That way you should pretty much look for the other lights especially the 18650 part.
hahahaha good luck, they wonât make more then minor changes, and even those have to be fought for, even my my idea about thermal power reduction is about as likely as being hit by lightning
Sure. Do you want fries with that?
But seriously: They are also planning small changes after which it would make coffee too!
Iâm in for one if it proves to be good.
venti or grande?
I am in for one at least depending on the review
BLF logo + âwhere Frugal meets with Flashlightâ on otherside
In for a couple.
I assume itâs plastic, just like the PA40 (had two of those, gifted them away, still miss themâŚ)
Thatâs why Iâm looking forward to see manufacturer solving the issues -> we might be able to get a good clone for half the price.
The PA40 has a âcarbon fiber reinforced composite bodyâ, not sure what plastic they use though as they donât provide much details.
The SA-22 uses PA66 (nylon 66)
From wiki:
Nylon 6-6 is frequently used when high mechanical strength, great rigidity, and good stability under heat is required. It is used for ball bearing cages, electro-insulating elements, pipes, profiles and various machine parts. Other popular applications are: carpet fibres, apparel, airbags, tyres, zip ties, ropes, conveyor belts, hoses and the outer layer of turnout blankets. Nylon 6-6 is also a popular guitar nut material.
I wouldnât be concerned about the the threads holding if they are made well with good tolerances as its pretty tuff stuff.
Also I hope no logo will also be available from Ric if this goes through instead of BLF by default.
B25364:Can we get the body made of metal. And have it use 18650s as well as AA. If so, I will take 2 with the green LEDs. No, one green LED and one red LED. Thanks
What about another model for us Tea drinkers?
better modes
0.2% of 880 lumens is 1.76 lumens which I would find pretty useless myself
Also any chance of OP reflector? That would be high on my list of wants for this light as it would eliminate any chances of a crappy beam pattern leading me to give it away and writing it off as a loss/wasted money.
edit The lowercase âhâ in âSTARRY LIGhTâ looks like a unnoticed error by the manufacturer.
If this can make Coffee I will need a dozen, to go
Count the RicFlair inn for uno. Aka 1
_the_: B25364:Can we get the body made of metal. And have it use 18650s as well as AA. If so, I will take 2 with the green LEDs. No, one green LED and one red LED. Thanks
Hey! Come on.. Please try to keep your requests reasonable.
Interested!!!
better modes
0.2% of 880 lumens is 1.76 lumens which I would find pretty useless myself Also any chance of OP reflector? That would be high on my list of wants for this light as it would eliminate any chances of a crappy beam pattern leading me to give it away and writing it off as a loss/wasted money. edit The lowercase âhâ in âSTARRY LIGhTâ looks like a unnoticed error by the manufacturer.
0.2% mode provides enough light for many tasks, and very long runtime (rough estimate would be over 17 days of light!)
OP reflector would be a nice addition, but I doubt it's doable. I'll ask anyways. (Stippling it yourself is always an option)
I suppose 'h' is part of their logo design, as it's that way in all the logos..
Count me in for one.
Iâm in!
Seriously though, Iâm in!
[quot
Yes I would also like no brand.
