I have modded this Courui since 1 month ago but it is not perfect yet as some issues still presented.
What I have modded:
Removed the stock R200 resistor and drop a solder blob in there to achieve direct drive in high mode.
XM-L2 on Noctigon.
Change the LED wires into 22AWG.
Battery springs are copper-braided.
What is the problem?
The LED was still lit even when the light was switched off! Refer to the picture below, it looks like some sort of âmoonlight modeâ, very dim but it is actually lit and it does flicker a bit.
I did some connectivity test using my DMM. When I used the probes to touch the LED +ve pad and the pill, no connectivity was found.
However when I touch the LED -ve pad and the pill, the DMM gives beep sounds, which mean the pill has connectivity with the LED -ve.
After that I tried to connect with a 18650 battery. The -ve end of the 18650 goes to the LED ve and the +ve end of the 18650 goes to the pill some sparks came out, it is indeed shorted!
Before this I thought it was the LED or Noctigon problem, so I change into another piece of LED but problem was still persist.
BUT, when I remove the driver and leave it tangle outside the flashlight, the aforementioned shorted issue gone. From here I guess it is actually the driver problem.
I try checking if I has soldered anything wrongly on the driver but I couldnât figure out anything. This driver works with an electronic switch and I am not quite sure about its mechanism. Some photos of the driver as below:
To make it more understandable:
When driver was put on, issue presented (permanent on and shorted occur between the LED and the pill)
When driver was left outside the light, no problem at all.
I have no clue at all but is there possibly something has burnt or shorted in the driver? Hope somebody can help me on this.
