It’s WW1405090932288077.
Kindly advise once you tracked it’s current location.
Thanks
Thanks
Got mine in today
Interesting…runs great with a 18650 in the adapter
Not really digging the next mode memory…bleh
Modding time…well once I get thru with the rest of my other flashlights and testing the 15mm SK68 drivers and whatnot
I haven’t received mine yet. I have a noctigon star with a XML2 and a Driver that I purchased from IOS for a P20…will it fit?
Who knows? You should post some dimensions.
Most of this is available elsewhere on the forum: The stock driver is 22mm in diameter, the cavity above that is >20mm in diameter - so you can piggyback anything smaller than that. The stock LED is mounted on a 20mm star, so you can use either a 20mm star or a 16mm star. I’m not sure whether the thickness of the Noctigon will have an effect.
clicking on the link gives me this, 404 ERROR - NOT FOUND!
Has anyone else gotten this error?
This is the url at the top of the page, http://www.gearbest.com/led-flashlights/page_not_found
This link?
http://www.gearbest.com/led-flashlights/pp_5499.html
It works for me.
Order W1405200719495112
Order Date: 05/20/2014 22:19:49 PM
“Tracking Details >> SGxxxxxxxxxx9276
Not found .”
This is the url I get when I click on the link you posted.
gearbest: strongest2004:Ordered last May 10.
No info where my order is till now…Hello strongest2004,
Sorry for this problem, could you please pm me your order number, I will keep track of it, thanks.
Kindly advise once you tracked it’s current location.Thanks
I just checked your order#, since you selected Flat Rate Shipping which is unregistered mail, no tracking number is available with this order therefore the shipping progress cannot be traced online.
However I’m delighted to inform you that your order is on its way. The standard delivery time will be around 15-45 business days after dispatch if there are no delays. Please don’t worry,the package can reach you in due time. Thanks.
Most likely something is wrong on your end. Possibly something on your computer is modifying URLs. Try a different browser.
Link works fine for me.
Note, I am signed in to the site; it would not work for me if I weren’t signed in there.
The link that wight provided (which is the same as the one in the OP), works for me:
or, you can go to their home page and put:
ultrafire ceee xm-l
in the search box (yes, “Cree” is misspelled).
Really? I tried it without being signed in to GB - it seemed fine.
musket3 wrote:This is the url
I tried all 3 of my browsers, firefox, chrome and IE. None work, everything else works fine on my computer.
Then I tried this,
ultrafire ceee xm-l
This worked, search for ultrafire ceee xm-l, and brought up 1 light, then when I clicked on the light I got the error message again. I am signed in to my account on their web page. I give up.
I know it has a 20mm star, the reflector centering ring is quite thick so I don’t think a noctigon/sinkpad thickness will be an issue if you either use a thinner centering ring or thin it down a bit…
Noctigons and Sinkpads are thinner, not thicker, than standard aluminum MCPCBs.
All of the 16mm and 20mm aluminum stars I have are thinner than any Noctigon or Sinkpad I have.
Just sayin...
Link works for me without being logged-in.
Just sayin…
I seem to have lots of thicker ones. I think that the aluminum stars I have from Illumination Supply and SinkPAD are all thicker than my copper Noctigons, but on the other hand the inexpensive Chinese stars are probably thinner than those. I have no idea what’s in the F13 head, I haven’t removed the MCPCB yet. My bad
musket3 wrote:
This is the url I get when I click on the link you posted.http://www.gearbest.com/led-flashlights/page_not_found
Then I tried this,
The link that wight providedThe link that wight provided (which is the same as the one in the OP), works for me:
ultrafire ceee xm-l
That is might weird :(…
I’ve seen things like that happen if I am pointing to some incorrect DNS server, or if the browser has the proxy setting wrong.
Have you tried clearing your browser’s cache? That might help also.
