Clear your browser cache and try again. It should be fixed now, although I've never seen it calculate incorrectly at the end of the line and I've tried dozens of addresses and zip codes.
Just figured it out! My account address didn’t have a Zip Code. Even when entering the zip on checkout screens – the sales tax still appeared. After modifying my account address to include my zip code – the order process didn’t try to charge me tax. Just placed the order with no problems now. -Steve
Ha ha ha. Even though I know some of my lights are 3000+lumens or have a tight beam I’m still going to look into the business end while it’s on full power one way or another. I know it’s dumb in the back of my mind, but I can’t NOT look at it. I have to do it at least once with each light.
Time to borrow from the digital cameras, and add “face detection” and “red eye” feature to flashlights?
If the lens is pointed at a human face, give a preliminary couple of low level flickers so the pupils contract before full power ….
Or borrow from the laser labs, and provide a stencil that prints on the forehead in mirror-lettering
CAUTION DO NOT LOOK AT FLASHLIGHT WITH REMAINING EYE
By the time I put in all of the work reflowing, sanding, drilling, adding chips etc. the labor is already almost done, so in my mind it doesn't make sense to sell it in kit form.
If you want to buy the parts to do it yourself, here's what you need:
S3 Host
17mm Driver (your choice)
Triple Noctigon LEDs (your choice of tint)
Noctigon 3XP Bare MCPCB (to sand mask off and reflow)
Yes they are. Those spacers are specifically made for the S2 and S3 so that others could build their own triples without needing to be a machinist! The only work besides soldering that needs to be done is to drill a hole in the middle of the S2/S6 pill for the wires to pass through, which is an easy task considering it is thin brass.
As am I! Per USPS tracking mine is due for delivery tomorrow. Only one though so I do not consider myself greedy. :bigsmile: M6s though are another matter. They look to me more like BEER CANS than soup cans.
S3 arrived yesterday. Even the narrowest beam per the listing, the one Richard calls the closest to a regular reflector type beam, is very floody with a gradual transition from hot spot to surrounding corona. A good beam for many close-in to 50 or 100 foot distance uses in my opinion. Max output and how fast it heats up at max are both impressive. Quite a nice little light to slip into a pants pocket. Running mine with one of Richard’s LG 3000 mAh button top batteries.
