Review was kindly sponsored by http://callieskustoms.com/CalliesKustoms-Batteries.html
From Callie's Kustoms :
18650 Unprotected Battery
2250mAh
Unprotected
10A Max Discharge
Max Charge/Max discharge voltage 4.2/3v
Panasonic uses "PSS Technology" in this battery. A solid solution technology that allows the high capacity of a
standard Lithium-Ion battery and the safety of an IMR battery. This is truly a revolutionary battery!
For testing I have the Callie's Kustoms 18650 High discharge battery , the first thing I did was to test capacity by discharging from 4.2v to 3v @ 0.5A in my Hobby charger , I did this twice , and the results are 2168mAh for the first run and 2162mAh for the second run , and those results are very close and consistent , a good sign .
The next test was to test for discharge capability [ Amps ] , and I used 3 flashlights for this , my best XR-E R2 , my MTE SSC P7 [ long time test light ] and my XM-L T6 3 mode [ from Manafont ] , as the T6 is a serious battery vampire , and when you take a peak at the result graph you will see why .
TFF = Trustfire Flame or second battery from left , and TFG = Trustfire Grey third from the left and CK = Callie's Kustoms .
From the left cell 4 = Samsung 26C and cell 5 = Samsung 28A , from the left Cell 1 = Sanyo 2600 and the 3rd from the right = IMR and the black cell next to the IMR is the AW2600 .
Wow , check out the Callie's Kustoms [ CK ] , 3.9A in the XM-L . That is simply fantastic , and it goes without saying , it has simply wiped the floor with the other batteries when it comes to power delivery [ Max Amps ] . Callie's Kustoms has delivered again , a 18650 that performs so well and gives folks an option to other IMR . If you have to have the best , the highest possible power delivery , decent capacity , you need to visit Callie's Kustoms and check out this battery , it has impressed the heck out of me .
