My suggestion in PMs was to run them all at the same 15 watts, so maybe that's coming sometime soon.
That would be interesting too. Would be a lot of hassle for Dale to do though.
I checked your spreadsheet Dale. That is a nice information!
On top of the beamshots, numbers also backs up why XP-G2s in a C8 sized reflectors (or larger) are not for me. Not much more throw but considerably less output (lumen) at similar amps. And the XM-L2 can still go way higher and gain more output compared to what the XP-G2 can gain.
Again looking forward to the rest. Keep up the good work! :beer:
But Race, it all depends on WHY you need a light in the first place. We have a lot of hunters, so I’m sure they know exactly what I’m talking about. The hunters day starts off with a very early morning trek out to the deer stand. A pinpoint of light to watch the trail, without a lot of spill to have the whole forest awake, will easily allow that trek to be minimally invasive. The XP-G2. They get a good shot, bag a deer that runs. The XM-L2 will give plenty of illumination to follow the blood trail and watch out for obstacles. Once to the fallen game, the MT-G2 will light up the scene for field dressing that beauty! Different situations call for different lights, or the same light with different outputs.
15 watts each would of course be doable, but it’s just not practical. Of all the modders threads I’ve read here, including yours Comfy, I don’t recall ever seeing anyone find Vf on an emitter, divide a projected wattage by that Vf to determine amperage to set up the driver for and figure in some losses so the actual doesn’t fall short. Who does that? 15 watts would be at the top of the XP-G2’s game at around 4.2A, while the MT-G2 would be strolling along around 2.4A. But of course, I like a challenge as much as the next guy so I might actually try to pull it off….might being key.
I’m working with the straight up easy to duplicate drivers, stack some chips like everyone does and run it on copper for better hang time. If the test isn’t real world, what good is it? I guess if you have a bench power supply and bench heat sinks to find what a particular emitter requires to make a particular wattage, that’s all well and good. I don’t. I don’t have a wealth of electrical knowledge to enable me to ferret that kind of thing out, I DO have the desire to see amazing output, and like bumping a driver for all it’s worth to get there.
Race, an XP-G2, 1A tint, de-domed, in a big reflector, easily out throws an XM-L2 driven harder. All the light is going into the hot spot, or the vast majority of it, such that 600 lumens outdoes 1000 as far as the eye is concerned. Got a build coming up where I’ll do just that in a copper pill for an HD2010 at probably 4.5A or better. We’ll see how that looks. Some have said that it’s easier to see out to where the hot spot is, without all the spill contracting your pupils. Makes sense in a way, but you’re still looking at the light, so they’ll still be contracted as far as I can tell.
Like with most everything else in life, compromise is the key word. There is no all-encompassing answer.
I can't believe I missed this thread! Great work and I look forward to seeing the future updates!
Looking for the opportunity and a new place for comparative beamshots. Since there will be another round, or two, it’ll need to be easy access and easily duplicated. I’m tired of the red oil drum and white barn. Even if those are easy shots taken from just outside the front door. lol Been seeing those views most of my life, ready for some scenery changes.
What works for this? A hiking trail? Parking garage? Under the bleachers at a large (semi) football stadium? What real world setting would best show the differences in these 3 lights?
I was hoping for some feedback, we’ve got too many lurkers….458 reads and about 10 people actually have something to say. Tough crowd! Perhaps I need to figure out how to do a poll, maybe that would direct me to my beam shot battleground…
Dale, you dont need to come up with a story about hunters when I just said why a certain light/emitter combo is not for me. I have seen those combos myself in real life. I did not have the numbers to confirm what I saw, nor do I have beamshots out of many of the lights Ive modded. Which is why its interesting to see a good comparison like this. But personally I was not impressed with the XP-G2 compared to the XM-L2 (and I tried several different C8 reflectors and several different larger lights).
Your numbers shows:
The XP-G2 have about 6% more throw compared to the XM-L2. Which I consider to not be visible.
The XM-L2 have about 40% more light compared to the XP-G2. Its got stronger spill light and larger hotspot with pretty much the same throw. Easily visible.
I hear people say this all the time. The XP-G2 "throws soo much better at similar current in big reflectors". So why does your Convoy XP-G2 light only have 6% more throw than the XM-L2 light? Drive the XM-L2 harder and it will outthrow the XP-G2 (domed vs domed). Its also easier to drive the XM-l2 harder.
