Review: Callie's Kustoms 18650 High Discharge battery
32 posts / 0 new
old4570
Last seen: 4 days 23 hours ago
Review was kindly sponsored by http://callieskustoms.com/CalliesKustoms-Batteries.html
From Callie's Kustoms :
18650 Unprotected Battery
 2250mAh
Unprotected
10A Max Discharge
Max Charge/Max discharge voltage 4.2/3v
Panasonic uses "PSS Technology" in this battery. A solid solution technology that allows the high capacity of a
standard Lithium-Ion battery and the safety of an IMR battery. This is truly a revolutionary battery!
For testing I have the Callie's Kustoms 18650 High discharge battery , the first thing I did was to test capacity by discharging from 4.2v to 3v @ 0.5A in my Hobby charger , I did this twice , and the results are 2168mAh for the first run and 2162mAh for the second run , and those results are very close and consistent , a good sign .
The next test was to test for discharge capability [ Amps ] , and I used 3 flashlights for this , my best XR-E R2 , my MTE SSC P7 [ long time test light ] and my XM-L T6 3 mode [ from Manafont ] , as the T6 is a serious battery vampire , and when you take a peak at the result graph you will see why .
TFF = Trustfire Flame or second battery from left , and TFG = Trustfire Grey third from the left and CK = Callie's Kustoms .
From the left cell 4 = Samsung 26C and cell 5 = Samsung 28A , from the left Cell 1 = Sanyo 2600 and the 3rd from the right = IMR and the black cell next to the IMR is the AW2600 .
Wow , check out the Callie's Kustoms [ CK ] , 3.9A in the XM-L . That is simply fantastic , and it goes without saying , it has simply wiped the floor with the other batteries when it comes to power delivery [ Max Amps ] . Callie's Kustoms has delivered again , a 18650 that performs so well and gives folks an option to other IMR . If you have to have the best , the highest possible power delivery , decent capacity , you need to visit Callie's Kustoms and check out this battery , it has impressed the heck out of me .
 Always remember , the easiest thing in the world to do , is to expel hot air from your lungs and through some vocal chords ..
The resulting sound may , or may not be worth listening too ….
Edited by: sb56637 on 08/26/2014 - 17:47
agenthex
agenthex's picture
Last seen: 8 years 2 months ago
Is that the BIO IMR? Curious that it's worse than the standard Sanyo 2600.
These new panasonics do look good though.
Reading this makes you smarter: http://lesswrong.com/
sb56637
sb56637's picture
Last seen: 22 hours 21 min ago
Looks really good. Thanks for the detailed review Old! Frontpage'd and Sticky'd.
old4570
Original AW IMR , still performs about the same as when I got it ...
Did 3.1A in my MTE when I got it , still does 3.1A ...  Same with the AW2600 ...  Cant fault them for that ..
xxllmm4
Last seen: 7 years 4 months ago
Thanks for the review! I'm glad you confirmed some of my results. I thought I needed a new multi-meter after testing some of my lights!
I just wanted to make this clear the new Callies Kustoms 2250 Battery is an IMR Battery. I had stated it was was a standard lithium battery. Some of the Panasonic sales literature was very vague.
Later press releases have confirmed it is in fact a "Nickel Manganese-based cathode"
agenthex
agenthex's picture
It's just surprising that it's worse than the sanyo. I mean, what's the point if that's the case?
FlashPilot
FlashPilot's picture
Last seen: 43 min 28 sec ago
Another typical high quality "Old" review. Thanks for having such a great battery addiction and sharing your experiences of so many of those fun little cylinders. I hope I will live to see affordable carbon nanotube battery technology and 6000+ mAh IMR 18650's.
mitro
Last seen: 1 month 1 week ago
In our typical flashlight applications? Safety. That's about it. IMRs are for higher discharge rates that regular LiCo cells are not rated for.
The Sanyo 2600 is an incredible cell and is still preferred by many people over the newer 2900/3100 Panasonics. They hold their voltage much higher than one of the high capacity Panasonics for 90% of their discharge. Now THESE Panasonics are much more like the Sanyo, only they have the added benefit of safety AND the ability to go beyond 2C.
Callie's High Discharge and other @ 3A (to 3v):
CheapThrills
CheapThrills's picture
Last seen: 3 days 1 hour ago
This post cleared about all questions I had with the performance differences and pro´s/cons with these batts. Thanks.
