Hi, new forum member here. I have some weirdness with some eneloops I just bought and I'm hoping this is the place to get some answers.
I bought some eneloops off a guy on ebay and they just arrived. I was specifically looking for HR-3UTGB 3rd gen batteries. He advertised he had bulk eneloops, out of package, and he identified them with the number SEC-HR-3UTGB-8B, which I'm fairly certain is the correct number for an 8-pack of 3rd gen batteries. Before I bought them, I asked the seller for a date code from the batteries and (after explaining to him how to read the codes) he told me they were 1 3 11UD, which should be November of 2013. Good enough, those should be some pretty new cells.
What arrived today, on the other hand, is odd. Rather than loose bulk pack cells, he sent me an SEC-HR3U16N 16-pack that he'd cut in half to fit in the envelope. He also cut out about 1" of cardboard down the center so I'm not sure if the two halves are actually from the same package. The blister covers over both halves are still sealed, and I looked at the glue joints up close with a loupe and could see from the dots in the offset printing that the blister covers had not been removed and glued back down, so it doesn't appear that he swapped batteries into a different package.
Looking at the cells through the blister covers I can see that date codes on 4 of them. 3 are 1 3 11UD and 1 is 1 3 03Y0. Ok, they're all from 2013, so far so good. On the back, the right side of the package says "SANYO eneloop" up in the upper right hand corner, and below it is clearly the words "Recharge 1800x" and "Holds charge up to 5 years". That's also right for 3rd gen cells.
The back of the left half of the package doesn't have any numbers, but it had a chart using colored in batteries showing 90% after 1 year, 80% after 3 years, and 70% after 5 years. Again, consistent with 3rd gen. This side of the package, on the other hand, says "Panasonic Energy Corporation of America, Columbus, GA. 31907" in the lower left corner of the package. In the lower right hand corner of the same side is part of the words "Distributed by/dist..." and below that "Panasonic Canada".
Was there a point in time where the packages had both the Sanyo and Panasonic names on them during the changeover?
But here's the weirdest part: The individual cells are marked as HR-3UTGA, at least the 4 that I can see through the clear blister. The cells from both halves of the package are marked with that number. Now that's the number for the 2nd gen cells!
That doesn't make sense! According to the wiki article, 3rd gen batteries started being made in November of 2011. Is there any reason 2nd gen cells would still be being manufactured in late 2013? And be put in packages that said they were 1800x recharge cells with 70% 5-year retention? Which *should* make them 3UTGB 3rd gen cells?
I have looked the batteries over very carefully, and I can't spot any of the usual signs of forgeries. These look like genuine cells, but the date code/model number/package-claim combination doesn't make any sense.
The package I got looks just like the one pictured in this amazon sale:
http://www.amazon.com/eneloop-cycle-Pre-Charged-Rechargeable-Batteries/dp/B005C2Z68M
Except the middle 1" or so down the middle of the package was cut off and discarded before he mailed them.
Anyone have any ideas? Are these really good fakes, or did sanyo/panasonic use up some old labels with the old model number printed on them. Did they fill a newer package meant for 3rd gen cells with an old stock of 2nd gen cells? (That still doesn't explain the date codes.)
I thought the date codes were stamped on when the batteries were made, on the same assembly line. Is it possible some old 2nd gen cells sat somewhere for 2 or 3 years and *then* had a date code stamped on? That doesn't seem likely.
Does this forum support photo uploads? I can send a couple of pics showing what I have if anyone's interested.
