Ahhh, but does it have the modded probe wires & repaired trace on the circuit board from trying to measure a little more amps than it can handle? :bigsmile:
Looking good. A small spacer that fits in the gap on the lens retainer will prevent it being distorted where the screw goes through. It could also be the start of a mount for a handle or it could just be left the way it is and I'll shut up.
I’ll be doing something with the joint on the bezel, I just don’t know what yet… I’ve filed it up a little since that shot to even both the tabs up.
going to be a cool shoulder-fired light when its completed
Looking good.
Thanks guys, bump for today’s progress….
So many more intricate parts that I want to do…… time will tell.
Very cool build. I almost used that same reflector from FT. It seems to be a pretty good reflector.
Good recovery. The timber work turned out nicely.
It’s pretty thin, & mine came with a few small dings in it, but for a couple of bucks….
I used their ‘protective box’ shipping upgrade, as a few guys who tried to buy them ended up getting a squashed piece of alloy in their mailbox….
Tell me about it. I though mine was going to be simple. The devil, Murphy, Puck, and all their friends are hanging out in a club called “THE DETAILS”.
Bump for today’s work (end of post #4).
I like how people are incorporating wood into their builds, it gives flashlights, err… hand mortars, a whole new dimension. Keep it up, this is going to be a good one.
Cool, I really dig this build. Looking forward to more.
Nicely done with the battery holder.
Nice recovery. I thought l'd seen it all but no, modified Phillips heads. What Phillips heads.
Sunday morning, off to work I go……
Bump for today’s work in post #5
Not a lot to see for today’s efforts (apart from the TEST FIRE!!)
A lot of time wasted re-wiring the battery pack & re-doing the end plate again, but better than frying the emitter….
I'd love to see a dozen members on this forum build a joint effort light using basic tools. I could not imagine what the end product(s) would look or work like. Nice comeback with the wiring.
Minor mid-week update at the end of the first post.
The driver that I re-programmed has now been upgraded with FET & Zener mods.
Looks like you’re gonna make it. That is unless you start engraving the stock and inlaying brass. 0:)