On top of that, the further towards 5A (or higher) you push those emitters, the more the XM-L2 will go for the lead...
I have done beamshots comparisons with de-domed XP-G2 running at MORE than 5A in large reflector. (The emitter died after some use btw) It did not live up to my expectations. De-domed XP-G2 in a bit more compact zoom light, totally different story. Cuts through fog and rain like nothing else and throws well for its size.
And yes, with less spill it is easier to see further, especially with rain/moist/fog/snow etc in the air. MT-G2 lights sucks in these conditions..
I certainly agree, there is a use for every light with every emitter combo. I just think that certain light/emitter combos are not as good as others..
As long as its not a parking garage, im good with the other suggested locations. Two sets of pictures (wide angle and tele). Mouseover pictures.
Could you check lux and lumen on XP-G2 vs XM-L2 at medium?
Would be interesting to see how numbers compares to high.
Race, new numbers in the spreadsheet covering lux and lumens for L and M ranges.
Where did you find centering rings for Convoy reflector for XP-G?
The XP-G2 fit’s diagonally into the centering ring for the XM-L footprint. Not the best solution perhaps, but it keeps the reflector off the pads.
Oh, because of the white background (mcpcb) I thought that it’s dedicated XP-G centering ring, should have clicked the image first…
I am doing the same thing but when screwing down the bezel, reflector rotation also twists this centering ring and its very hard to get 45 degree offset…
Smash on the lens with your thumb, holding the reflector and thus the centering ring in position while screwing the bezel down. Then clean the lens.
And I never said any of this was easy. You should try stuffing the MT-G2 in a Convoy C8, more to it than it might appear. Beats digging ditches in the hot summer Texas sun…
Thanks.
Which numbers are better to compare btw. Lux or throw in meters? Lux numbers are further apart.
In my previous post I said the XP-G2 only had 6% increase in throw compared with the XM-L2 on high. But when checking lux numbers the gain is higher.
Which number is best for describing difference in throw?
Throw numbers are derived from the lux of course, but the variable is in the spill. The little XP-G2 makes high lux numbers at the cost of very little spill. As the indoor photo shows, there’s not much light to show the area to the sides as compared to an intense hot spot. The difference between the XM-L2 and XP-G2 is much more than the numbers would indicate because of the amount of lumens being put into the peripheral area. There’s still a decently intense hot spot (not a whole lot less than the smaller emitter) but there’s waaaaay more light in the outer areas, making it much more useful than the pencil beam in my opinion.
Again, your need would dictate which way to go.
I will, at the very least, get my standard beamshots tonight to show a comparison at 97 yds. Rain or no rain, cold or not.
Awesome comparison Dale. I am afraid I am in the minoroty though. I love the MT-G2 and the XM-L2 but throwers to.me are funner to play with. I prefer the tighter spot and less spill of the XP-G2. It is just easier to see if a tighter beamed light makes a target because you are not blinded by the spill. I am looking forward to seeing it driven at about 4.5A and de-domed. Great job!
Great shots! I am still a big fan of the MT-G2 for close up work, it puts out so much light it doesn't even seem like I have to pan the flashlight because it lights up my entire field of vision! I am interested to see a dedomed XM-L2 vs. stock XP-G2 and dedomed XP-G2 comparison.
Interesting...
The beam shots look as I imagined. I like a single XM-L or L2 for a thrower, because I don't care for a really tight spot with no spill, but for a flood light I still favor a multiple XM-L or L2 with small reflectors, like the SKR lights. Wall of light is really what I enjoy the most. The MT-G2 is somewhere in between the two of those. I think a multiple MT-G2 in something like the SP03 would be about right for a wall of light monster with enough lumens to still reach out 300 yards or so.
I am hoping to mod one as a prize in the 2nd annual home made light contest this year...... Ooops, wasn't supposed to mention that yet.
Anyhow, thanks for the beam shots from the football field.
Next up, the hiking trail then de-doming. Then a power bump. And, hopefully, an assistant that’s cooperative.
Just found this thread… must’ve slacked off a bit over the holiday travel season.
Love the comparisons, but hate you for making me want an MT-G2 in a tiny format. (I’ve been trying to stick to 18650s, but maybe I could sneak a couple of 18350s into the pile…)
One question: in your spreadsheet, you’ve got head temperatures. Is that at the end of 2 minutes? Could you do a 10 minute measurement? Or is that risking a china syndrome?
