The light is well regulated, but the head heats up pretty much, causing some thermal sag when run indoors without any cooling (not in hand, no moving air). Ambient temperature was 25°C and the maximum measured temperature of the head was 90°C (at 59min, when the light ran out of regulation). That's pretty hot, but then again, not too hot for electronics, and the body tube and cells were in comfortable less than 50°C temperature, which is perfectly ok for NiMH cells.
Conclusion: This light is driven at suitable level, being bright enough, but still safe for careless non-flashaholic users. :)
Note: The graph ends at 2h mark, but the light is still running with about 0.5 lumen light. Currently 4h and counting..
I believe you are confusing the “off time memory” Chicken Drumstick described with the “on time memory” used by qlite and other 105c-style drivers.
“on time memory” memorizes the mode based on how long the light has been on (for example on >2 seconds), “off time memory” memorizes the mode based on the amount of time the light has been off (for example off >2 seconds).
Wrong (IMO). Without memory, you can go from low to moonlight by turning off for a couple of seconds, then starting in moonlight without going through medium and high. If you use high and are annoyed by having to spend a second or two on lower modes, then a light offering moonlight and low is simply the wrong tool for the job.
Yes, you understand correctly. “off time memory” is what was described by the and Chicken Drumstick. In the other thread nobody discussed which type of memory the stock light has beyond the fact that it works properly. In this thread we have yet to see a 100% complete prototype of the BLF GB light, so I can’t tell you for certain what this light will have yet! “off time memory” is considered the more desirable of the two. I believe that outside of Nanjg drivers “on time memory” is rare.
Personally while I see merit in having both low and moonlight, I’d primarily use a light like this on full blast. If it were to have no memory, I would prefer to start in high because:
I mostly use it on high.
It's easier to showboat that way.
If it ever seems practical to defend myself by shining the light in someone's eyes, it better be on high for that first click! ;-)
I can easily preserve my night vision by covering the lens and switching modes a few times to moonlight.
I think the memory/no-memory/mode-order discussion has been walked through several times on BLF and elsewhere. There's really no cure-all for the issues that are brought up _the_ picked a configuration, some people will purchase it and some will not.
[quote=Bort]
Can the LED be upgraded to sinkpad/noctigon and what diameter is the driver, i am curious if it can be replaced
[/quote]
Bort, _the_ pointed out that the special battery contacts are on the bottom of the driver PCB, a swap with an existing driver would not be practical. Of course a custom driver could be made. Fair question as to how the LED is mounted!
I’m afraid with the confusing battery configuration that I won’t be in on this one. I was going to give one to a non-flashaholic, but I don’t think this one will work. Sorry!
