At the beginning estimation, or at the end when you actually go to check out? For some reason it keeps on trying to add tax at the beginning, but when you get to the bottom of the page (before you actually check out) the tax will be correct.
Also, if I click estimate shipping and tax initially it removes the tax. I'll get it figured out.
Its been doing it both ways. Sometimes it adds tax at he beginning. Another time it didn’t and I went all the way to the end of the checkout process and then it added the tax right before I was about to pay with Paypal.
Clear your browser cache and try again. It should be fixed now, although I've never seen it calculate incorrectly at the end of the line and I've tried dozens of addresses and zip codes.
Just figured it out! My account address didn’t have a Zip Code. Even when entering the zip on checkout screens – the sales tax still appeared. After modifying my account address to include my zip code – the order process didn’t try to charge me tax. Just placed the order with no problems now. -Steve
Ha ha ha. Even though I know some of my lights are 3000+lumens or have a tight beam I’m still going to look into the business end while it’s on full power one way or another. I know it’s dumb in the back of my mind, but I can’t NOT look at it. I have to do it at least once with each light.
Time to borrow from the digital cameras, and add “face detection” and “red eye” feature to flashlights?
If the lens is pointed at a human face, give a preliminary couple of low level flickers so the pupils contract before full power ….
Or borrow from the laser labs, and provide a stencil that prints on the forehead in mirror-lettering
CAUTION DO NOT LOOK AT FLASHLIGHT WITH REMAINING EYE
By the time I put in all of the work reflowing, sanding, drilling, adding chips etc. the labor is already almost done, so in my mind it doesn't make sense to sell it in kit form.
If you want to buy the parts to do it yourself, here's what you need:
S3 Host
17mm Driver (your choice)
Triple Noctigon LEDs (your choice of tint)
Noctigon 3XP Bare MCPCB (to sand mask off and reflow)
Yes they are. Those spacers are specifically made for the S2 and S3 so that others could build their own triples without needing to be a machinist! The only work besides soldering that needs to be done is to drill a hole in the middle of the S2/S6 pill for the wires to pass through, which is an easy task considering it is thin brass.
