I’ve tried, no luck. Look for another seller.
Now they have also purple tritium. Green is the brightest. Please check the customs laws of your country. In some tritium isn't legal for example in Germany you can get some problems.
Price is the same as the others, which Chloe posted $11,29. My link - non aff-link
A few posts show, that some usres are interested in Walkie Talkies. Herer are also two new in the list.
BaoFeng BF-777S 400-470MHz Walkie Talkie / Two-way Radio 5W / 16 channels / US plug.
Channels: 16 Frequency Stability: +/-2.5ppm Working Voltage: 3.7V Working Distance: 5000m
Encryption: CTCSS / DCS Antenna impedance: 50ohm. Price $25,76
BaoFeng BF-V85 1.2" LCD Single-Display Dual-Band Walkie Talkie / Two-way Radio 5W / 136-174MHz + 400-480MHz / 99 channels / US plug charger
FM radio frequency: 65-108MHz Channels: 99 Frequency Stability: +/-2.5ppm Working Voltage: 7.4V Working Distance: 1000~4000m Encryption: CTCSS / DCS Dual band, dual watch, single display Frequency step: 5/6.25/10/12.5/20/25kHz Antenna impedance: 50ohm Working temperature: -20'C ~ +60'C. Price $45.41 My link - non aff-link
Batteries - some with special max. voltage (LG, Samsung). Use BLF so save 5%.
Samsung ICR18650-32A 3.7V 3200mAh Rechargeable Li-Ion Batteries (2 pieces), Battery Maximum Voltage 4.35 V, unprotected, flattop. Price for a pair $13,97. My link - non - aff-link
Samsung INR18650-29E 3.65V 2850mAh Rechargeable Li-Ion Batteries (2-Pieces), Battery Maximum Voltage 4.2 V --> the charging voltage should be 4,2V +/- 0,05V (from the datasheat of Samsung), unprotected, flattop. Price for a pair $11,85. My link - non - aff-link
LG ICR18650E1 3.7V 3200mAh Rechargeable Li-Ion Batteries (2-Pieces), Battery Maximum Voltage 4.35 V, not real flat top, not button top - I would say a little bit button (not much). Price for a pair $13,49. My link - non - aff-link
32A 29E LG
Sanyo UR18650RX 3.6V 2000mAh Rechargeable Li-Ion Batteries (2-Piece) 22A continuous discharge.Battery Maximum Discharge: 22A, button top, unprotected. Price for a pair $12,23. My link - non - aff-link
Sony US18650VTC4 3.6V 2100mAh Rechargeable Li-Ion Battery (2-Piece).Battery Maximum Discharge: 30A, peak 60A. Max. charging: 4A, flat top, unprotected. Fasttech wrote: Max. battery voltage 4,25V, but no other shop wrote this. All warote 4,2V.Price for a pair $11,87. My link - non - aff-link
ICR26650 KingKong 3.7V 4000mAh Rechargeable Li-Ion Batteries (2-Piece and a box).Battery Maximum Voltage 4.2 V, flat top, unprotected. Price for a pair $18,09. My link - non - aff-link
Wallbuys sells KingKOngs ICR26650 with 4000mAh one piece for $7,26 since a few months. I don't know, if Wallbuys have older stocks (like the LG 18650 D1) of the King Kong and this cell came without a box.
Today some new knives are listed, too. Some I haven't seen before and some which are known from other store for a longer time.
I start with some knives: Ganzo G701 in 3 versions. The blade color is always grey, but the handle colors are different. Available are black, green and tan - like the G704 colors. Bladelength 84mm. Price (green/tan): $17,52, black $17,08. My link - non aff-link
Authentic TEKUT LK5268 Wolf Paw Stainless Steel Folding Knife 60mm blade / black, 7Cr17MoV. On the handle are some footmarks of a wolf (looks a little bit like the Jack Wolfskin logo) Price $16,80 My link - non aff-link
The next knives are avialable with a blade length of 90, 75, 68 and 55mm. They aren't new on the market (Vaialable in other shops since a few years). The 90mm version is avaialable in black/grey camo, the others are available in black, too. It has an interesting way to open and close it (short video). The is a knock off the Kershaw ET.Kershaw ET
Price for the 90mm is $10 and the cheapest 55mm version $5,15.
Authentic Sanrenmu B4-733 Stainless Steel Folding Knife, 64mm blade, 8Cr13MoV, carabineer Clip. Price $11,30 My link - non aff-link
Ganzo G302B Stainless Steel Multi-Tool. If you need a multi-tool and Leatherman or Victorinox is to expensive - I know that the Leathermans in the US are cheaper as her in Europe. I ordered a Ganzo 301 a year ago for a friend who want to give it away to a fellow. It's feels stable and I have never heard anything bad about it. Price $42,84. My link - non aff-link
The SRM 733 is one of my two favorite knives. I posted a mini-review of it a while back, but the short version is that it’s a good design and well-made. Fun to fidget with, too, with its flipper. It’s too bad they don’t have it in all-silver or all-black yet.
I couldn’t resist the Sunwayman V20C-Y neutral white version for about 39 shipped. True, it doesn’t have the XM-L2 but that’s OK.
Maybe you could use it as a host and put an XM-L2 into it?
Has anyone bought this S6 clone? Does it have the brass pill like similar X-Power and Convoy lights and Omten switch? I’m thinking about, at the least, upgrading the driver.
