got ya, i was contemplating the same thing, but might try the extra XP-L i have laying around.
You know, that sounds like a good idea. The hot spot looks pretty tight. That would give a bigger hot spot and djozz showed that the xpl didn't lose lumins when dedomed (I think).
Ervin Anastasi wrote:
What is the iner diameter of the lens ?
Just repeating the question so it doesn't get lost. Would like to know that and what is the max diameter lens that can fit in the head.
you are correct, it shouldn’t loose much at all in way of lumens.
Lens size is 67mm and this is the max that will fit.
What lens are you considering.
The adjustment is all the way in for maximum intensity so the pill is almost to the large nut shape on the head. Should have plenty of heat absorption. The head screws onto the tube. Tube is threaded on both sides.
Pitcture of light adjusted for max throw. Pill is is tucked into bulk of head.
Picture zoom out for flood. Pill is away from the bulk of head.
The tube is threaded on both sides. The head is only threaded for about 1/2 inch. When zoomed in the majority of the tube threads are below the head threads and don’t make contact. I imagine you could foil wrap those threads for heat transfer to the rest of the head.
Too bad it doesn’t have a smooth shape and fine knurling.
Wonder if there is enough room to layer the inside with copper to help dissipate heat.
Thank you very much mholdenattorney, the teardown is very informative.
As long as it is solid pill and having good numbers of threads as shown in the picture I wouldn’t worry too much about heat dissipation.
The lens, pill and focusing are all good, and the other interesting part is the driver. I think I’ve never seen a buck driver that small - at only 16mm. Do you mind to take pictures of the driver?
looks alot like a std c8/t20 pill….
Thank you for the report and pictures. If I follow you correctly, this zoomie has some decent heat sinking. I'm thinking about these 2 lens if the stock lens does not satisfy.
http://www.fasttech.com/products/1606/10007641/1660906-jgf-dt63-63mm-optical-glass-plano-convex-lens
http://www.fasttech.com/products/1606/10002523/1583701-replacement-67mm-optical-borosilicate-plano
I have ordered the first one already because I have a light I could put it in. It looks similar in design to a 100 mm one I got from FT that gave me 800kcd with an dedomed xml2 at 7 amps. Obviously, it will deliver less throw all else being equal.
Thank you again and congrats on that light. Looks to have a lot of potential.
EDIT I'll report back on focal length and performance when I get the 63mm lens.
EDIT2: That second lens I linked to looks very similar to the stock lens in your pictures.
Driver is 16.6 - 17 mm. Any ideas for boosting? Probably a 17 mm buck driver.
Bad pics replaced below.
Can't make anything out in those pics. Ohaya has a thread about a 17mm buck driver. You may want to compare your driver to the one in that thread.
Maybe if you can provide the model number labelled on the driver and or better pics (does you camera have a "macro" mode). Being a buck driver, there is probably at least one voltage sense resistor. The resistor or resistors will have a pretty low resistance value (<1 ohm). So it or they will start with an "R" which is the equivalent of a decimal point. Lowering the resistance by adding more parallel resistors will increase current if the rest of the circuit has the capability to deliver more current.
Round hotspot on aspherical = not focused properly = pass!
I think I might push the magic button. Is there any reason not to get the single 18650 version? I wouldn’t want to put anything bigger than an xm-l2 in there.
The single 18650 version should be nice too, perhaps better than the T20, but has a much smaller lens than this one .
Nice pictures again, the heat path looks sufficient for a bit more than 3A at the emitter :-)
A clearer photo that shows the components on the driver might help.
I hope simply bridging the sense resistors works with this driver.
If you look at the beamshots posted here, it is square just like the crelant collimator head....
The spot is round just prior to maximum focus or just past.
It is almost as bright. It is brighter as the led is more clearly focused.
You do not have to worry about adjusting led up or down for max throw because the zoom does this. It is the best of both worlds. You can have big flood or small spot with max throw.
Crelant columnater only allows max focus and no flood.
Hey djozz,
Are you thinking that there isn't enough contact between the tube and the head? I don't have a clear picture in my mind of how it is built, but it seems that what the contact area lacks in number of threads, it makes up for in circumference. Maybe that is just wishful thinking. The head seems large enough to dissipate a decent amount of heat if the heat can get to it.
Another question for Mr. mholdenattorney if I may bother you again,
I take it the head doesn't slide, but screws up and down. Is that correct? The threads look kind of fine and that it would take a lot of time to go from full flood to zoom.
that would be my guess but i was wondering the same thing.
