce host, I dropped it (about 2 feet) and the LED came unstuck from the pill. So I’ve got to figure that out.
But — one works fine.
I went looking for a way to filter out the visible and not interfere too much with the UV output. Rosco makes theatrical filter gels that might do, but the UV would eat them up pretty fast and they lose a lot of transmission even in the UV range. But.
“… Rosco’s new Permacolor #3660 UV Pass Filter in front of a UV-rich source will do the trick perfectly.”
Those cost around $8 from photo suppliers for a 2” circular filter.
Anyone know a flashlight that takes a P60 dropin and will hold a 2” filter?
Or a flashlight that will take camera step-up lensholders from its standard head to mount a 2” filter?
I got the drop-in the other day and put it in an L2P with 2 extension tubes, running 4 18500 lap pulls in it. Very low visible light, but very strong UV. Can’t see it in a beam profile more than a few feet away, but in a dark room it will flouresce virtually anything in the room. Haven’t tried currency yet, but diamonds really show their stuff! And the emitters, yeah the MT-G2 is awesome looking at a bright reddish orange! Gotta be careful not to flash the UV back at yourself though.
How important is it to run that high a voltage? Would be much more convenient to have a smaller light, but if it needs that kind of power to really work then I’ll leave it set up as it is.
forget Newport, different technology, no doubt $uperior (sigh) but not for $400
The Rosco UV-pass filter costs $8 to $16 from a lot of photography stores.
So — does anyone make a flashlight that takes a P60 dropin, and has a 2” (50.8mm) lens/reflector diameter??
Or know of step-up rings that would put a 2” photography filter on a flashlight?
Threads. Drive. Me. Crazy.
Seems like machinists have more different kinds of threads than quiltmakers!
Just curious. I doubt it would compare to a multi-hundred-dollar dedicated UV light, but it’s nice that it’s useful for general-purpose lighting instead of just UV. Low-power red/green/blue emitters, a “3 watt” UV emitter, and the XP-G2 we’re all familiar with, in one package. I’m hoping someone will review it soon.
