Sold to pinkpanda.
If anyone else wants one, I can make them on an as needed basis.
Sold to pinkpanda.
Rice Krispies Treats included?
What the hell. Sure.
Freeze the copper pill in dry ice or liquid nitrogen. Makes it smaller till it warms up. Wear gloves and if you use nitrogen, a face shield.
I can't believe it, but it only took one week to go from Pennsylvania, USA to Perth Australia! I am surprised as hell. The parts that I sent to Matt took forever.
And I won’t be needing any liquid nitrogen 8)
Thanks for the deal Bucket.
Whoa, that is one serious looking pill. Congrats pinkpanda.
Missed this thread in the first go. Wonderful job. Sweet looking pill for sure.
Must weigh a lot more with that installed though!
That’s cool. Post some pictures for us Panda.
So, do you think I could pull the restrictions on my driver and run it at 100% with one of these?
It pulled over 14A for 4481 lumens with no restrictions.
Question…could you make it longer and mill a flat for the e-switch to clear? Since it’s a press fit it will go in a specific location straight down, a flat milled at the correct level would allow another 1/4” or more of copper to be utilized. Am I thinking right on that?
Yes, I could make it longer and mill a flat for the e-switch wires. I don't have it in front of me right now, but I believe doing that would allow it to extend closer to 1/2" or more further depending on what driver you use.
I have a BLF17DD piggybacked in pretty tight onto the original driver, said driver being stripped. I use short pieces of teflon wire in 3 place to get ground to the piggybacked driver and make a 3 legged support for it. So it’s strong and well grounded, only rises up about 1/2” above the OEM driver pcb.
*Would have to pull it and confirm of course.
I’m wondering if yet more copper could be squeezed in on the top side, filling the area where the base of the reflector sits? This might serve a dual purpose of giving more mass as well as more head contact to spread the heat out further, ultimately getting heat into the big aluminum pill as well where yet more mass would be available.
It isn’t easy getting rid of the heat from an MT-G2 at nearly 15A and over 4400 lumens.
It has also occurred to me that 2 battery tubes might be connected in order to utilize higher capacity 18650 cells in series…
Dale, we gotta see this.
Gazing into my crystal ball I catch a glimpse of an anodized 2 x 18650 tube by Bucket with Dbcstm on a note inside.
Dale, I think I would just make a completely new center section for that kind of power. A copper core pressed into the finned and anodized outer layer.
What is this super power light you speak of? Pics?
I don’t have a noctigon yet to mount the led properly but I found out the pill fits over the heatsink. Of course, the head doesn’t screw right the way on but anyway.
With the driver stripped and a BLF17DD Z piggy backed in, 6 Efest 18350’s will do close to 15A to an MT-G2 for 4481 lumens. That big ol chunk of copper you have there will make it doable. I had to scale mine down to 6.23A for 3030 lumens because I don’t have that chunk of copper. I DID put an ounce of Silver behind the shelf though.
I do see your point though about re-creating the pill with copper pressed in. That would be the most efficient.
Could you machine a connecting ring in order to tie two battery tubes together? It might be difficult to align the 3 bays but could be glued once that position is found. Then 18650’s could be used for even greater power delivery and better run time. The corresponding ends of the tubes would have to be milled to remove the anodizing to help ensure ground carrying through for the power level looked at here. Might be a pretty neat trick to get the 2 tubes to thread together snug, in full contact for that ground, with the 3 cell bays in perfect alignment.
Anodizing the connecting ring red or orange might be cool to signify this is a dangerously powerful handheld light. lol (Or Purple )
Using 6 18350’s at 700mAh is the equivalent of a 2100mAh cell at 8.4V. Pulling 14+A from a 2100mAh supply doesn’t give much run time. Pulling similar amperage from a 7500mAh supply would be quite the different story! Multiple 3400mAh cells could be used to tone down the power output while simultaneously providing considerably more capacity and run time.
Think this is possible? Worthy?
