That does sound ideal, as long as an XM-L class emitter is being utilized.
I’m thinking of going with an MT-G2 at around 15A, changes the scheme of things considerably where heat is concerned.
'Dale amps' - yes, 15A is a whole different realm there. The Y3's I've gotten have been 1 cell, so been using XM-L2's, but the one I ordered is the 2 cell version, so I'm thinking of MT-G2 also. 15A with an MT-G2 is bout as much heat as 5 XM-L2's would do at 6A each (30A x 3.xA vs. 15A x 6.xA).
Lightly melt the end of a hot glue stick, glue it to the corner of a piece of sandpaper, trim off the excess sandpaper around the OD. Voila, instant sanding puck with a built-in handle.
Sweet. I gotta remember that tip. Thanks CC.
That’s IF the heat output can be interpolated in a linear fashion. The big MT-G2 at 15A is likely to be far less efficient than the 5 XM-L2’s at 6A.
(5x3A max vs 2x 3A max x5 / sq rt of n*Vf over c³)
The theoretical equivalent of the mathematical formulation represented in my last post is purely conjecture based on a triple heaping serving of steaming hot mud.
(Edit: This thread has been edited to remove descriptive text representative of my stupid mathematical formula) Sorry if anyone found it offensive.
I’ve been reading too many of ToyKeeper’s posts.
Oops! Not to imply any doubt as to the integrity of ToyKeeper’s posts, merely insinuating that I am too far gone mentally to even begin to comprehend the multi-level depths of her quoted theory and mathematical genius. (crawling back under my rock now)
Was wondering where that science was coming from... Pure speculation, but if a MT-G2 at 15A is less efficient than 5 XM-L2's running at the same power (ie watts), doesn't that mean more power gets converted to heat? So, maybe even worse? Think you got a room heater there, forget hand warmer.
Winner in isle 5!
Thanks Tom E. I appreciate the effort. Love the work bench cleanliness. Are the threads as others pointed out on the battery tubes the same on your samples?
Pardon the profanity in this thread. What was pointed out with the threads? I just looked at the two pieces and I wouldn't call them square - they are maybe too fine for that, but the overall quality is pretty good. They feel great when threading, but of course I got Nyogel on them.
It was reported and confirmed by another member here that the Y3 battery tubes screw onto the HD2010 battery tube.
For flattening aluminium inside a cavity I flatten the head of a bold that is about half the diameter of the pill cavity (I have a block of cast iron that I made really flat that I use as a base under sandpaper, I use it for flattening led-boards too), wrap pieces of sandpaper around that and start sanding the pill surface with that.
I take mine to my lab for lapping. A little bacon grease on it and he’s really happy!
thanks for the review
take a piece of broom handle or timber that fits in the pill + –3 cm
Take the center and drill a hole.
Take a drill of + –0.5 mm thicker and press it in the middle of the wood.
Now you can turn your drill machiene while the pill turned around to work for more flatter surface. sandpaper the edge at.
2nd way) turn the pill over and tap with a hammer and a piece spindle diameter of + –2 cm in the middle of the pill.
so that the center plane with the back side.
TomE: you have now one AR lens from flashlightlens.com ? for the y3
see you different on brightness?
penumbra, that makes me say “Well DUH!” I knew that!
I’ve seen machinists go to great lengths to set up the machining of a part that takes minutes to do, even making components to facilitate this. I DO know that preparation is key to success. But I, like so many others, always look for the quick and easy way out. Not afraid to work, just afraid to use my brain apparently.
Thanks for that reminder.
problem with this methods is that you must have a little “technical mechanik ” feeling … :nerd_face:
