What do you think about number 1 and 2 Match?
I would like the UniqueFire UF-2170 if it was offered as a host only. I don't need the entire set with battery and charger. I wonder about the build quality as well - especially the offering from cnqualitygoods . It would be a nice alternative to and 18650 based host. I have plenty of those, but only a few m@g C mods that accept 26650.
I've been looking all day for a 2x26650 flashlight with a big head. There's of course this
You get a lot of details there.
And there's this http://www.cnqualitygoods.com/goods.php?id=1145 SSt-50
1300L ? On a different site it was specified that the LED is driven at 5A. I think lumen estimates are not realistic, judging by this recent test https://budgetlightforum.com/t/-/2346
And then:
http://www.cnqualitygoods.com/goods.php?id=1150 XM-L T6
900L . This looks very real as on a different website it was specified 860L at 3A.
These too are both nice lights, and good prices, $57 and $49 respectively . The reflector is 51mm wide, however how deep it is? It seems to make bad ring/loop according to the beamshots.
Maybe some else is looking for a 2x26650 and some extra details might help.
I have finally found out what's the reflector size for these two flashlights, since no one @cnqualitygoods is willing to answer my e-mails.
It's 51mm wide and 30mm deep. I sure looks shallow and probably that's causing that outer ring.
1) UniqueFire UF-2180: manafont $58 Shipped
2) UniqueFire UF-2170: Manafont $58 Shipped
3) 1&2 26650 Host: cnqualitygoods $33 Shipped
4) 1&2 26650 XML: cnqualitygood $60 Shipped
5) Maelstrom S12: 4sevens $135 Shipped
6) TorchLite Host: gigainternational $50 Shipped
7) Palight BG-SST50: manafont.com $178.50
8) 2X26650 Host:cnqualitygoods $48.60 Shipped
9) 2X26650 XML: cnqualitygoods$68.60 Shipped
10) 1&2 26650 XPG-R5: cnqualitygoods $48 Shipped
11) Big Bruiser 3 XML: elektrolumens $260 Shipped
12) Titainium P60 26650 Host:candlepowerforums$486
Who feel that this 1&2 26650 Host: http://cnqualitygoods.com/goods.php?id=114
or http://cnqualitygoods.com/goods.php?id=1077
has shady pictures but is interested in such a host, check the link below for better pictures
Switch Type: | No switch, put in battery & the flashlight will work |
Im guessing this is a twisty, lol. http://www.dealextreme.com/p/fandyfire-bt-qs88-xm-lt6-waterproof-1-mode-1000lm-white-led-flashlight-2x26650-2x18650-4x123a-91661
I LOVE the 18650 adapters though.
The pill / heatsink looks good even if it lacks of mass / volume compared to the one of the original JM07 (on left)
So I prefer the "original" TorchLight / Shadow JM07 and idealy I would buy the one with the bigger head:
http://item.taobao.com/item.htm?id=5538270055
http://item.taobao.com/item.htm?id=5980690322
The problem is to know if the 55mm reflector for MC-E will "work" with an XM-L.
I do not know if the XM-L would benefit from such a flat area around it, like the reflector of the MC-E Torchlite with 55mm head and it appears to be heavy OP.
If you don't mind the double battery format this would make a better host in my opinion:
Yes, I seen this host a few days ago when I was searching 26650 flashlights but I didn't seen it anywhere else probably because it was discontinued.
(I seen one like this in Taobao but was not sure if it was new or used.)
"Sorry, this item is no longer available!"...
Nice! do you know if the body detach to run in single 26650?
Doesn't look like it does.
I'm waiting for the new Shadown lights from CNQ. Supposed to be very power, very good. Hope they are of Jetbeam quality.
What that extension under the light then??? Hmmmmm
[IMG]http://i912.photobucket.com/albums/ac323/vinhnguyen54/421.jpg[/IMG]
<a href="http://s912.photobucket.com/albums/ac323/vinhnguyen54/?action=view&current=421.jpg" target="_blank"><img src="http://i912.photobucket.com/albums/ac323/vinhnguyen54/421.jpg" border="0" alt="Photobucket"></a>
Also doesn't look like the Voltage range would handle 1 battery
[quote] Power 6~8.4V 2x26650 (not included) [/quote]
Anyone actually purchase either the UF-2170 or the UF-2180? Curious to see beam shots and find out if they are equivalent or essentially the C8 that is highly recommended on BLF, but with the 26650 battery.
Tia.
Other details from TaoBao:
This light definitely exists in 1x26650 format. In this photo the 2x26650 tube is in the background.
Priced @ $33
The 2x26650 version is sold for $36 by the same seller.
Shipping is $1.5 in China. :)
