18 x XM-L Flashlight is in the town!! Someone has just up the game!!
I wonder if anyone is going to get this light and make a review of it?
These multi-emitter lights are getting out of hand! When will to many be too much? One of us needs to go a head and build a 100 emitter light. :bigsmile: I’m happy with my 12 emitter lights.
Ken
It has the potential. I’m up to 6980 lumens with my X60vn at the 2:00 minute point while running on 20R’s. Tom basically has that matched with his his 7 led TRJ18. So I’m sure this 18 LED monstrosity has the chance to do even more if somebody could find the right driver for it.
The only driver I can think of is the hyperboost. That’s the driver I have in my 12*XM-L2 Courui and my Trustfire AK-90. Its running at about 123 watts right now and its been holding up very well considering the designer does not recommend running above 100 watts.
Ken
Your X60 is dedomed too isn't it? I'd love to see what a light like this can do, but I don't want to throw another 100-200 dollars into it.
ok you guys, found the ultimate deal on this light!
whos gonna do the review??
http://www.aliexpress.com/item/2014-New-Arrival-22000LM-18-x-Cree-XML-T6-Led-High-Power-Flashlight-Torch-Lamp-Use/1580314057.html
The Chinese should go back to E.E. classes and design some new drivers. Let’s not mess around and start at a measly 10 amps, and go from there. I want to see 18 gauge wire glow like an incandescent.
They’re Chinese lumens, so half of 12 is 6 = 6,000! It’d beat the X60, but with next-mode memory and the 18-inches of girth, you’d have to be at least 1/2 insane to invest in it.
correct me if i’m wrong. these are the specs,
Flashlights
TAIL-CAP CURRENT 2800 mA
BATTERY FORM FACTOR 26650 / 32650
REQUIRED BATTERY COUNT 3 / 5
doing simple maths,
2800mA, max 5 Batteries,
total Power consumption = 2.8A * (5*3.7V)
= 51.8W
Per LED is taking about 51.8W/18
= 2.87W
translate back to per battery is around 0.77A at 3.7V per LED consumption
Underdriven compared to a C8 with 2.8A per LED driver… haha
You will be lucky to get 70 lumens/watt OTF, so maybe 3600 lumens total…
Luckily Match posted quite an intensive data on this XML T6 LED.
assuming my calculations are correct with 0.77A at 3.7V, his test results are around 303.5 lumens for that current and voltage input.
Test on LEDs
I don't think you're accounting for losses in the reflector and lens.
yeap… i didnt do that… just assuming for ideal case? :bigsmile:
This light is allmost a killer, two driver host. Sadly, it lacks cooling fins and mass where it counts the most. :frowning:
Two 9x led beast drivers in and off you go. Would gobble up those 5 cells in a heartbeat.
Using efficient drivers (Senser Xtremes) and assuming 5Ah cells, you would have close to half an hour runtime on 3A.
More than enaugh time to melt that pathetic flashlight head!
9x driver may not have enough voltage to run 9 XML2s - see here: https://budgetlightforum.com/t/-/23851
Yeah, I read that earlier. I was talking about the stock version… Correct me if Im wrong but the stock has XM-L T6 in it. Beast driver seems to work flawlessly in my 9xT6 torch. It really slurps up those 3 King Kongs but man it’s a lumenmonster!
Anyone buy this yet?
We ain’t that stoopid…
