Put me down for at least one, possibly two. I might be able to build a 5A module simply just because, and a more practical 2.5 or 2.8A module for every day stuff.
I’m in…for under $20 for sure…budget
Gonna be a whole flashlight or just the dropin?
i think i’ll have to make a spreadsheet, this is pacing up faster than I thought.
Ooh, what about lens, clicky, boot? If not, I have to add those to my shopping list…
Lens, clicky+boot+spacer included, also the clicky can be replaced with Mattaus’s e-switch or mcClicky by just unscrewing/screwing the retaining ring.
Also I have to work out further options yet, Instead of everyone buying small parts I will add them to the hosts myself at probably no additional costs.
Lets see.
Any thoughts on a screw in pill? The thread on a P60 is 20mm x 1mm pitch. If this was made around 12mm long the reflector would screw on one end and a 17mm driver pocket could be machined in the other and the assembly screwed into the head/body. This would allow for a better heat transfer to the body.
It will, but it might also make it complex for some. The goal is to keep it simple and budget. But a simple threading wouldnt hurt i guess, I might just make one like you said and see how it turns out , it is a great idea.
So it’s currently a host plus copper pill and reflector only at this stage at a goal price point of $20. If we want things like lens, clicky+boot+spacer, then that would be at an additional cost, possibly at cost to you.
It’s still a good price IMHO.
All said and done if you could do a host kit around 35-40 shipped I would be happy.
I’ve seen your other work and it looked exceptional.
If it works out to be something I can just install a regular P60 drop-in and somewhere around 20 then great!!
If not maybe there could be a “economy” model for folks like me who don’t (can’t) get too fancy.
Please count me in.
Thats the plan.
It will be a complete host kit, @mhemling33
Only emitter+driver is needed.
I just hope everything goes as planned.
I am in for one at around $20 also…
Counted everybody in.
Est. Price $20 (+/-$5.00)
count me in too… as I have several lens that need a good home host :bigsmile:
Count me in for two right now, possibly more. Can never have enough p60 hosts. Also will the pills be available alone as well?
Edit: if there is a lot of interest count me in for one, so others have the chance to get one. Otherwise count me in for two.
Definitely in for one, possible in for 3 depending on just how good they turn out.
Will the drop in need wrapping or are you going to size the host just perfect?
I’m in for one too.
Would first like to see the host before I'm able to tell if I want one or not.. if it's better looking than a ....fire or vitac, I'm interested!!
You have some pics to share?
