YEZL Y3 CNQUALITYGOODS Group buy. 3 Versions. See post 274 for delivery details.
Long discussion and thoughts thread here.
https://budgetlightforum.com/t/-/24076
More info on the light here. The picture shows an XML-2. Specs say XML-2 U2, I will confirm with Ric.
http://www.cnqualitygoods.com/goods.php?id=1997
Edit. TomE has done a comprehensive strip down here.
Im in!
Why am i reminded of a light built from a bicycle pedal?
Yes, why three indeed?
Yezl
Do we know if all 3 versions share the same driver?
To the best of my knowledge there's only one base unit, you can buy it with or without extension tubes. I have a 1 cell and a 3 cell version from WB, either base unit works with 1,2 or 3 cells without visible output variation.
Thanks Gj.
+1 same here. Pretty sure the 1 cell versions I bought from WB were with buck driver circuitry. The 2 cell might make a nice MT-G2 host with a zener mod driver. Not sure of the reflector opening - will check this eve.
They do. I just bought four of them from WB and they are all identical. Only difference among the samples was one had orange o-rings instead of red.
Speaking of the light, I did some measurements last night, and the emitter shelf is up to 8mm thick! I’ll take some pictures of the light and post them here… now just to figure out how.
7mm
These have an XM-L2 T6, correct? What’s the tint like?
Cool white, looks identical tint to a stock DST on my living room ceiling just now.
Thanks. And it XM-L*2*?
Thanks MrsDNF!!! And cnq.
It look like we don't have to wait for a minimum amount of interested people right?
Mrsdnf, maybe you could link to 1 or a few reviews, mods, so people can get more excited.
The Yezl's are XM-L2, the DST is XM-L.
This was bought as a single cell - note the big inductor for buck circuitry. Nice flat pill top, single piece uni-body style and easy access to the pill top. Massively thick pill top I might add...
In this thread: https://budgetlightforum.com/t/-/24076, post #77 has stock measurements I made, post #86 has the prelim mod #'s and post #117 had final #'s, after the UCLp upgrade. My #'s may be a little high (optimistic?) but I use the very best cell I have, actually the Powerizer may be the best cell in existence - too bad you can't buy them anymore.
Thanks for the great pic Tom. It looks extremely robust. Is the stock mcpcb thicker than a noc or sinkpad? If so, any issues with reflector seating after the swap?
Don’t recall any group buy has its own Web page!