Chicago X
Chicago X's picture
Last seen: 8 years 6 months ago
+1, Great job Old4570 !!!
I would like to live to see a zillion mAh "batacitor," as proposed by the late author Philip Jose Farmer.....part battery, part capacitor, it charges up almost instantly and can dish out power at a trickle, or all-at-once.  Wink
http://wardogsmakingithome.org/index.html
War Dogs, Making it Home - Rescue Dogs for Returning Vets
CheapThrills
Great review, very interesting!
xxllmm4
Just like the 3100's some people assume the extra capacity comes at the price of safety. Please understand I do not consider ANY battery "safe"
So I made a quick little video to see what really happens when they are shorted out.
http://www.youtube.com/watch?v=uaosGRX9BaQ
mitro
You sir, have big brass ones. LOL
But have you tried charging it back up and using it? Silly
old4570
Now thats something Id like to see other battery suppliers try
xxllmm4
"You sir, have big brass ones. LOL
But have you tried charging it back up and using it? Tongue"
LOL sorry I tried, the battery is Toast! its now reading .46v I tried 2 chargers. Both said connection break. I even tried the nimh setting to get it back up to chargeable condition. No luck but we can rest assured it lead a valiant life in the name of science Laughing
2100
Last seen: 3 years 2 months ago
It is precisely coz of this characteristic that i'd love to gun them in DD triple XM-Ls for the Sanyo 2600.  At $5 a piece, can't go wrong.  The XTAR 2600 have very aggressive PCB protection but i suppose the discharge curve is similar.  I can't get Rev Jim's Panny stuff, so these will do nicely.  Big Smile
benckie
benckie's picture
Last seen: 8 years 9 months ago
intresting thread but at $29.41 AUD each shipped to oz puts me out
old4570
I saw you post on CPF , and yeah , upsetting the status quo !
There will always be someone ....   But whats important , is the results ..  And getting the info out there ..
benckie
benckie's picture
you dont mean me
if so its funny how some peole on cpf thing its ok the parrallel charger batteries when the cells are discharging and charging them selfs from 2 to 6 amps + when connecting in parrallel and they think they are all corect and it will not harm or increase the internal resistance of the batteries over time, they make out like people who series balance charge are crazy,
mitro
I have less respect for CPFs "experts" than ever. I'm still an idiot when it comes to the whole thing, but that reads like a total backtrack. "Well no lithium cell is entirely safe..." Yeah... you wouldn't hear that if the cell said AW on the side.
mitro
Where is the data that shows parallel charging increases resistance? I've never seen anyone ever say balanced series charging is crazy... just charging in series without balancing.
benckie
benckie's picture
to have alot of people and post saying parrallel is better then series and why do i bother then the so called proof connecting batteries in parrallel with diffrence in voltage in the cells, then to use graphs and test equipment to prove us wrong  but the info show,s there is a sudden discarge/charge from 2 to 6 amps between cells, then to say there it is parrallel is better and theres the proof.
high charge rates will add resistance to the batteries over time the high the internal resistance the less the amount of charge/discharge per cell, this can be from age/use or how the batteries have been charged and will affect how much current the cell can give and in time will lower the end voltage and life of the battery.
a 2c to 3c (3 x capacity) charge rate is no good for these cells or most other,s and in my honest opinion will add to the internal resistance of the battery, even if they are hitting 1.5c to 3c + for short periods, like parralle connection for charging while the cells self balance.
i belive no one yet has done a pretty graph showing the increases of internal resistance of batteries due to there use,s and chargine connection methods, but over the years of using batteries from an rc back ground of some 20 years and playing with diffrent chargine methods (high & low c rates, multible, series and parrallel) with lixx for the last 7 odd years ive noticed it wil, the high the amp,s you charge a battery the shorter the life, the higher the resistance gets.
and for the record you can series charge any thing and most premade rc packs are made in series and most chargers and made for series charging, some rc (hobby chargers) will limet the charge time and mAh because they are not suit to charging muiltible packs in parrallel (lostly large mah lipo packs) and you can even series charge lixx in series with out balancing if your in a rush, but balance charge is recomended.
just my 2 cents and not worth more as its just my thoughts and my expernce.
now back on topic i would love to test these batteries from the first post i was going to buy 3 till i got to the international shipping page $29.41 AUD each shipped to oz puts me off at thats almost 90 bucks for 3.
