The lights in the link above seem to be a little overpriced to me. The AA extender will give you longer run times allowing you to use 2-AA’s instead of 1, thus doubling your run time. It also makes the host longer. The lights probably have low voltages drop ins (.8v to 4.2v) Using 1 or 2 AA’s will put you safely inside the voltage limits. (1.5 to 3v’s on fresh cells)
The smaller 1-AA Tank in the link is only a 1W output vs. the 3W output of the 2-AA light.
Tank makes some decent lights, and have been discussed on here several times.
Check with some of the vendors on here and see if they carry the same light. They offer excellent customer service and guidance.
The TK566 goes from 1w to 3w with the extender, or at least that’s what was explained to me when inquiring about it.
Also, Manafont had them for under $30 at one stage…
If you are into soldering, a 365nm light can still be made fairly cheap by buying a separate emitter (an ok chinese emitter goes for under 15 dollars, I guess the Tank uses one of those) and put it in a host-with-driver of choice.
I think I’d rather buy a complete unit. I know the required electronics but have no experience with hunting parts and figuring how to put them physically together. Unless someone can show me a list, like “host here, driver there and emitter there, here you go” and I just click “buy, buy, buy” and slide the thing together once everything arrives.
There was links in the thread to two P60 drop in that will just slip into a P60 host, the links still work. One was the solarforce with 380-450 claimed nm. And the Kaidomain with claimed 365nm. The reports from an owner suggest he kaidomain was better, less polluting other light and it charged flouro paint instantly. The SF one did it too, just not as quickly. It was pointed out that light in the 365 range can also do what the ones in the higher range will do, but not vice versa, so the 365 would seem to be the pick to me. If Im reading it right. And at the price point of a few dollars that is.
Hi all,
I own a couple of P60 (502b w/186500) 1W UV lights from DX. They wont light up a $100 USD bill. Based on this thread, I ordered one from KD. Do you think it will work in a 501 with 2 CR123s?
I could be wrong, but I don't think the new US $100 bills have anything that fluoresces in them. Maybe some small fibers in the paper, but I don't recall.
Yeah, ever since I got a CU6 I've been aiming it at random things, like my shoelaces and watch hands. It's really amusing, and probably bad for my eyes haha.
Speaking of which, I got these glasses for my laser, but they really make UV light pleasant on the eye and you really see fluorescing objects so much better. I have several pair of yellow glasses, for some reason these work better. Haven't really compared side by side though. So caveat emptor.
UPDATE: Another member purchased these glasses and reported that they don't work as well as most yellow glasses. I trust that members judgment in this area better than mine.
I know that texaspyro has better output on one cell. I have this KD drop in and find that mine is very much brighter on 8.4 volts than on a single cell. Even though they came from the same source, knowing Chinese venders I would not be surprised to see different drivers or LEDs.
I do find that the KD 365 nm UV does a much better job on bank notes than my unknown 380 nm drop in.
Just received the KD 365nm P60 and to my surprise, there are two emitters inside the dome.
I thought the two emitter version was the 395nm version. I’ve just tried it out on some money and it fluoresces the Australian 50 dollar note OK where as my other 395nm one doesn’t show one of the symbols. Can anyone confirm that the 365nm also has the two emitters? Everything else is as how it was described in this thread.
Another thing is that I bought a purple Ultrafire WF501b as a host. Well the P60 does not fit in the head as the lens retaining ring kept it from going deep enough. I had to remove the lens to get it to fit, but it does mean I’m going to have to use it without the lens which probably has some pluses.
… plus someone claiming that the actual photon output should be around 450mW worth, though I’m not really sure how that translates into a familiar unit like lumens. I doubt the usual 683 lm/W math applies, but if it did, that would mean about 300 “lumens” of mostly-invisible light.
Regardless, assuming the 3000mW figure is correct for its input power, that’s several times as much as the cheap 12-LED 375nm light I have, and at a better wavelength… with a more focused beam and all the other Chameleon extras.
Here's another photo to give you an idea of the strength. The bill is sitting on a white box which is probably treated with some fluorescent. I'm still collecting applications to have this light reviewed.
