Anyone owns the XinTD X3 from Wallbuys/Banggood?
Do you by any chance have the Nitecore EA4 or the Sunwayman D40A to compare it with, especially when running on AA batteries? Thanks a lot!
Sorry, too many models, brain overloaded with flashlights.
its 3AA, so it will only put out about 2A from eneloops so a lot less bright then the EA4
I have a cyclone c88 which is the same idea, (probably an older version of this light), the AA capability is a bonus but not really a feature, it can’t fully power the 105c (qlite) driver
When i first started out in high power lights i had hoped this would allow me to get a full brightness light without getting in li ion batteries but i was wrong
Yea, since you can’t get the full 3A out of eneloops I’ve modified mine with a different driver. I only run 1.4A max with AA as it should allow for a full hour of use at ~400 lumens. I bump it up to the ~3A when running with an 18650/26650. The body, however, is a few mm too short to accommodate longer protected cells so unprotected cells are needed. I really wish the body was just a few mm longer so I can use some protected 26650s in this light. Might add some shims here and there to make it work.
Build quality wise, mine was pretty decent. Anodization was flawless and nice too. It’s not shiny like my xintd c8. The steel bezel is also a very nice touch. Reflector has a defect (which seem to be a problem with these as others have posted about it before) but it doesn’t seem to show in the beam. The beam shows the donut profile 2-5 inches away from a wall which is a sign of a good focus. The build is HEFTY for this size light so heatsinking should not be an issue, especially with the one piece head design. On top of that, the board is also screwed down. My only recommendation is to get a copper board in there.
Hi, thanks for your input. So is the lens AR coated as well? Also did you notice any difference between your version with the IOS one?
Thank you!
How does it compare to the HD2010?
Gj I did not see that light on mtnelectronics? Just 3 C8’s
Just got mine from Banggood, and I'm surely impressed!!!! Especially for $35...
I mean build quality wise.. No sharp edges, and couldn't see any flaws in its anodization. Nice color as well.
It’s fast for you! I also have ordered the X3 from Banggood with $31 after discounted with coupon code, but they only shipped out at 23 December due to out of stock (it appeared to be “in stock” when I ordered). :expressionless:
Anyway if Banggood is really good then I should receive the light within the standard-14-days, which is by next week or around so.
It is beautiful, kind of a Gunmetal Gray, lubed threads, deep reflector, kind of a cheap aa battery holder, a thick plastic 18650 adapter, no 26650 adapter, but one could easily improvise one with PVC. Ok, I loaded mine with a Powerizer 26650, draws 3.2 amps at the tail. I have a LG 18650, draws about the same amps. Haven’t tried the Eneloops yet, Yes, it is very bright and a definite thrower.
I ordered 2 from banggood on dec 7 haven’t seen hide nor hair of them but they sound pretty good , can’t hardly wait
My two x3’s came in today, yea! Wow they are a gorgeous light . The only batteries I have at the moment are tenergy aa and the 3aa battery carrier is crap but it does work ok . Waiting on some 18650 but am happy to see them arrive .
Was about to order this until I seen this post. No sharp edges = No deal!
So you prefer sharp edges?
Definitely do! I got this instead so I could attack Tigers in the Jungle, or maybe crackheads too!
http://dx.com/p/godfire-x-06-cree-xr-e-q5-1-mode-250lm-attack-head-white-flashlight-black-16340-cr123a-276759
I think you mean the spiky bezel, not the sharp edges that left by poor machining.
Yes, I really don't understand people like poor machining that can even cut your skin.. that's what I meant by No sharp edges=poor machining.
Yes, I really don't understand people like poor machining that can even cut your skin.. that's what I meant by No sharp edges.. Sharp edges=poor machining.
The battery carrier from ios is far better imo :)
Yes I did actually notice that, but considering the significant price difference I ended up ordered with Banggood anyway lol.