Several explosives added today. Not going to link them.
I know this is not a radio thread however it must be said, if you do buy a uv-3r under NO CIRCUMSTANCES should you use the charging stand. It simply wires 5V strait to the li-ion battery.
DO NOT USE IT!
You CAN use the charger into the charging port on the side of the radio though, it is regulated though a ‘proper’ li-ion charge controller.
Thanks for the head’s up. I ended up grabbing a couple of 5R’s, and did not realize that the 3R has a battery setup similar to a cell phone.
If you go by the FAQ written by Ed Griffin, at the bottom of page 9, it sounds like if you have the correct battery, it should still have a protection IC in it, but he also confirms that the base has no controller, so it’s a good head’s up for anyone that may have grabbed those units from Fasttech. Anyway, here is some more information from that FAQ on this subject that may be of interest to some:
Edit: I shouldn’t have said, “written by Ed Griffin” (he owns Wouxun.us), it says on the cover it was a collaboration project, so it would be more accurate to say he distributed it (and probably had a large part in the collaboration as well).
After a longer time without any new interesting products here are a few nice products:
Some different stoves of Fire-Maple. One for fuel and the others for gas:
Fire-Maple FMS-108 Camping Stove Gas Burner output power up to 3500W, price $71,29 My link - non aff-link
Fire-Maple Spark FMS-121 Wind-Resistant Remote Gas Stove firepower 2900W, price $38,53 My link - non aff-link
Fire-Maple FMS-100T King Kong Titanium Gas Stove 2450W, price $60,36 My link - non aff-link
Fire-Maple Turbo FMS-F5 Remote Fuel Stove 3200W, price $60,60 My link - non aff-link
Knives:
Enlan M027 Stainless Steel + Pakkawood Folding Knife 54mm blade, $9,36. My link - non aff-link
the bigger brother Enlan Bee EL-05 Stainless Steel Folding Knife 72mm blade, $13,75. My link - non aff-link
Enlan Bee EL-06 Stainless Steel Pocket Folding Knife 92mm blade, $16,80. My link - non aff-link.
This is a big and nice knife. I have it since a few weeks and it works really smooth. Fasttech also have the black G10 version, with non coated blade for $15,44.
Ganzo G203 Stainless Steel Multi-Tool, $21,50. My link - non aff-link
I will recommend the larger models of the 300 series more, because they are more stable, but cost $15-20 more.
Sanrenmu 9054MUC-GP No Lock Stainless Steel Folding Knife 83MM blade. The GP is the green handle version the GH the black. Price $13,16. Teutate buy this on ebay for $18,90 and show some more pictures here. Important thing: It hasn't a lock, but it's to long for UK (3") if you do not modify it. Take a look at the thread of Teutate.
Ah, they now have the ‘strange fish’ knife! Thanks, Buwuve.
You know this how?
I have the UV-5R and it works like a champ…also the MTC UV-X4 which is a clone of the UV-3R, has a 5vdc charge port on the side (little spade that plugs in with a USB connector on the end)…maybe it has a li ion charger circuit inside
P.S. Open source programming program that is ALOT better than the chinese version CHIRP
Oh and this will also help too
One way would be by reading the Third paragraph of the image of Ed Griffin’s FAQ shown in post #1141. Another would be to Google it, which seems to indicate that is correct.
The Third paragraph of the image of Ed Griffin’s FAQ shown in post #1141 addresses that question.
And I suppose someone will mention it anyway, programming that frequency list into your Baofeng would be illegal, but in reality your chances of getting into trouble for doing it are almost NIL. However, unless you live in the USA, many of those channels would be useless to you anyway. The best way to summon help is call 911 on your phone, and if there is no cell reception and you have to use a radio, then you better be able to hit the local repeaters (for which you need to know not only the tones codes required to activate them, you also need to know the duplexed frequencies, and whether they are Wide or Narrow Band) The only duplexed channels in that are in that list are token GMRS ones that probably would not exist where you are, but you can check here you live in the USA.
Another note regarding those Fire Maple Stoves linked above. Looks like he missed the FMS-118. Even though it has a pre-heat tube on it, they do not work all that well in the cold because the tube is too small, so it splutters almost as soon as you invert the cannister. It looks like they added a second tube plus shielding to the FMS-100T, so I suspect it should perform a lot better in cold weather.
Thanks for the heads-up Buwuve, bloomin’ typical, I ordered two of the “strange fish” knives from another source for $19.99 each. I really should have waited but I’d only just put in a product request in, not that that makes any difference if the copy/past answers you get are anything to go by.
I like the look of that Enlan/Bee EL-06 as well but there was a bad review on youtube saying the scales looked painted with the camo and the thumb stud was very hard to use and uncomfortable, looking at the position of it in the pictures on FastTech I can see that it might take a bit of dremelling to uncover it a bit. It is a good looker though.
I think Fasttech is no longer interested in Flashlight products. If you notice all the new arrival products from 24th February onward are e-cig related items.
Daggumit…it was FT fault for getting those flashlights in while I was ordering my vaping stuff that got me onto this new hobby…they BETTER not bail on us flashlight folks!
or what? you will stop smoking buaahahahaha
Smoking is much better/probitable addiction, users cannot stop buying new e-liquids and they are not as demandable as flashlightoholics also
