got my 2nd srm763 from mf still the same great quality.
got 2 mario watches for the kids
and a pr of tf flame 14500.
waiting for the microtech combat troodon . 2 weeks to go
(borrowed old's pic)
It would not work at first but I unscrewed the pill and wiggled a few things and all is good. Seemed to have a problem with the switch.
I found a small silver of white plastic that was stopping contact with the spring and switch. Works perfectly now
got 4 AW 16340 cells in the mail. sick and tired of spending money and TIME searching for a budget 16340 PROTECTED cell for my EX10. I wont remove protection circuits, because I know that I Will OD my cells. The trustfire flames were the best so far, but are a crazy couple mms too long to work. The spiderfire yellow '1000mA' were Even longer. And after costing up some of the other brands + risk + time, I had to get some AWs.
So far from a resting voltage of 3.99, I managed to put in another 145mA into each of the 4 cells. Will see how they go when it comes time to re-charge.
Got a notification that I missed the drop off of my Shadow TC6. I can't wait to pick it up tomorrow!
I also got some Ultrafire 10440's to use in my Ultrafire M5 r5 light. Excited to see the difference in output on this little guy!
Oh the excitement!!!
My packages today were also missed drops... The story starting from yesterday....
Received my order from hkequipment today. A pair of Xtar 2600mAh 18700's and a pair of Panasonic 2900mAh 18650's. Got them charging now :)
Same here, two XTAR´s appeared :)
Not charging yet, some day soon...
They probably don´t fit to my WF-139 so have to hook up my Imax...
Charging complete in my Xtar WP2 charger. I'm impressed with how well the pair is matched:
Battery 1: 4.1325 volts
Battery 2: 4.1392 volts
Readings measured with my Fluke 189 multimeter
uf-2100 1 mode from DD for ~11usd, it was weaker than ff-2100 with an xp-g at ~1.2A
didn't measure the current, took it apart and changed the driver to 3 mode 8amc
it's just blue compared to my other lights :(
not today but Friday. UF M2, 2 TF flames 14500, "Benchmade Infidel", Milspec rescue knife. The M2 is an awesome light with a 14500 love it. The "Infidel' came in a Benchmade box with all kinds of warranty paper work and the quality of this clone it top notch. I have bought the Microtech clones before and the quality of the Benchmade clone is far superior. Nothing special with the other knife it did come in a box. Both knives came with sheaths also.
I recieved my cw shadow tc6 yesterday. Looks as though I got ar coated lense as well. Also I will say this is Hands down the highest quality light for the money I have ever seen. Wow! However I did not receive any accessories with mine! just the light itself.
I got the SF L2r. It's a really nice host. The knurling and finish is like the L2i. I was hoping it would fit in a minimag holster but its too wide. Took about 14 days from SF sales. It passed an L2t in the mail. The L2T was only sent out one day before so it should be OK. I have a neutral XRE on order from DX for the L2r but it has been waiting for a supplier forever. I made a spacer so I can run a 4.2V XML dropin with a 14500 in the meantime.
Did you have a link to the BM clone? Sounds good!
http://www.manafont.com/product_info.php/benchmade-3300-infidel-outthefront-mechanism-knife-p-6524
Also now using the knife for a bit the finish of the knife is not holding up all thAt well but the mechinical function of the knife is still nice and smooth and locks up well.
great day for me today. Got my two dqg tiny II and my xeno e03 with diffuser. Wow I really like the xeno.
Got 3 packages.
1 = Ebay - Box of tools for lathe - drill bit (18mm), reamer (19mm), ball end mill (1mm), taps/dies. (lets try to imagine what could they potentially be used for? 18mm drill, 19mm reamer = battery tube, 1mm ball end mill for trit slots.. heheheh! (no plans any time soon, maybe next year)
2 = Tower Hobbies - Bits for dads RC Helis, OS Hyper 55 heli engine, tune pipe, props, and other various bits for my planes.
3 = R2 hobbies - bits for RC cars, wheels, tyres, and fiberglass mat. THIS BOX WAS AMAZINGLY PACKAGED, many companies can learn from R2 for HOW to properly package goods.
Took me 20mins to even get a glimpse of the stuff inside. It was packaged in Multiple layers of bubble wrap, which encloses the items multiple times, and around all this are 3 layers of hard paper/plastic backed foam sheet (think of the take-out foam, brittle stuff, but 1/4 inch thick, cut and taped together to form rigid boxes, with a Very neatly wrapped layer of bubble wrap between the foam built up box layers.... Those box knives "stanley knives" as they are commonly called, would NOT even reach the items if I was to take a serious slash at this box, there probably 1-2" of solid packaging material thickness. And all this contained stuff that was not even close to being called fragile (rubber tyres of 2" diameter, wires, connectors etc...)
And shipping was a very respectable price, Items are seriously cheap, and not only that, it was marked as posted on the 8th, arrival on the 16th.
Dry 3XT6 (CW) and 3 unprotected UF 18650's.......waiting for (1) The batteries to charge, and (2) Darkness.
Should have posted several days ago.. got my DQG from the group buy. Tiny does not even begin to describe it. Love it.
TODAY I got a nifty little lanyard, handmade by a skilled craftsman. I won't say who it is, but if you scroll up you'll see the very same item in a different picture.
I got my spark st6-460NW headlamp in the mail today! So excited to try it out at night. This is my first neutral white so we shall see how I like it :)
DQG tiny AAA R4 neutral from the group buy and Sipik SK68 grey from DX arrived. Very impressed with the DQG and very unimpressed with the Sipik SK68. I think I found my perfect keychain light with the DQG: 2 well spaced modes, no visible PWM , ultra small, easy 1-handed operation on the keychain, but O-ring is "fat" enough that I don't have to fear loosing the head ( not mine but the flashlights... silly BLFers ;-) ). Only minor downside is the slight battery rattle in off position. All in all money well spent. My Sipik has atrocious machining and boings and dents under the anodization. Threads are fiddly and prone to cross-threading. The clip and the push-pull zoom and clicky are OK. I guess you get what you pay for... oh no, I am infested with the CPF virus.
On the upside... the German customs doesn't seem to confiscate all flashlights from the far-far east.
Update: the Sipik has grown on me a bit, since it is brighter than my C78, can tailstand and fits snugly in my standard bike holder.
