Get the Convoy C8 AK47 from Banggood (8*7135)
Just to confirm
Banggood is indeed XML2 while
Fasttech is XML
correct?
I believe some people have received xml2 when they ordered xml from FT (small amount). My convoy c8 from FT arrived with xml.
But yes, if you choose the xml2 option at BG on the Convoy C8 that’s what everyone (to my knowledge) has received.
Thanks. Now I’ve hopefully got a XML2 T6-4c coming.
That’s what I ordered. It was a nice tint, I bumped mine to 3.5 amps. It stayed like that for a week and now it’s waiting to be modded into an xpg2 light. I’m just too involved in other things to finish it.
You’ll love it though. Very neutral warmish tint.
Does anyone know Convoy’s website, can’t seem to find them online ! :~
AFAIK
http://www.cnqualitygoods.com/
I think this is more their website under the BTU label !
BTU Flashlights - Convoy
I don’t think they even have an official company. I guess they just ordered hosts from factories and then assemble the lights. The important thing is they done it right with their QC.
Ric seems to be Convoy and CNQG and Shenzhen Great Wall on Aliexpress. You can PM him here and ask.
http://budgetlightforum.com/user/8498
Sorry, I'm confusing Ric and Simon. Simon is Convoy Flashlights.
I just received the Convoy C8 xml-2 4C and it is AWSOME! This is my first flashlight and I’m impressed with the quality for this price. The tint is perfect, neutral for my eyes and the light is very strong. First product I got from China that has perfect finish, I think is underpriced.
I bought it from recomandations on this forum, thank you BLF!!
Now you just need a convoy m1 and a convoy s2 and and and :bigsmile:
Someone ordered XM-L2 smooth reflector?
learn so much
Oh yeah the 4C tint is great…many people find that tint to be their favorite…colors are brilliant and vibrant and not washed out, not too much yellow and not too much white
XM-L2 is a very good emitter, a bit more efficient than the XM-L
Just be careful of getting spoiled, Convoys are always top notch but there are many manufacturers that will send you crappy builds with the same “model name” like fandyfire C8, or Ultrafire C8…so be careful…with Convoy…and dealing with Simon you usually can’t go wrong :slight_smile:
Gave in and took the L2 4C OP, thanks for recommendations.
Hope I’m happy with the light AND with the delivery time :slight_smile:
EDIT: Got it, not a long wait I guess. Is 2A@tail sensible? I think some of you got more…
Oh, the pill was loose out of the box. Strange.
I would venture to guess the leads for your measuring device are inadequate, or the battery is sub-par/low charge. You should be seeing 2.8A on high.
Thanks. I will try to get a better set to check if mine is not up to the task.
I have those leads BTW: http://www.dx.com/p/multimeter-test-leads-probe-cables-90cm-33451
oh yeah, those leads are woefully inadequate
I took an 18ga automotive wire, tinned about 3/4-1” of one end, folded it over to make it double thick re-tinned together (this is the end I slip down into the multimeter plugs) other end I put banana clips, leads are about 12-14” long, those will give you MUCH better readings for sure
Wow, good job with those wires :slight_smile:
We have some Flukes at work, I will try to see what one of them shows.
EDIT: Nope, still 2A. What else can I check? Battery? Or just try running it from a DC supply @ 4,2V?
