STARTED: GBGB: Stainless steel AAA clicky with a clip (CQG S1 "clone")
in for 1 NW
Cw and nw are shipped.
Hello Ejected Filament,
The specific verification is for your “first name”, one CS found the first name of this order WW1407070617259002 not match for your order History, so she transferred this order to the “verification channel”, but when she found this, the other order WW1407080615043210 has shipped out passed by another CS since your order’s first name and paypal’s name matched. I’m sorry to make things complicated, and sorry for the delay shipping order, we will improve our system to avoid the same situation, hope you can understand, thanks :slight_smile:
Its all good and thanks for clearing it up. I guess Im glad someone is looking at the orders, not simply an automated routine.
My NW shipped too, now the waiting starts.
I wonder if the clip comes installed?
Reason is because I may never use the clip so removing it if it comes installed will probably damage / scratch it…
The clip is pre-installed. Removing it might cause only very minor scratches. Removed mine a couple of times and the light is still looking good in my eyes. :)
Bugger, good to hear it can handle the removal not too bad though.
I also took the clip off, and on, and off, and again i.i.r.c. without visible damage.
Btw, i just took mine apart by unscrewing the bezel, and i find a nice glass lens, an aluminium reflector, a g.t.i.d. O-ring, a (looks like) teflon washer, XP-E on tiny (8mm?) alu MPCB, and a tiny brass pill with a tiny driver.
A spring pushes the pill forward.
Sorry, didn’t take pictures…
Thanks for confirming my findings. :)
[quote=Jerommel] Sorry, didn't take pictures.. [/quote]
I did (see post #53)
Some measurements:
- pill diameter 10.8mm
- star diameter 7.8mm
- driver diameter 10.1mm
- emitter wires: short (almost stripped them by lifting the driver )
- driver cavity depth 4.0mm (3.0 + 1.0mm PCB)
- pill is solid, quite thin though
Some more photos of the pill:
Ah, missed that…
Thanks for the pics.
So, is it GITD or not? Or whatever g.t.i.d. is?
Glow In The Dark
http://www.urbandictionary.com/define.php?term=GTID
BOT: Mine doesn't glow at all.
Thanks again.
:beer:
@gearbest
How long is the processing? My order is still pending under processing.
Order No.:W1407102226414145
Mine does glow, a little… I have seen better, or maybe too little light hits it, dunno…
I got it from dealsmachine when it was on special offer.
Another CW (i suppose) from DX on the way and two NW of this deal.
(ordered seperately because the coupon only worked for 1 item at a time)
Ordered 2x NW + 2x CW. 8)
Just ordered 2 NW.
Thanks =the=!
Hope these come better packaged than the X3 GB lights
