It’s fast for you! I also have ordered the X3 from Banggood with $31 after discounted with coupon code, but they only shipped out at 23 December due to out of stock (it appeared to be “in stock” when I ordered).
Anyway if Banggood is really good then I should receive the light within the standard-14-days, which is by next week or around so.
It is beautiful, kind of a Gunmetal Gray, lubed threads, deep reflector, kind of a cheap aa battery holder, a thick plastic 18650 adapter, no 26650 adapter, but one could easily improvise one with PVC. Ok, I loaded mine with a Powerizer 26650, draws 3.2 amps at the tail. I have a LG 18650, draws about the same amps. Haven’t tried the Eneloops yet, Yes, it is very bright and a definite thrower.
My two x3’s came in today, yea! Wow they are a gorgeous light . The only batteries I have at the moment are tenergy aa and the 3aa battery carrier is crap but it does work ok . Waiting on some 18650 but am happy to see them arrive .
Yes, I really don't understand people like poor machining that can even cut your skin.. that's what I meant by No sharp edges.. Sharp edges=poor machining.
i guess the xintd x3 that wallbuys sells should be the same banggood sells? (hard to know, but flimsy 3AA carrier, 3/5-modes, no moonlight mode should apply to both?)
i ordered 2 from wallbuys group buy a couple of months ago (i have received one, the other one seems to be lost in china post since 17 november…)
i have tried the one i’ve received, and when i use 3x GP Recyko batteries, and use high, after a while the flashlight ramps up and down, is that a low voltage warning? it happened when the batteries where quite fresh though, and IIRC 4.02 V resting voltage over the battery carrier.
I am thinking about gifting one of the flashlights as it should be great for non li-ion people, but i’m unsure if i have a defective flashlight, or if it can’t be used on high with nimh’s?
I notice FT also sell the same one with Banggood. at least the same battery carrier.
can anybody post a little bit update after couple months usage of X3 from Banggood one?
I’ve bought X3 from BG… What would you like to know?
Quality wise…it’s excellent! Threads were a bit dry on arrival but I lubed them and modded this weekend(replaced driver for Qlite with added 4x7135 380mA and changed led to T5-5A3) and I couldn’t be happier.
Hey thanks for the update. Does the battery carrier limiting the current on eneloop?
as for the FT nanjg driver you pointed out, I have using quite a lot of it. perform like it should be although it’s not like Qlite on IOS one.
The total current draw with Nimh batteries on high is about 2.1A and this is also measured by other forum members. The AA batteries are in series so 2.1/3=0.7A current drawn from each battery. I’ve never measured the resistance of the battery carrier though but I think it won’t be an issue to limit just 0.7A current draw from each AA battery.
2.1A is drawn from each battery.
I have purchased some of these cheaper Nanjg drivers from FT too and yes they still can perform like the other 105C driver in terms of current draw. Now if you know how to re-programme these drivers using the Nlite developed by Dr.Jones then you can programme it into whatever modes you like with higher PWM frequency.
If the batteries are in series 2,1A is drawn from each battery. (if the batteries are parallell they would be delivering 0,7A, but then you would have a voltage of 1,2V instead of 3,6V…)
i did a basic test some weeks ago with my X3 from wallbuys. I used 3 quite fresh GP recyko’s and measured 4,02V resting voltage at the battery carrier. Then i used 2 DMM, one measuring current (i think it was about 2,8A on high) and one measuring voltage under load.
-It didn’t take long for the 3 batteries in series to fall to 3,2V under load.
-So i guess that’s why i have been having problems with this flashlight when running it on high with AA’s. After a while on high it starts ramping up and down, and i’ve been wondering if that’s a low voltage warning.
-Maybe recyko’s don’t keep up their voltage under load as good as they would have needed to be used in this flashlight.
i’m going to gift this flashlight, so i’m thinking about changing driver to something easier on the batteries, maybe 1400 mA could be good enough for this flashlight in the hands of a non-flashaholic using it on AA batteries.
