I sometimes take pictures of emitting leds through a cd (also good for looking at the sun during an eclips :-) )
Well, i'm focussed now :).
I have used an extra 'O-ring' of solid copper installation wire to adjust the lens a bit.
The projected picture of the die is not as sharp as my sk68 zoomy.
As you can see in the picture, the beam has a purple imperfection in one corner. Maybe the die is damaged, or its a little bit of the dome left on the die.
Well yes, maybe there’s a little part of the dome left. I don’t think soaking the PCB for a longer period would help, as the dome completely fell off and was kind of ‘crushed’, not dissolved. As the naked die is very vulnerable I didn’t brush the surface.
Well done! The blue in the corner is typical of a chip of phosfor broken off in the corner of the die during the dedome (you should be able to see it in a close up of the led), exposing the blue led underneath.
The image suggests that the led is not exactly centered under the lens.
Cheap glass lenses used in flashlights tend to do worse imaging than plastic ones. I still like them better because they do not scratch over time, and I do not want the ugly die imaged sharp anyway.
I think this is collatoral damage of dedoming then?
:) I'm fine with the picture. Ans the beam is small enough for me now.
or maybe cellulose based thinner is a bit harsh, I mean, full dedome in just an hour or less, that’s pretty fast chemical reaction.
Anyways, all those discolorations and unwanted rings are reason I don’t buy zoom light.
depends remains of silicone or around your LED?
I dedome with thiner and it works very well.
after the ball fell off is just lash out, blowing hard / blow / blow and back for an hour or two in it!
then back hard blow / blow BLOW … and you have a clean dedome.
the harder you drive up the Amp (4 or higher) clearer and more how you obtain whiter light.
furthermore, you can gently with a black marker around the silver plate LED colors around the LED itself to reflection.
The only thing I want with this flashlight is a spill from afar 100m + which is the same as the hub you have to + –10 meters.
if someone trick or another glass knows please replace. please let me know
and of course … of course even more light! :bigsmile:
another beam shot,
this time the modded Uniquefire uf-t20 VS a modded Trustfire X7, emitter : XP G2 R5 2B (with dome) at 5A current .
left: uniquefire , right trustfire
The Trustfire X7 should be at ~225 Klux.
What do you think guys? The uniquefire spot looks more intense, isn`t it ?
Solder paste? In the video it he uses ‘solder paste’ in the pill… I am not sure what this is, can someone send a link to where I buy… Maybe from the ebay?
This is only one of many places
clicky link
Go onto Ebay.au and search for “solder paste -flux”
be careful as there will be a lot of flux under all kinds of names mixed in the results :~
Cheers David
I have been using this without any hassle.
Question, could you scoop a glob of it, put it in a syringe with say a 14ga blunt tip needle (I use rotary tool and diamond wheel to grind sharp tips flat [I use it to put e-juice in my vapor systems thru small screw holes) and use that to place small bits of solder paste on the pads for reflow?
I used the full syringe tube that I got from amazon to dab globs of this on the pads when I made my 32*7135 SRK and 20mm TexasPyro Nanjg driver
A stencil from OSHStencils would DEFINITELY be a good idea if you plan to make more than one at a time (and they do VERY good work, I got both my stencils for the above, haven’t used them yet, but got the plastic mask and stencils for very cheap!
Here is rosin solder flux
https://www.fasttech.com/products/0/10001213/1101900-high-intensity-soldering-flux-paste
But definitely like that FT solder paste! NICE!
I have been using a toothpick, but stencils would be much faster and more precise for quantity work.
another beam shot,
Hi,
first thank you to the thread starter for this nice mod and detailed review, I really like this stuff Now my UF-T20 have arrived and i really like it. Still waiting for drivers and leds, seem there is no luck there for me…
Borg, liked very much your work too, and I am for xpe mood too. Still one question in my mind, how its possible u have spend all this in torch and leds and so on and still are missing a lux meter? I strongly advise you to get one, it will help you and us a lot.
With my bad luck with mail I have, got a lux meter and still waiting for led and drivers to arrive lol.
ah one more thing I am measuring stock UF-T20 and is giving me around ~ 22Klux, but my batteries are cheap TrustFire. Look that reading ok ?
22klux sounds plausable, that is what you can expect of a xml in a good zoomie.
(thanks for the thanks, I would have never thought that this thread would attract new posts even after a year :-) )
Well I believe this thread will go strong for a lot more than one year
Personally i like throwers, and really like pocketabile ones with just 1x18650. My dream one will be one that is small like an M2 for excample or even a little bit smaller and throw 100Klux and up (pretty much impossible by today standards I know)
This T20 is in the upper limit of the size to my tastes, so I will try to experiment a little bit with it with the hope to up the lux numbers as much as i can.
another beam shot, this time the modded Uniquefire uf-t20 VS a modded Trustfire X7, emitter : XP G2 R5 2B (with dome) at 5A current . !{width:70%}! left: uniquefire , right trustfire The Trustfire X7 should be at ~225 Klux. What do you think guys? The uniquefire spot looks more intense, isn`t it ?
You have wrong tint for XP-E2... Try 1A or 2B tint... To me it seems like you are in 180KCD range with this mode. Get yourself light meter and open a thread with your version of Vavien collar I will buy it :)
Stock Trustfires X7(sst-50& 80) are not throwing more than 50kcd, and I did not to try to mode one with XP-G2 because it seems that it has not right shape of reflector for that little led.So I think you are in 120 kcd range with your mode(and it would probably throw 200 or more kcd if you dedome it? Why not? 2B is my favorite tint for dedoming).
Ervin Anastasi,
no lux meter until my current aspheric project is done
luminarium iaculator,
in the beamshots i locked the white balance to “daylight” . This makes the image to look more warmer. In reality, the spot is much more cooler.
i choose XP-E2 R4 (6100-6500K) tint because it was the only option from intl-outdoor.com store. I assume that 1A and 2B tint are cooler ?
Anyway, after installing a recycling light collar the tint becomes even more warmer than after dedoming.
About the Trustfire X7, if you check this thread by Andi , last page, post nr. 110, you will see that a hard driven and well focused dedomed xpg2 in the X7 will do 400-450 Klux.
About the recycling light collar, i am sure a lot of people would buy a collar custom made to fit the Uniquefire UF-T20, but also i do not think that wavien would be very happy about it, since they patented this technology. So i do not think this will going to happen
For now, i will not dedome the XP G2 2B in the Trustfire X7.
I bought the X7 to mod it into a aspheric thrower with a hard driven XP-E2 + 75mm lens . The XPG2 is installed now just to see how it shines with it, until my new lens arrives.
I want to report about the kaidomain 80mm aspheric lens link
This lens is not good for maximal throw, it has a bright spill and it can not focus all the light in the spot.
This is how the recycling light collar custom made for the Trustfire X7 looks :
