Still watching and hoping it goes well.
Finally got a quote back on some large quantities of AMC7135 chips. Will probably build them up with 350 mA chips (2.8A/LED)… 380 mA ones cost twice as much. Adding a single 350 mA chip would bring the current to 3A/LED
This will probably be a stupid question, not sure if the pin arrangement is the same but could ATTINY85 be substituted with attiny13A ?
Good point on the cost savings. I will still be definitely interested in buying one or two of these if you build them with those modes you planned
It uses the TINY85… code is around 6K long…
yes, and I have code/UI that I like very much burned into attiny13a (purchased and locked) …
Do you still plan on using your friends pick-and-place machine? It sounds sophisticated and flexible if it can place all those 7135’s at the necessary various angles. If youre able to do it, a vid of that baby in action while making these drivers would be cool to see.
I was thinking of using a commercial board house to assemble the boards.
Ron’s machine will be rather slow and may not be ready for a while. He is trying to do some fancy pants image recognition to align and place the parts. So far it’s looking pretty good…
If you go the commercial board house route, do you know about how much you would be selling them for?
i second the notion
i second the notion
This is sounding good. Of course this like… what- the choir preaching to the choir? How much and when?
subscribed
Ditto!
I would LOVE to get a PCB from OSH Park and get the components and build my own...or pay some money for pre-built...I have a SRK and definitely are interested.
Tell ya what...trade you a pre-built lead acid battery desulfator for one of those (got mine from OSH Park as well)
I’ve been tied up on some projects that pay real money… hope to get back on this next week. I have been doing some long term testing on the drivers in some lights. Looking good so far. I’ve had some problems finding a cheap PCB maker that can panalize round boards. Most want to cut out the individual boards… not good for having the boards built professionally. I have got my own reflow oven up and running (DIY Reflow Oven) and a friend of mine is building a pick-and-place machine. May wind up building them myself.
OSH Park (Open Source Hardware) guy makes PERFECT PCB’s for dirt cheap…
He knows that ;)
But OSHpark only gives individual boards, not whole panels.
He knows that ;)
If you order enough of em I bet they would
They only burn 3 at a minimum...why do I know...I have 3x boards for some battery desulfators inbound...for an incredibly cheap price...anywhere else would probably have been a few hundred bucks...OSH Park...$11 and change for 3 on a panel
I bought a CNQ/FF ‘real’ SRK a few months ago, but when I tried taking the driver out to upgrade wiring and check solder connection quality, I was dismayed to find out that the driver was glued down to the head extremely well. I even tried heating and drilling to try to take the driver out, to no avail. This one would be a sweet replacement if I end up wrecking my current one. I’m getting obsessive about getting that driver out!
A lot of great groundwork here. I hope it leads beyond just this driver but even if it stops here it will be worth it.
Actually, I may get two. One to go in the real SRK I bought specifically for this driver. If this driver comes out, I'll order a Supfire M6 to put it in, and I'll probably add a few more 7135's.