i was going to buy some aw,s recomended on CPF at $18.50 usd each plus shipping but that to put me off, ive read some info on the aw,s true or false
http://www.light-reviews.com/forum/viewtopic.php?f=9&t=513
no i was stuck been witch batteries to buy so i brought some tf flames from manafont
http://www.manafont.com/product_info.php/protected-trustfire-18650-37v-2400mah-rechargeable-batteries-flame-2pcsset-p-5560?rp=522815
i brought a couple to test out they took there claimed mAh rating they can take upto 5 amp draw and they are pretty consistance i brought more i now have 12 ive given some to my old man for a jet beam bc40 i gave him and a 2s (2 x 18650) balance charge lead i made and he is happy and 12 shipped was less then $120 aud.
im not say they are the best battery as they are not but for bang for buck if you get originals they are good, but is it worth paying the extra for these ? i mean two trust fire flames 2400mah at just under $11 each pair shipped at todays conversion or one Callie's Kustoms 3100 mah for $29.41 AUD each shipped to oz really worth the diffrence can the naked eye see the diffrence between 0.5 amp draw on high, i cant not on high.
at the price diffrence is it worth the extra claimed 700 mah as you could just buy more of the cheaper batteries to make up the mah, there has to be better more in the middle of the park if you get what i mean.
old4570
Hmmm , The Trustfire Flame 18650 no longer impresses me , as my much older Trustfire Grays now outperform them [ one of the first 18650 I ever purchased ]
I should do a Recap [ test older cells to see how they have aged ] , as I still have most of them .
Unfortunately here in Oz we need to source our cells from overseas , as local prices are far worse , I did try to buy Panasonic etc locally , and at the time the Panasonic 2900 was about $45 per cell from a local distributor ..
You could try contacting CK - and ask about shipping options and combined shipping . And whether you buy CK - AW - RL , the shipping will add to the price .
xxllmm4
Ok, I would like to point out why international shipping is so much.
In order to use printed computer labels through paypal we must use priority mail. It costs us a minimum of $13.XX I simply do not have time to fill out customs forms and hand address every package we ship out to use the cheaper first class shipping.
I would also like to point out that paypal takes a bigger cut on international orders and we carry about 10 times more risk. So part of this extra money is basically insurance (for us) I'm not trying to open a debate or a discussion on this. If you choose not to buy from us because the shipping is too high I completely understand.
Thanks
xxllmm4
I thought it only fair to "test" an AW IMR battery to see what would happen. I bought this battery about 3 weeks ago. Both batteries had about 4 charge/discharge cycles on them.
old4570
That IMR certainly did dump current almost instantly , The Panasonic appears to be far more stable ....
Wow I wonder what AMPs the AW IMR pulled ....
That was very interesting , thank you .
old4570
http://www.youtube.com/watch?v=rPA4cdeyYng   CK 18650
http://www.youtube.com/watch?v=Ro_suW7gMo0  IMR if I got things the right way round
Voltage sag @ 1A   CK VS my IMR ...
old4570
This review is showing on Google ....   Wow ...  Thats nice !  BLF reviews are showing up rather promptly ..
sb56637
sb56637's picture
Yep, Google finally likes us. The .com domain definitely helps. As do excellent reviewers like yourself who constantly provide new, interesting content. Thanks a lot for these reviews!
old4570
http://budgetlightforum.com/node/2581#comment-64061   member mitro has done a nice High Amp comparison ...
how2
Last seen: 1 month 4 days ago
I have tested the Callie's Kustoms 18650 High discharge battery in my Ultrafire TH-T60 (2 mode) The results are as follows:
                                Voltage               Amps
CK 2250mAh               4.17                    5.07
Sanyo 2600mAh          4.18                    4.45
T/F Grey 2500mAh      4.10                    2.65
T/F Grey 2500mAh      4.15                    2.63
T/F Grey 2500mAh      4.05                    2.16
T/F Grey 2500mAh*     4.16                   3.04
AW 2200mAh               4.08                   3.38
T/F red/black                4.10                   3.23
T/F red/black                4.11                   3.15
T/F red/black                4.08                   3.02
T/F red/black                4.13                   3.31
T/F red/black                4.09                   3.31
T/F red/black                4.12                   3.50
* This battery's PCB removed it was reading 0 volts
