My king has arrived today too. Driver is crappy of course with one mosfet. Reflector is a little scratchet, leds are XM-L2.
Not measured current yet but stock is a little brighter than my king with 3x XM-L @2,8A each.
Leds have heatsinking. Pill is 3mm thick and screw in to flashlight body.
Machining is good for that price, anodisation not bad too.
I bought that flashlight becouse of leds and reflector for mod old diving flashlight.
Here are pics of the tear down.
The bezel is Aluminum, not Stainless and the button on the on-off switch is a little smaller than others I have seen.
6 XM-L2s all lined up in a row. So neat!
With the tail cap off. First time I have seen one with all 4 screws installed.
Unknown, to me, driver.
I tore the trace trying to get it out. This method works great if the driver isn’t glued in place.
So I had to go at it from the other direction. After unscrewing the bezel, I used a sock (for the feet) over my hand to unsrew the reflector. I was very happy to see this, as other cheap SRK clones did not include this. This provides a good thermal path to the body of the light.
Once I was able to get behind the reflector, I was able to pound out the driver from the back side. It took quite a lot of force to break it loose. The leads to the star are 24 gauge.
Pic of the driver, I will have to study up on this one, I don’t know if it is worth trying to improve.
The MOSFET is an HJ35N03, Chinese. I couldn’t find any parameters other than it is rated at 25V. I’m pretty sure I could just swap in one of the 70N02s.
All in all I am thrilled with the build quality of this light considering it was only $23.10 from DX-US. I could have done a lot worse. Good job DX.
I just got finished with some mods on this light and driver.
First of all, I am no driver expert, but as far as potential output from this driver, I think it can be VERY good. Here is a pic of the 70N02 MOSFET that I just swapped in. The 70N02 has super low resistance when passing a lot of Amps. Look at the circuit board. The entire perimeter of this driver is a sea of copper clad circuit trace that all leads to the Source pin of the FET. The Drain of the FET is just a few mm from L-. The positive ring on the cell side of the driver is connected directly to L+ through the vias that can be seen just under L+. These are all direct connections already, unlike the highly regarded JB driver that has current limiting resistors that have to be shunted in order to get what this drive already has STOCK. As long as that FET is drivin to full ON when on high, nothing could be better. If I am missing something here, someone please point it out. Sure, maybe with the original 35N03 FET it sucked, but now it rocks.
Before
After
All of the XM-L2s are mounted directly onto 1 star that has its own traces connecting them in parallel. Nothing I could do there. What I did do was replace the 24 gauge lead wires with some 16 gauge wire I picked up at Cables and Connectors. they only had 25 feet on the spool, so I bought all they had. I think it might be silver plated copper, but I can’t be sure. They didn’t know what they had as they got the spool as part of a liquidation buy.
It’s definitely copper underneath, what I don’t know is if it is silver on the outside. They said it was test lead wire. It’s nice stuff, just not silcone or teflon.
I have yet to do the spring mod, but as of now, my subjective guess is that it is twice as bright as it was. Before these 2 mods is was about as bright as a modded 3 XM-L SRK with tail spring mod, lead mod and FET swap to 70N02. That also was a cheap, non JB driver.
