The buck drivers I have worked all use .25 , but (more efficient) drivers from sandwich shoppe have used .05 sense… so I was using .18 based on the current measures here.
This will all get sorted out sooner or later here, thanks.
Not a bad idea of course, when I was using the wrong units it was just really confusing to me where 0.18 came from. Now that I realize my mistake your logic is clear!
desolder is misleading when he says that the chip is rated for 24v, the chip can run on 2-6.5v. The diagram in the datasheet shows a 2.5v - 5.5v Zener Diode in use along with the appropriate resistor in order to keep the chip inside that range.
No doubt that's what some of the extra stuff on the PCB in this thread is. I don't see the advantage of QX9920 over QX5241.
Sorry, too many posts have gone by, so I’ll answer the ones I know about here so we can kind of start fresh:
- [wight, I think]: That was a good call on the solder blob, i.e., you were right, that all 3 components (one end of the toroid, one end of the 151 component, and one end of the brown component) are shorted together, both the blob-less and the blob-ful board.
- [wight, again, I think]: I didn’t find an R200, but I did find an R300, so I figured I’d try that, parallel. From the post above, R300 would be .3 ohms?
So, I have R200 and R300 in parallel, i.e, so equivalent of 0.12 ohms.
Is that correct?
Anyway, I tested the driver after that, and BINGO, Iemitter on high went to ~1.62 amps (from previous 0.90 amps)!
So:
0.2 ohms => 0.9 amps
0.12 ohms => 1.62 amps
I took the Vbat/Vin quite high, > 10V, I think, but I got excited, and didn’t really watch the correlation of the Ibat/Iin vs. the Iemitter, but I did see Ibat/Iin start dropping at some point as I raised Vbat/Vin.
I’ll do that later.
So, given the above, what resistor value do you all recommend to replace the R200 “safely”?
Thanks,
Jim
EDIT: Can we get this driver to 3 amps at the emitter, or maybe even higher?
It’s possible, based on your results, that the sense voltage listed in the datasheet is no longer accurate. Maybe it’s using the same sense voltage used by QX5241, approximately 205mV. Or it could be 180-290mV, who knows. Really it’s just as likely that somewhere in this mess of a driver there’s something messing up the normal sense voltage setup.
I’d dig up an R100 and put that in parallel with the R200 (for 0.0666666666666 Ohms). That should give you approximately the current you want. (maybe 2.7 - 2.9A based on what we’ve seen so far, maybe 3.75A based on what the datasheet claims (250mV sense)) If current is too high, discontinue use until you’ve increased resistance again ;-).
Pushing this current too high will generate problems related to the SS34 diode, the inductor, the no-doubt-crappy FET, etc.
EDIT: yes, you are correct about R300 and about R200 and R300 in parallel.
Nothing, the “R” represents a decimal point. R10000000 would also be the same thing, they are just trailing zeros.
It looks like a 1206, but I’d measure it if I wasn’t sure.
I’d also still consider an order from Mouser. For <$10 you should be able to get out of there with a decent assortment of precision sense resistors. They’ll get to you faster and if you choose the right values you’ll be in a good position to tune your output exactly as you want.
OTOH I always feel a lot of pressure to pile everything I can into a Mouser order so I don’t have to order again right away. With FT you just buy what you want, one item at a time.
BTW, for the record, I’ve added the emitter leads and tested the other board (the one with the blob) and it’s performing the same way as the first one did before I added the R300 resistor in parallel with the original R200 resistor.
So my paranoia about the blob of solder was unfounded :)…
I’ve ordered some of the R100 and R200 from Digikey, just in case, so I’ll have a pile of them :)… Shipping actually wasn’t bad… they apparently ship via USPS first class now, so it was about $3+ for the shipping.
If you’re game, let’s go ahead and stack R200, R200, and R300 on one driver for 0.075 ohms. That will be a good test to see how the sense voltage scales at close to 3A before you place any orders.
The lower we take the resistance, the higher Vcsn seems to be! (2.8 * 0.075 = 0.21)
R100 and R200 in parallel should put you at 3.15A+
~6.4v Vf + ~0.21v current sense = regulated to maybe 6.61v? At that point your batteries are dead anyway. That sounds pretty decent to me. Assuming the driver survives of course!
I wrote a fairly long post about this, but lost it after the forum went down for that unexpected maintenance.
I don’t have much time now to re-write it, but here we go while it’s still semi-fresh in my mind. The PWM / Modes chip does not seem to be the common CX2829, who’s pinouts appear to be:
As we can see from ohaya’s pictures, pins 3 and 4 appear to be “not connected” on the unmarked SOT23-6 package. If that’s correct it can’t be CX2829.
The pinout we appear to have on this driver is :
Vin or PWM (probably Vin.)
GND (sort of…)
NC
NC
offtime cap?
PWM or Vin (probalby PWM)
Assuming any of that is correct, pins 3 and 4 probably need to be pulled to GND or Vin in order to change mode groups, if it’s possible at all. If ohaya will set the driver on “medium” and probe those pins for voltage with a DMM we can get a better idea what’s going on and then recommend an action.
So, I guess I have a stupid question (sorry, being a little self-deprecating today :laughing:… Why NOT short the resistor? Would current go to infinity or something?
Or is the concern that current would go high such that it might overheat the driver (which kind of seems like a good thing :laughing:?
I’m not ignoring you all - I’ll try to get those physical measurements you all have asked for, today, after work.
Jim
EDIT: Also, BTW, I only have one working driver (I KNEW I should’ve ordered more of them). I used a heatgun to pull the R200 off last night, and a bunch of the components came off at the same time. I’m planning to try to re-construct the driver when the new resistors come in, but not now since it won’t work anyway - that was part of the reason I asked about shorting the resistor…
Also killed one XM-L2 so far on this “project”… kind of amazing that it’s not more :)…
