need a 26mm PCB / driver board / contact plate
Maybe if you had extra tabs at 12 and 6 oclock, more work to fitā€¦but would really increase the area for soldering to the ground ring, much more rigidity and strenght
Some 17mm drivers have very narrow GND ring. BLF17DD for example.
Wow, Iā€™m still trying to find the bottom layer in Eagle, and you bring up truly fancy stuff here.
If you could
a) extend the 4 inner lips just so far, that a 17mm driver can be put on top instead of being soldered planar
- then you have the option to file it down to 17mm if you want it planar, but you neednā€™t. I second the idea for a 5th and 6th lip.
b) extend the whole piece to 26mm while keeping the vias exactly there.
  • then you can grind it down to any diameter between 26 and about 22.
That would be a very variable board for 17 to 20mm driver and 22 to 26mm outer diameter. PCB can be shortened with a dremel and a sanding piece in no time.
Just a thought.
As long as Iā€™m in Eagleā€¦
Would you want guide rings?
The inner tabs already extend to 16mm diameter. As I mentioned, 15mm would cause a problem for BLF17DD and similar I think (?).
The tabs were a big pain and not flexible the way I was doing them. I did some new tabs a different way.
Oh yes thatā€™s truly helpful. Now I start to understand where all these cool Oshpark projects come from.
Sureā€¦
What are guide rings? :slight_smile:
In response to your earlier comment - yeah, Eagle is the the devil. Itā€™s super-not-intuitive. Somehow Iā€™ve started to get used to it. I have also messed with Kicad some, it was different but not better.
Like SinkPADs have, so you can grind a circleā€¦
Yes.
Oh yes. :beer:
Just following your OSH Park ā€˜shopping cartā€™.
Cool stuff.
Itā€™s more than late where Iā€™m from, thanks a lot so far, will look again tomorrow.
HQ
Ah, well hereā€™s something for in the morning. v11 ā€“ 16mm tabs for 17mm driver or file to the outside of the purple line to get a 18mm circle for a 20mm driver. 0.2mm purple lines at 22mm, 24mm.
Here is the Eagle BRD file.
You can add those with tDocu and bDocu, part of the silk screening
Did a tweak to wightā€™s .brd file (just added the white rings is all)
https://www.dropbox.com/sh/deu6qlk49jbop2x/AACqGhANLCeyEdKDSYBYnSYaa
Files here
I havenā€™t shared itā€¦if you would like it shared let me know
Very cool having a modular type contact ring that with a little grinding can make fit multiple pills
Here is Mattausā€™s CAM processor that I added the top and bottom cream layerā€¦just put in the cam directory of Eagle install, when you get your board built save it, open the CAM processor, open the board, generate, zip up the all caps files and upload to OSHPark, you can also upload to OSHStencils and select the correct cream layer for a stencil
https://www.dropbox.com/s/rr81hrecd6olqrr/Matt_Gerber_Generater.cam
EDIT: You cannot just add those with tDocu/bDocu. I know some people will TLDR :wink:
Oshpark frequently cannot keep the silkscreen aligned with the rest of the board - adding thin rings is asking for misalignment. That said, thereā€™s a bigger problem with your suggestion. You canā€™t silkscreen bare copper. Silkscreen is only allowed on mask, it gets automatically removed otherwise in the production process. Therefore you must manually lay down mask rings or the silkscreen generated by tDocu/bDocu will never show up in the finished product. Since the mask is a negative layer and we want to laydown a positive, itā€™s already a big pain to add the guide rings. If you donā€™t know what Iā€™m describing there just fire up Eagle and try to make another mask ring or two at something like 23mm.
So IMO silkscreen rings just makes the board look sloppier after production and adds extra work / gets in the way inside Eagle.
rightā€¦you canā€™t put any silkscreen or mask where tStop and bStop areā€¦those rings tDocu/bDocu were just added over the top of your mask ringsā€¦but as you saidā€¦alignment sucks bigtime (I donā€™t think the bottom layer has the rings, the bottom image showed them thereā€¦but the bottom of your .brd is all copper I believe, the top had the concentric rings of mask above
Thanks a lot. This is everything that could be hoped for. Moving the vias to the thicker regions was a good idea, this will increase stability. And the guide lines should be truly helpful. I did set up an OSH park account (only had ordered a stencil yet) and have now ordered 26mm (v11) and 22mm (v9b). More than happy I am.
I opened 26mm (v11) in Eagle and separated all parts to understand them. Two things seem weird.
The tStop layer (29) seems to be the complete opposite than in the oshpark picture. Solder mask everywhere but not in the small guide rings. Shouldnā€™t it be the other way round? The bottom layer is completely covered with a bStop layer as wellā€¦
Over the vias are red shaded cicles, belonging to layer 1, that are unmovable and unclickable. I can move the 26mm red cicle of layer 1, but not the 8 small ones.
I use Eagle 6.5.0 light, could that be a problem?
Thanks again.
Your Eagle version is fine.
Stop layers are negative - they define where we do NOT want solder mask applied. Generally speaking, most PCBs require solder mask everywhere with a few exceptions, so negative makes sense in a normal application.
Take a screenshot of the red shaded circles, Iā€™m not really sure what you are running into there. Actually, most likely thing is that you ran a DRC from the Tools menu or the tool pallet. If thatā€™s the case you must run a DRC again and this time clear all errors - those are overlap warnings.
Repeatedly right clicking may help you select the appropriate items. If I continue to right click Eagle will select things one by one through the stack under my cursor. Those circles should be easy to select though. Things get harder to select when stacked deeply. Also some items (not those circles) will require the appropriate Origins layer to be turned on, and you grab them using the little origin symbol.
Yes, thatā€™s exactly what it was. I must have clicked there while trying to get a grasp.
Left me quite dumbfounded.
Thatā€™s very very good to know.
Thank you very much. I will stop now asking laymanā€™s questions, you did help me more than enough.
Just got the ā€œassigned to panelā€ info from OSH park, by the way. :slight_smile:
HQ
Picā€™s / measurements of wrightā€™s adapter ring at post 871 of OSHPark thread
I made a thread for the latest revision of the 26mm board here. v13 is meant to be attached to a mandrel in a drill or dremel and filed down that way before breaking out the center area.
